- Brake rotor pics - 91k miles
- which fuse is for MAF sensor
- Rear hatch door won't lift when pressing button on the door
- DVD Monitor Won’t Stay Up
- A/C Issues
- how to remove 2010 navigation module
- Anyone replace their own brake calipers?
- Rear hatch only opens when heated
- What is this part?
- Need help identifying part
- P219C and other issues..
- Settings for locking car
- how to unscrew backdoor license plate screw from inside panel
- Rx 350 2010 -2015
- Front lower control arm bushing at 120k miles
- Roof Cross Bars Didn't Fit 2010 RX450H
- Original DAB Module
- Engine sound
- P0012 A Camshaft timing over retarded.
- Key Fob Cover
- 2015 lexus rx350 f-sport license plate front bracket
- 2015 grille removal help
- Used RX: Miles vs Years
- My RX 350 radio: Is it XM only?~
- Rims identification
- Auto Dim Mirrors
- Outside air only, no AC
- Smoke after new battery installed
- Steering column
- Inside Passenger Taillight assembly
- Lexus is350 brakes fit on 3RX?
- Lexus RX 350 mold/leaky sunroof
- 2011 RX350 Creaking Steering
- Year to year changes?
- 2010 muffler leak - Replacement options
- --New Led tail lights--
- OEM Audio System (with Nav) wired Most 50 interface
- Name of caller not appearing due to international prefix
- Left Turn signal stuck on flashing
- 3RX Seat Covers
- All rear passenger side lights are out
- Sirius/XM Radio Issue
- 17's on RX 350
- Shows no sign of life - could it be a simple as a battey
- Take off ECO
- Cant open the tail gate when running
- Cushion Cylinder Head Cover location
- Transmission oil leak help -2013 RX350
- How long to keep 2010rx350 with 140000 miles???
- Trouble starting
- Melting dash issue?
- BSM and Stability Control. 2013 rx350
- Unintended Acceleration/no brakes event
- Need Help: Tires
- B1441 Passenger Air Mix Servo Broken
- Haul full size mattress 2 miles
- Clear Bra Horror
- Long trip preparation/capacity questions
- Ex 350 milage
- F-Sport Steering Feel?
- Brake/ABS Malfunction after bleeding the passenger side front brake.
- Location of Vapor (Charcoal) Canister on '13 RX350
- etrailer hitch for 2015 rx350 issue
- 2013 RX350 Heat shield question
- Rear shock replacement by dealer question
- 2015 RX450h - RES+
- --My Modded Rx
- Afs headlamps failing?
- 2012 rx 400h liftgate wont open
- AC bar won't go away in nav screen
- 2011 RX350 completely locked up/frozen
- Rear seat cable release mechanism faulty
- 2010 Nav Question. Split screen specifically
- Need help with broken headlight spring clip
- CV joint going bad?
- RX350 vs. ES350 & Avalon for Daily Commute?
- Trouble Shooting Inquiry.
- Turn signal indicator in the glass of the side mirror
- Ghost in the audio
- Power Window Reset
- 2010 rx350 audio system not coming up
- HVAC fan lost high speed
- 2015 lexus rx f sport key gloves
- Trans help... P0741 & P2757
- Parking Brake Stuck..?
- 200,000 k.... doing plugs.... should I change the back coils at the same time?
- minor damage on 2015 Lexus RX350 F-Sport
- Removing shift selector indicator trim
- Auto seat position is hit or miss
- Stubborn rear shock upper bolt
- Battery malfunction??
- Weird power tailgate issue
- Dashboard and panel lights shut off completely when headlights are on at night
- Fuel pump dying?
- Goodbye Allen Key Differential Plugs!
- Whirring noise in dash at steering wheel
- Looking at 2015 F-Sport with Low miles.
- Best RX model 2011-2014?
- P106A. Did anyone have this code before? 2010 Lexus RX 450h
- 13 RX350 Advice
- Steering wheel slight noise question.
- Where to find random plastic filler for this piece on dashboard?
- Advice: 2015 Lexus RX 350 or Rav-4?
- Amp Repair
- 2010 RX 350 Spoiler Top piece glued?
- Tailgate stopped opening automatically
- P0990 Transmission problem
- Rear shock bottom bolts
- 2013 RX 350 horn relay location
- Alignment Issues
- Tire size 255/55/19
- Part Identification
- Help...Rx350 frame damaged leak???
- Cargo area RX350 vs RX450h
- Po990
- Blower motor replacement
- RX350 2011 Apple iphone 12 pro max ios bluetooth incoming phone call disconnects
- Window Belt Replacement?
- Intermittent Vibration At Highway Speed
- Broken lamp glass how to change
- Active Sway Bar(s) for F-Sport?
- Brake pads and Rotor for RX350 2015
- Vibration/hum from 45mph to about 52mph
- Whirly noise from rear after installing new brake pads
- Ghost in/on my Audio
- Alarm arming when doors unlocked after battery replacment
- Rear spring weld gone
- Hatch motor opens and closes with remote, and not hatch button
- Waze issues
- Rust by tailgate
- What is this hose for and should I replace?
