NX - 1st Gen (2015-2021)
Replacement Hinge on Front door for XN
Old Jun 20, 2022 | 04:59 PM
jgdoiron's Avatar
jgdoiron
9th Gear
Default Replacement Hinge on Front door for XN
Good Evening
I notice that my front door was hitting the door latch so I had verified at the dealer and told me that both my door hinge were gone. I was thinking of just replacing the pins and bushings but the dealer told me that they don't last. So I did get a new upper door hinge at Rock Auto and wondering if you can only get a lower door hinge at the dealer ?
Also do you have to remove the fender to change both hinges? I was checking on You tube and the only video that I saw was for a Toyota Sienna and they had remove the front fender. Any helps would be appreciated
Thanks and have a great evening.
Old Jun 22, 2022 | 12:01 PM
n0v8or's Avatar
n0v8or
Can you obtain a front lower hinge anywhere else but a dealer? Evidently you can (see attached image).
I did not see a model year in your post, so I guessed.
I inspected my NX and 2 of the 3 bolts that retain the upper hinge to the body are obscured by the fender (true for both left and right door).
Even if one managed to remove the hinge without first removing the fender, keep in mind you will need some clearance to re-align the door after the new hinge is installed.
Old Jun 22, 2022 | 01:36 PM
jgdoiron's Avatar
jgdoiron
9th Gear
Thanks for the info. My NX is a 2017. I figured that I had to remove the fender. If this is the case I'm going to replace both upper and lower hinges.
pete116
Dec 25, 2020 10:05 PM
Tymboo
Feb 23, 2016 01:21 PM
rykwebb
May 28, 2008 07:27 PM
MoogieBoogie
May 29, 2004 08:40 AM
97SC
Dec 19, 2003 02:24 PM
