Programmable reverse tilt down mirror?
Old Jan 14, 2021 | 07:30 AM
NjoyTheSho's Avatar
NjoyTheSho
Default Programmable reverse tilt down mirror?
Hey guys quick question, is there a way to adjust and save how far down the mirrors tilt in reverse? 2011 RX350 I need more tilt haha
Old Jan 15, 2021 | 05:56 AM
Droid13's Avatar
Droid13
I don't think so. You can only turn if off and on. It may be based on the current position of the mirrors though (not sure). You could try setting the normal position of the mirrors a tad lower.
Old Jan 16, 2021 | 08:25 AM
salimshah's Avatar
salimshah
25 Year Member
Mirror tilt does give you double the angle [1degree shift in the mirror angle --> 2degree shift in image], but you may be able to gain 1 to one by adjusting the seat or even bending the neck. You can further shift image by moving the seat forward/backward or neck or both.
Andy does the mirror shift the same angle from "set" position? There is got to be a physical limit on the travel, but an option for the OP would be to set the mirror normal position biased towards the reverse tilt.
Salim
ps: I read Andy's response and he indicates it is an option for OP to test it out.
nate101
Jan 14, 2021 03:00 PM
lexman52
Jan 18, 2020 02:40 PM
IRANDY1948
Mar 15, 2016 04:13 AM
LexoticJ
Mar 20, 2015 08:49 PM
Atlantico
RX - 3rd Gen (2010-2015)
May 6, 2011 04:00 PM
