Trunk latch keeps popping open
Old Jul 24, 2022 | 05:17 PM
Toffeemen's Avatar
Toffeemen
5th Gear
Default Trunk latch keeps popping open
New member first post here.. I own a 2011 RX350 and a 2004 RX330. Quick question about the two quick release buttons in RX330 trunk that access jack area. Unfortunately one of the latches wont latch on driver side rear will not secure and keeps popping open and lifting up. I tried using wd40 and a needle nose plier to pull catch out with no success. Any ideas for a quick fix and is this a common problem in a 2004 RX330? Thanks for the assistance.
Old Jul 30, 2022 | 04:45 PM
Toffeemen's Avatar
Toffeemen
5th Gear
Need to replace both of these latches that are secured to the frame under the rear scuff guard. Does anyone know the part number or proper name for the replacement parts?
Old Jul 30, 2022 | 04:46 PM
Toffeemen's Avatar
Toffeemen
5th Gear
Old Jul 31, 2022 | 03:38 PM
DennisMik's Avatar
DennisMik
I think this is it...
Japan built car - 58405-48010
US built car - 58405-0E010
The name used is lock, left. I cannot find a lock, right. Do the 2 look to be the same?
Old Jul 31, 2022 | 04:10 PM
Toffeemen's Avatar
Toffeemen
5th Gear
Awesome, thank you sir. That is exactly what I need. Much appreciated.
Actual part number for 2004 rx330 Canadian built. Thanks for the assist two on order.
cfh13427
Mar 11, 2026 10:19 AM
winsalem
Feb 17, 2005 02:18 AM
tkphua
Feb 16, 2003 07:16 PM
