Dashboard Whipping a dead horse
Old Aug 19, 2022 | 10:03 AM
KenM3607's Avatar
KenM3607
1st Gear
Cool Dashboard Whipping a dead horse
Owners of a 2009 RX350 and inherited the "sticky and reflective dash" issue. Did a "hail Mary" and called LEXUS only to be told that there was no longer any support. What has made this issue worse is that we never received and notification of this program. Now left with trying to find a solution to this issue, especially the reflective surface issue. Also, separate from this the TPMS. Replaced two tire sensors, but still get a low pressure warning light. I have been through the reset process with the same results. Any help or suggestion would be appreciated.
Old Aug 19, 2022 | 12:46 PM
uksparky's Avatar
uksparky
Put dash mat cover on thats what i did .. tire sensors last ten years ...costco can check the sensors and see if they are low voltage
Old Aug 27, 2022 | 01:48 PM
4xdog's Avatar
4xdog
10th Gear
I popped for a new instrument panel on my 2008 RX. A Lexus tech I know did the work privately. (I've R&R'ed IPs on my Tacomas, but didn't feel like tackling this one.) Not cheap, but while we were into the instrument panel we also replaced the AC evaporator to solve the "dandruff" problem well known for these years. The combination of the two was money well-spent on a car I'm keeping for the long term. It makes me happy to see that new instrument panel every time I get in the RX.
My original TPMS sensors started crapping out last summer. Thirteen years seems OK life. I didn't replace the tires at the time (they're on the list for before this winter), and breaking/reseating the bead on the 7-8 year old tires has led to one corner with s slow leak. Check your tire pressure at the corners and in the spare to see if you have a legitimate slow leak.
Only replacing two sensors seems like false economy. The other three can't be far behind.
Old Aug 27, 2022 | 09:01 PM
lexo98's Avatar
lexo98
Were the new sensors programmed into the ECU?
BertDog
Dec 11, 2022 08:05 AM
Raven01750
Apr 24, 2021 04:52 AM
mpbone
Jan 23, 2021 10:49 PM
hccaorion
Aug 22, 2019 10:33 AM
Wronglane
GX - 1st Gen (2003-2009)
16
Oct 7, 2017 08:46 AM
