PDA
View Full Version : NX - 1st Gen (2015-2021)
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16
  1. 2017 NX - Brake Fluid Replacement Interval?
  2. NX Parking brake Malfunctions
  3. 2017 NX - P0303 cylinder 3 misfire, fault ignition coil?
  4. Slight ticking noise before engine is warmed up
  5. 2020 NX carplay
  6. Wheel color
  7. Torque Specs: WP, Idler, and Tensioner
  8. SD Card Navigation doesn't work
  9. Error P0456 - Only when it's cold
  10. Question about CPO and independent shops.
  11. Independent Lexus shop in SoCal- Valencia, Santa Clarita, SFV area
  12. Anyone Replaced the Alternator? NX200t 2015
  13. NX upgrad apple Carplay&andriod auto
  14. Voice to text on 2020 NX stopped working
  15. Voice to text on 2020 stopped working
  16. 2020 NX Voice to Text stopped working
  17. Potential new owner
  18. Air ride question/request
  19. Radio and Infotainment Not Working After Battery Replacement
  20. Cover under car
  21. Transmission shift quality question
  22. 2018 NX brakes failed
  23. Will the NX do 200k?
  24. Bumper ends
  25. JDM 2018 Lexus NX300 DRL
  26. OEM part price differences from dealer-to-dealer
  27. NX300 Headliner
  28. Gas/oil smell from vents
  29. Brake upgrade NX300 2021
  30. 2019 nx300h premium
  31. Lexus NX 2021 Model
  32. Locking the car doesnt beep or flash
  33. Tire recommendation for 2020 NX300?
  34. Radio turns on but no sound
  35. Is there a preferred model year
  36. Low Key Battery Warning in Dash
  37. Low highway mileage
  38. Can I change my front bumper to the newest model,
  39. 2018 NX Canadian Version
  40. Leak from Pillar trim while in car wash
  41. Shopping for new tires - Looking for recommendations!
  42. Low Frequency Sound 1000-1250RPMs Underneath the car
  43. New Wheels , Lip Skirt installed
  44. Help - What’s wrong with my side mirror
  45. Front camera black "V"
  46. Another Oil Change Question - Lexus NX300 2020
  47. Dash Camera
  48. 2020 NX TPSM Issue
  49. Car unlocking itself by bringing key near
  50. Leaking oil
  51. Android Auto audio cuts out constantly
  52. Cigar lighter fuse location
  53. Noise from luggage cover and back door 2015
  54. 2016 NX300h Pre Purchase Questions
  55. 2020 Malfunction in the Electronic control Engine, Throttle or Automatic Transimssion
  56. Oil Change Interval/ Spark Plugs on used 200t
  57. MPC remote start 2016 200NXt
  58. NX300 Interior Leaking
  59. 2015 lexus nx - water pump replacement instructions or videos?
  60. Lights on dash
  61. Fumoto Oil Drain Valve
  62. Right marker light not working, DRLs work
  63. No Washer Fluid front windshield only
  64. Anyone have factory service or repair manual for 2020 lexus nx300
  65. Lexus NX300 2021r. Canada - error U0182 Help!!
  66. Extended warranty
  67. Shaky Drivers Side View Mirror
  68. How to read Parts Manual?
  69. 2021 NX 300 - Replace Antenna Assembly and Fin
  70. pk389-78j00-tr rear mud flap instructions
  71. NX300h USB stopped working (2018)
  72. Usb port not working
  73. Trunk light voltage ( to install more powerful led light)
  74. Why there is a need for a "breathing hole"?
  75. NX 350H Color Concerns
  76. Two simple questions
  77. Trickle charge 12v battery
  78. "NuLuxe" seats cracking - under warranty?
  79. Struts and Shocks.
  80. Need Some Input from NX owners
  81. Infotainment Fuse / Not working
  82. Tpms
  83. Is it possible to reboot the SiriusXM receiver?
  84. Lexus NX300h firmware update from version LE.40.35
  85. NX300h Sport or Executive line?
  86. 2021 NX300 hideous noise from Radio/center console.
  87. Favorite floor mats?
  88. Started modding the wife's NX
  89. Rear brake Pads with colored markings
  90. Flooded dead NX300, how to release it so it can be pushed
  91. Looking to lift the NX 2" or so
  92. Bagged 2017 NX200t with Fsport Swap
  93. Is 5Q oil jug enough?
  94. Replacing cracked grille on '17 200t
  95. Micro SD Card location
  96. Aimgain spoiler
  97. El Wire in NX
  98. All for sale threads belong in marketplace classifieds
  99. 1st gen non hybrid tranmission fluid filter change
  100. Front Differential Oil Change - 200t fwd
  101. door side scratches - how to remove
  102. Please tell me about F Sport!
  103. NX Downpipe & Exhaust Options
  104. 2020 NX-300 with 18k miles
  105. Is service department just making this up? Center console display/
  106. OK for Toyota dealer to service Lexus NX?
  107. 2021 NX300 F-Sport Service Spec.
