Tilt wheel squeak
Old Mar 27, 2022 | 08:56 PM
lucasRX's Avatar
lucasRX
Default Tilt wheel squeak
Hello all, how do I lubricate the steering wheel tilt. It makes some squeaky noise after you take the key out and going out of tilt.
Thank you in advance.
Old Mar 28, 2022 | 09:55 AM
Trebbor's Avatar
Trebbor
I had the same noise a few years ago. Have a look at the plastic covers on the steering column. In my case, there was some rubbing going on which caused the squeak each time I removed/inserted the key. Fixed it by loosening the cover screws slightly and readjusting the covers. A five minute job. Hope that works for you. Bob
Old Mar 28, 2022 | 12:12 PM
lucasRX's Avatar
lucasRX
Thanks, Bob. I'll give that a shot once it stop raining and update the results.
Old Mar 29, 2022 | 06:16 AM
bcolins's Avatar
bcolins
I've got the same noise and have been meaning to post about it, so thanks!
Brian
Old Apr 3, 2022 | 10:38 AM
Felix's Avatar
Felix
I'd just bypass it & pull the fuse. I set the s/w all the way out & down & pulled the fuse. No more waiting for the s/w to get to your setting. It'd be great if Toyota added more down & length travel thou....
almondm
RX - 1st Gen (1999-2003)
Aug 12, 2013 08:19 AM
MissyLexxx
Nov 22, 2010 04:15 PM
maxgee
Dec 16, 2007 04:22 PM
