Does anyone make a shift kit to tighten up the shifts in the NA transmission? I've done a bit of searching and haven't found much. . I plan on buying the boost logic TT trans but until then, it seems like the stock transmission has quite a bit of lag between gears.
You can probably piece together a built trans for cheaper than going through Boostlogic. Buy Red Alto HD clutches, ATF billet 2nd gear sprag & ATF billet forward piston. Your trans would be bullet proof after that.
My 1-2 shift is sloppy since the turbo instal and im worried its going bad. Think this is something that would be fairly easy to do with the trans still in the car??
Yeah there is no way the stock trans can shift fast enough without a shift kit under boost. The Transgo shift kit can be installed with the transmission still in the car. All you have to do is remove the valvebody and do the necessary modifications.
