No OBD connection
Old Feb 18, 2021 | 01:39 AM
Finlux's Avatar
Finlux
Default No OBD connection
I have a little problem, because I got fail from inspection. Examiner can not read emission test on OBD-tester. Lexus works fine and power is ok on the OBD-plug. Today they tried check that problem in Toyota service but the result was same, no connection to ecu. I have reserved more time to find the problem from Toyota service, but I know that it cost a lot of €uros. I´m thinking that same problems are cars of the same brands. Ladies and Gentlemen, Dear forums users. Do you have any idea where is the problem on my Lexus RX 450H (2010). I have not tester but good tips are welcome.
Old Feb 18, 2021 | 10:17 AM
salimshah's Avatar
salimshah
25 Year Member
Some times words get lost in translation. Just want to make sure that the OBD reader can not read or the ECU values are not available to be read. There is a term "NOT READY" which shows up when the ECU has been reset recently and enough drive-time/start-stop (run) cycles have happened. Some of the driving must be done at highway speeds.
First gen have reported issues with ground wire circuit, but that has not happened enough to conclude anything.
Salim
Old Feb 19, 2021 | 09:13 AM
Finlux's Avatar
Finlux
Salim
I believe that OBD reader can not read. Connection can not form between ecu and reader. I have not reset my ecu. Is it possible, if I now take the ground wire away from battery and wait over night, so connection would return ? Is any other damage possible ? After that I have to make new teaching.
Old Feb 19, 2021 | 12:49 PM
Hayk's Avatar
Hayk
No damage would occur but your Emissions Monitors will be reset. You will need to drive for up to 200 miles to reset them.
If the reader cannot access the ECU that's a more serious problem that needs to be professionally diagnosed. You may have a bad ground connection somewhere.
mab813
Southeast
Aug 28, 2018 02:05 PM
macko1944
HS 250h Model (2010-2012)
15
Mar 29, 2012 11:33 AM
Husker4the
Jul 13, 2005 05:03 PM