- How to change weather strip for front windshield?
- Front oxygen sensor
- Window Seal Replacements?
- Front Strut Install ISSUES - Bilstein B6
- P0500
- Considering a 2014 RX
- 2010 RX with No Nav upgrade to CarPlay
- 2010 Lexus RX 350 Android Auto Unit; Need help!!
- Noise coming from Engine RX350 2010
- Extended acessories run time
- 2011 w/P0607 code after rain
- A/F Sensor Replacement Surprise...
- Soft brake pedal due to missing brake shims? Safety concern?
- inteerior light switch
- 2011 RX 330 tailgate repair
- Drive Belt and PCV valve
- RX 350 2010 few questions about how to
- 2011 RX450 Headlight moisture
- BSM warning light
- Trailer brake controller installation
- 2015 RX350 Base FWD replaced Rear Main Seal and Engine Timing Cover
- Left Sunroof Open During Rain, Infotainment System Malfunctioning
- junk trap/ rust issue
- Taking the car on the Auto Train and the alarm
- New Lower Ball Joints Needed 2014 RX 350 36,000 miles?
- AGM Battery or standard
- 2012 Lexus RX350 Rear Headrest
- Console lid opening
- low car battery leads to failed key fob ID
- 2011 RX350 Diagnostic Tool
- 4th Gen vs 3rd Gen Front Rotors - What is the difference?
- Rear-ended-what to watch out for re repairs?
- Steering Wheel Button or Air Bag Replacement DIY (2013-2015)
- Cigarette lighter ports in console not working
- Hi..Carpet Assembly, Rear Seat question
- Factory premium vs. new Morel speakers
- Driver exterior door handle removal
- Vibration when accelerating
- Any mod's done ?
- 2012 RX 350 AWD parking brake shoes frozen
- Looking at 3rd Gen RX
- Can you replace just the passenger mirror housing?
- 2011 RX350 Cranks but won't start
- Error code P0300/Engine knock on cold start
- Loose interior trim
- Backup camera angle adjustment
- Leak around front driveshaft
- 2010 Audio System Crazed
- Lower Suspension Control Arm and Ball Joint
- 2011 RX350 Wheel Swap Question
- Expensive or not
- 60,000-Mile Service
- 2013 rx350 has power but dead.
- New RX owner here, question about equipment
- Steering Gear; Inner tie rod
- 10' RX350 (AL10) Air Suspension to Coilovers swap?
- Replacing interior rear view mirror to get homelink
- RX450h Wheels??
- RX350 True Towing Capacity
- considering a newer model
- Aftermarket sunglass holder?
- Big Tune up at 120K miles???
- 2013 350 trunk issues
- BSM not working on RX350 and no error
- Loss of audio
- Fair price for 2013 RX350 - Lexus first timer
- 2GRFE/2GRFXE Engine Coolant Drain Plug Locations
- I think I just got ripped off by my dealer
- 2013 RX350 Custom Audio System Installed
- Fog Lights - Bar
- Grille trim piece?
- loud noise coming from the passenger side under the hood
- Call history. Delete not showing up on screen.
- Will a 4th Gen grill fit a 3rd Gen? Rx350
- CPO warranty question
- RX Won't Start
- No OBD connection
- Climate Settings Resetting + No Heat on Driver's Side
- 2015 RX350 Door Mouldings bubbling
- 2010 RX350 Rear Winsheld washer fluid Nozzle replacement.
- Can I use 2013 Tail Light to 2010 Model
- Exhaust Leakage
- Auto lights and Daytime running light system - how does it work?
- RX450 Exhaust blocked
- Homelink / garage door opener - can I add that option?
- What's my next big expense?
- Does this black w/black wheels look good?
- Where to run power wire for Amp.
- Tpms ecu wiring harness
- Rear wiper arm rest position
- Engine Cover...Can I Take it off, and Leave it off?
- RX or GX? Help me decide
- Rear seat problem
- P0116 Engine Coolant Temp Sensor 1 Circuit Range/Performance
- Warning light hell
- Fluid leak under front of car
- BAck up camera upgrade
- Open RX350-2013 Trunk w/o draining battery
- Transmission dead?
- Disc Noise
- 2013 RX 350 stuck in valet mode
- 2012 RX 350 Vent Control Knobs all inoperable
- Garage Door Opener Problems
- Need Help with outside mirror
- High beams not coming on
- Parking sensor question
- Using external inverter for camping with 450H
- Rear wheel bearing
- Poor hot air from central dash vents
- Climate settings reset when car shuts off
- 2? Transmission cooler lines, & oil cooler lines
- Rear tailgate / liftgate won't open automatically. Not due to fob or valet button.
- Lower Control Arm Bushing replacement costs?
- Lowering guidance needed.
- Eror
- RX Catalytic Converter Theft Deterant
- Programmable reverse tilt down mirror?
- Looking for a good code reader
- Cup holder divider/insert
