TPMS Receiver issue
Old Mar 13, 2022 | 09:16 AM
BertDog's Avatar
BertDog
10th Gear
Default TPMS Receiver issue
Hi all, my 2008 Rx400h is showing the low tire pressure warning. It flashes when I first start the car then goes solid. I took it to Les Schwab (PNW) and they said all 5 of my sensors read fine but the receiver is not programmable. It keeps crashing their programming software and they think it is a bad receiver.
So I’m trying to find what to replace. At Lexus parts they show two receivers. One in front and one in back.
https://parts.lexus.com/a/Lexus_2008_RX-400h/63399987__6731940/TIRE-PRESSURE-WARNING-SYSTEM/524410-8435.html
Anyone know what needs to be replaced and why?
Old Mar 13, 2022 | 10:23 AM
spinellib's Avatar
spinellib
They might be wrong. Sounds like one or more of your sensors is junk, that's all.
I suggest you go somewhere else, or figure out how to get Techstream on your own computer (PC), or, last resort, a Toyota dealer.
Do you know how old your TPMS sensors are?
Old Mar 13, 2022 | 11:06 AM
DennisMik's Avatar
DennisMik
As spinellib said, go to another place and ask them to check the sensors. Normally when the TPMS light blinks, it is because the battery in at least one of the tire sensors has died. Regular, standard maintenance for a car 10+ years old.
It is always possible that the receiver is bad, but they seem to be pretty reliable. So go do the easy thing first and go to another tire store and get the second opinion.
Old Mar 13, 2022 | 12:16 PM
lexo98's Avatar
lexo98
Isn’t there a second set of wheels button under the glove box? Someone probably kicked it.
That would be one reason that they can’t access the ECU. Also it is possible the ECU went into a closed loop because it thought it was being messed with. A properly formatted scan tool is required to get it out.
Old Mar 13, 2022 | 01:44 PM
BertDog's Avatar
BertDog
10th Gear
Thx all, I will get a 2nd opinion and yes working getting TechStream. I had checked the 2nd set of tire button and it’s in the correct position for main.
after I asked this question of which module, I thought about it more and think they are grouped per function in the picture. The top one (front) being for the 2 sets of tires and the lower (rear) for the TPMS connection.
Old Mar 13, 2022 | 02:38 PM
DennisMik's Avatar
DennisMik
Originally Posted by BertDog
Tafter I asked this question of which module, I thought about it more and think they are grouped per function in the picture. The top one (front) being for the 2 sets of tires and the lower (rear) for the TPMS connection.
You are sort of right. The rear unit is the radio receiver that the sensors in the wheels communicate with. The unit under the dash does everything else
Old Mar 13, 2022 | 03:49 PM
lexo98's Avatar
lexo98
Most tire store tools are pretty limited and not everyone knows how to use them. Hard to diagnose a bad receiver with them. I don’t think I’ve ever had a bad receiver issue in a Toyota/Lexus. Get a second opinion. If that scan tool can’t communicate with the ECU it probably went into lock mode. Where they able to pull codes?
Old Mar 13, 2022 | 05:06 PM
Felix's Avatar
Felix
Had the same thing happen last year, the tire pressures were correct & I was going to replace the tires, so I bought 4 new sensors & had Discount tire swap them out when installing new tires. One of the new sensors was bad, so ended up using the one good sensor w/ no issues & returned the bad sensor.
Old Mar 13, 2022 | 07:11 PM
lexo98's Avatar
lexo98
[QUOTE=BertDog;11246520]Thx all, I will get a 2nd opinion and yes working getting TechStream. I had checked the 2nd set of tire button and it’s in the correct position for main.
one time I couldn’t figure out why the 2nd set button made no difference so I dropped the lower panel to find out somehow the plug in the back was disconnected.
Old Dec 11, 2022 | 08:05 AM
BertDog's Avatar
BertDog
10th Gear
Solved this. Took the car to another tire shop and they confirmed all 5 sensors were good and had no other ideas. I bought a replacement TPMS ECU and replaced mine and now it is working properly. New part is $600-800 and on eBay it runs sound $100 used.
Andy17
Apr 17, 2017 09:33 AM
Ears
Nov 20, 2016 06:36 AM
lexag12
Jun 14, 2016 08:35 AM
tom33952
Jan 8, 2015 09:08 AM
