RX400h lock actuator still not working
Old Mar 5, 2022 | 11:36 AM
nyb72's Avatar
nyb72
Default RX400h lock actuator still not working
2008 400h, my driver door lock stopped working via key fob or switch.
I got around to taking it all apart and replacing the motor with the ebay part I saw linked in another thread.
10mm Flat Shaft FC-280PC-22125 Door Lock Motor - Repair Actuator Toyota Lexus D | eBay
After the motor replacement, it still doesn't work.
I checked all the linkages, physically locking/unlocking with the key, or pressing the lock lever on top of the handle, and that part works.
It just seems like electronically, on the driver side door, it is still dead. The lock switch still locks/unlocks all the other doors.
Are there other things I should be looking at? Fuses? Wiring? Try a different brand of motor? Replace the entire actuator?
Thanks!
Old Mar 5, 2022 | 11:47 AM
Put a test light on the actuator see if it gets power when you hit the door lock/unlock.
Old Mar 8, 2022 | 01:10 PM
nyb72's Avatar
nyb72
Thanks!
Actually before having to take things apart once again, I ran voltage through the motor I removed, and of course it works fine.
So, I guess I have some electrical digging to do...
Old Mar 8, 2022 | 02:06 PM
Wires going from the door to the A-pillar (flexy part) could be broken it's a common problem.
pernjiepoi
Apr 23, 2022 07:23 PM
python1
RX - 1st Gen (1999-2003)
28
Mar 18, 2018 02:25 AM
islexusred
Dec 3, 2013 02:26 AM
SureShot
Jul 11, 2013 11:43 AM
action
Jul 19, 2010 04:15 AM
