2011 RX350 Cranks but won't start
Old Mar 15, 2021 | 04:22 PM
sf21230's Avatar
sf21230
Default 2011 RX350 Cranks but won't start
My RX350 won't turn over. I replaced the key fob and main battery the other day and the engine finally turned over. I drove it Thursday, it hesitated on starting Sunday but after a few tries it started....Went to go out today (Monday) and it sounds like it's going to start but the engine will not turnover. I did notice that there is a red light on the silver ring my around my start button but the indicator light is green like it usually is when I start it. What does the red light mean? Any suggestions before I have it towed to a dealer?
Old Mar 15, 2021 | 05:36 PM
Clutchless's Avatar
Clutchless
I doubt it is anything you can fix. It could be any number of things, fuel system, or any number of components, and there may be stored codes. You need to run more sophisticated diagnostics and not be on the learning curve at the same time. Have a pro take a look.
If you are in Montgomery or PG County you could consider taking it to Satellite Motors in Silver Spring instead of the dealer. They are an independent Toyota specialist and will be more honest and less expensive than the dealer with great reviews online. I have friends in Maryland who use them.
http://satellitemotors.com/
Old Mar 16, 2021 | 07:59 PM
salimshah's Avatar
salimshah
25 Year Member
Sometimes words can throw the reader off.
crank/Turnover --> fails to spin. [Battery, terminals, starter]
fails to Catch -> Does not run [engine and not the wheels] [imobilizer, fuel, air, spark, timing] Since the engine turnsover/crank, it may give you CEL to help diagnose.
Salim
bez88hlb
Feb 1, 2025 02:11 PM
RX350PTY
RX - 3rd Gen (2010-2015)
Aug 25, 2019 01:31 PM
H20S
Jan 9, 2018 11:46 AM
Calilex34
Jun 22, 2015 12:34 PM