  108. Lost boost
  109. Potential new owner
  110. 2018 nx300 - Android auto add on
  111. NX300 Bass Issue
  112. Throttle body cleaning
  113. Trim along bottom of door coming off
  114. 200T Tunning box
  115. 100,000 Mile Service Question
  116. Is it common to bump longer in the back
  117. Radio Nav Keeps Rebooting Loop
  118. Annoying Whirring/siren noise when accelerating
  119. 12 V Battery deplete in idle mode
  120. Dimensions of rear acrylic "L" emblem?
  121. How dependable is the NX? Do you see your NX going 10 years without issues?
  122. Need Your Opinion - Crankshaft Seal and Belt Noise
  123. NX200t radio assy replacement
  124. 2016 NX200T Bluetooth compatibility issues with iphone 13 pro max
  125. Help with front and rear suspension noises
  126. Dash rattle making me crazy!
  127. NX200T Brake Pads Toyota equivalent
  128. Lexus nx oil change concern - does this oil look new or old?
  129. AWD System Malfunction 2WD Mode Engaged Error Message
  130. Front passenger turn signal light fuse location
  131. Plastic hose clip
  132. No Back-Up Camera
  133. Voice command does not work for "Call Command"
  134. Touchscreen
  135. Replacement Hinge on Front door for XN
  136. rear hatch wont open after dynamat install
  137. Spark Plugs from RockAuto?
  138. Apple Carplay with 2019 Parts
  139. Water Pump Seepage Dealer Declined Work on CPO
  140. Anyone using Beat-Sonic rear/front camera system with the 10.25” android navigation s
  141. Fitting TPMS (on a non-equipped NX)
  142. Put the car in park right before stopping
  143. 2020 NX rear "L" emblem removal - debadge (badge removal)
  144. P013A at 36K miles
  145. NX Carbon Build-up - dealer says 10k (Can) to fix
  146. Front bumper options for non F-Sport 200s?
  147. Tpms sensor on - will it reset???
  148. Text Message Signature
  149. Wireless Carplay Adapter
  150. iPhones won't connect
  151. 8AR-FTS - D-4ST Fuel Injection
  152. Underneath the NX200t
  153. Fixing scratches on my 2018 NX 300 armrest
  154. Aftermarket Wheel Advice
  155. 2015 nx200t
  156. looking for ABS pump
  157. Incessant Rattling from Center Stack
  158. TPMS x2
  159. Wheels and tires set up
  160. 2019 NX Rear Hatch Trim
  161. Rear brakes front brakes
  162. 2015 NX300h w/Rooftop Cargo Box
  163. Is this a Lexus or Apple issue
  164. Adding USB Ports to blank ports?
  165. Check engine!
  166. Setting up text messaging and compass
  167. NX200t 2017 Running Light Bulb
  168. Replace Stock Display with Larger OEM? Android Auto solution?
  169. Need help - rear brake job
  170. 15 nx300 tail light assembly replacement
  171. Any recommendation for dash cam?
  172. Towing Capacity
  173. Moonroof stuck open
  174. NX300h 2015 wireless charger to small
  175. Malfunctioning Trackpad
  176. 2019 NX300H High beams.
  177. Rattles in 2021 NX 300 F Sport
  178. After market module to add Android auto to cars with Carplay?
  179. Keyless system installation
  180. Front plate mangled in car wash
  181. Brake Pads & Rotors
  182. Roof rack cross bars
  183. 2017 NX comments
  184. PCS,brake hold and cruise control malfunction
  185. Help! (Using 93 octane gas)
  186. Non f sport front lip?
  187. 35k Service Decarbonization Highly Recommended
  188. Stored DTC Code in ECU - how many drive cycles to disappear
  189. Sparks plugs - buying at dealership vs online retailer
  190. 2017 nx - p0302 cylinder 2 misfire check engline light
  191. Do I have an alignment issue? Steering wheel slightly off center.
  192. 2018 nx300 App suite apps all gone ?
  193. Neighbor’s Land Rover & My Daughter’s new car
  194. Help With Remote Start - Have to bring to dealership ?
  195. Spotify Car Thing
  196. NX Hatchback won't open
  197. Two iPhones paired at once causing a problem
  198. Spare tire well for storage?
  199. CarPlay Opinions
  200. 12volt solutions installed remote start
  201. TPMS for Toyota Wheels on 2017 NX Base
  202. 2017 NX200T water pump
  203. Gas tank cover flap wouldn’t open and I’m a schmuck
  204. Carista Options
  205. TPMS (not) in Winter Tires
  206. 2018 nx300 headlight condensation
  207. Parking brake didn't release
  208. Broken CD player
  209. Vibrating License Plate Frame
  210. Tonneau cover for 2020 nx300
  211. Tread Depth Mismatch
  212. NX downshifting
  213. Microphone, SOS, destination assist not working
  214. Nx300 Rear Hatch issue
  215. Winter tires 235/60r17 on nx200t
  216. Rear Brake Pads
  217. Battery dead and key not working
  218. Inaccurate fuel gauge and light
  219. Trailer hitch question
  220. Door edge guard pulled off
  221. '21 NX300h Door Lock Problems
  222. Canada spec NX300 in US?
  223. Electric parking brake release - rear brake service mode without a scan tool
  224. 2016 NX200t F Sport Steering Wheel Material Question
  225. NX Ran dry of Gas won't start
  226. Leather or NuLuxe seats in this NX?
  227. Can I disable the seat belt alarm
  228. 2020 lexus 300h system remind on with battery pack plug in to dashcam
  229. lexus navigation off course
  230. Wrench Icon at 9xxx interval
  231. Tti Motorsports ever restocking?
  232. Sulfur smell under acceleration
  233. gearbox "pops" into position when in park
  234. Subwoofer Rattle
  235. Master Switch Rattle
  236. Geolanders
  237. How to disable Communication Module Activation Failed ?
  238. locking the car with the engine running
  239. Spark plug replace
  240. Passenger Side Mirror Malfunctioning
  241. Transmission Responsiveness on Different Driving Mode and Turbo Questions
  242. Strong exhaust fume normal for nx 300?
  243. Faint whistling noise
  244. Heater HVAC issue
  245. No Lights w/Remote Start?
  246. Hazardous alarm
  247. 10.25 inch CarPlay screen from 4x4 shop??
  248. DIY replacement of driver front window
  249. Buttons fell into console
  250. Vehicle Status on Lexus app question
