Power Window Reset
Hey y'all! New to the group here! I recently had to disconnect my battery, and as a result, I lost the one-touch capability in my sunroof and front windows. Thankfully, I fixed the sunroof. However, I can't seem to reset the front windows!! I've looked everywhere and tried everything I could find (lowering window halfway, raise, hold the switch for a second, and another method, open window all the way, close, and hold switch). Let me know if y'all have any suggestions! Thanks!
edit- 2014 lexus rx
edit- 2014 lexus rx
Did you try to initialize it?
1-Hold the power window switch in the one-touch closing position. Continue holding the switch for a further 6 seconds after the window has closed.
2-Hold the power window switch in the one-touch opening position. Continue holding the switch for a further 2 seconds after the window has opened completely.
3-Hold the power window switch in the one-touch closing position once again. Continue holding the switch for a further 2 seconds after the window has closed.
mercurymet
IS F (2008-2014)
Apr 15, 2011 04:17 AM
