View Full Version : Suspension and Brakes
- Stuck Sway Bar End Link Nut - Ideas?
- brake master swap
- intermittent brake pedal loss
- Problem with SuperPro Sway Bar Install
- This is rear right control arm and this is not in place, think it causes a camber..
- Someone PLZ FWD me 2GS measurements of Side Rear rectangular window
- Serial999 Products
- Lower Ball Joing question
- No part number application?
- Is my replacement used Mater Brake Cylinder Bad?
- Suspension + front camber arm torque specs
- GS300 KYB struts
- Brake problems
- 98-05 gs
- 2GS Rear Springs
- New Bilstein HD shocks on stock '98 GS400
- Newbie question
- my GS. before and after
- front lower brace in 2017
- Steering rack bushings
- KYB + L tuned springs = bottoming out
- Rear submember bolt torque
- Megan Front Sway Bar???
- GS300 Brake Light Issues. when braking revers lights come on
- Dailiable coilovers for 2001 gs300
- Rebuilt/Remanufactured BMC
- 99 gs300 c0278, vsc,vsc off and abs lights on
- Mystery parts while replacing GS300 steering rack
- LS400 brakes on 2GS help???
- LS spindle on GS?
- 1996 sc400 brake booster
- Anyone in NYC with Fortune Auto Coilovers?
- GS400 Front Roll Center Adjuster
- brake and power steering fluid alternatives
- Just got my Tein coilovers, strut bars installed
- 98 strut assembly for 02 model?
- new brakes
- 2013 gs 350 awd front right caliper pistons will not push in
- Tein street advance coilover ride height
- Bought Moogs, came with problems?
- Brake job on 99 GS300
- Tire wear/camber: Just bought Bc Racing coils
- Spherical Bearing Lower Ball Joints?
- Godspeed Rear Tie Rod
- Ok , i need help. Im really a ametaur but I want to know what needs to be fix
- Looking for a reliable store who ships international
- 2004 gs300 . Ball joint broke off .
- Standard spring height?
- Ls400 front brake swap on 2gs, which RCA?
- rear Lexus gs300 1998 problems
- caliper bolt part number?
- suspension interchangeability?
- Loose suspension / steering '04 ES330
- Fun daily driver
- Gs400 sway bars
- Body kit & lowering springs concerns
- Looking for the suspension brace
- GS400 Suspension Package Bilstein B6's with??
- Stock '98 GS4 - I want to upgrade sway bars only
- 1999 brake booster vs 2004 brake booster
- Lowered suspension - can't align
- Safe to use lowering springs
- Looking for lowering springs and shocks/struts to go with it.
- What are all of the bushings that can be replaced front and rear
- Nitrogen charged coilover pressure?
- Drop zone springs?
- Coilover Issues
- Need to buy camber kit
- Lowering Concerns and Questions
- front suspension - mot advisory
- bent axle from a sc
- That floaty feeling.....advice?
- Lifted one side of car after lowering? What the...
- New upper ball joints, still squeeking
- help Rear air suspension fitment problem
- Question about RCA
- Looking to buy some coilovers... just a few questions.
- FS and WTB threads belong in classifieds only
- Godspeed ( MSS0250 )
- Anyone know if window louvers...
- Front BBK & figs front end
- SuperPro Caster Arm #2 Bushing (Figs vs other dealers)
- When to do shocks/struts ?
- Rebuilding GS300 Rear Calipers
- 38 k miles on EBC green stuff
- last few suspension parts for the build
- Gs300 I have no brake fluid in rear
- Replacing shocks, do I have to do springs too?
- Aftermarket drilled/slotted vs Genuine OEM rotors/pads
- Dont buy cheap ebay balljoints
- Air Suspension?
- Fortune Auto 500 Coilovers
- Figs rca's for caliper swap
- Need help with tire sizes and the right suspension
- Shock/Strut Replacement Question Gen2 GS300... DIY?
- Rear upper control arms for 1998 ? what to prefer?
- OEM Calipers
- New site, Master bushing kit listings, custom options.
- Alignment Issues
- the clunk
- Power Steering in Brake System
- 2005 gs300 VSC lights after front brakes changed
- Advice on lowering car
- Struts
- Lowering spring suggestions?
- New Coils... Opinions?
- Coilovers bushings
- Need help PLZZZZZ !!
- Final Konnexion coilovers
- 2000 GS300 Intermittent ABS/Brake lights, high-pitched buzzing
- Experience or feedback on KSport ProComp or Ceika BBK?
- Rear camber bolt washer
- Trd sway bar
- Battle Version Solid rack spacer and tie rod install
- 98 GS400 ABS Issues
- Ball joint question
- 98 Sc400 Trd Sway bar bushings ???
- Air Suspension: Double bellow, Sleeve, or Cups?
- ball joints worn again
- PSA rear bushing kit.
- Bad Brake Booster ??
- Camber options?
- ABS issue
- Bet you haven't heard this noise before - Expertise needed
- questions about mysterious loud pop
- Front Suspension, LBJ, Caster Arm, LCA, UCA Torque Spec
- Problems with wear!
- Drop
- Control Arms and Ball Joints
- Supra TT front brake swap thread
- Camber adjustment bolt install please help!
- Just wanted to show off new coils
- Trkdrvr
- Need advice on a damaged car and what i should do
- Advice, Upper Arms
- replacement aluminum RCA bearing or bushing sleeve
- I can't get on top of my suspension
- opinions and suggestions coilovers?
- Vsc,Vsc off?
- PPE Headers Install
- Caster(tensioner) arm bushing
- Whats a good spring rate for BC extreme low kit with swift springs?
- 98 GS300 - routing of the rear brake anti-squeal spring?
- What brand coilovers do you have on your gs300?
- Brake pedal gives feedback then goes soft
- Strange, loud popping sound/feeling in my '03 GS430
- round 2 suspension
- Rcf brembo bbk on gs300
- Rca kits and tires size help
- Lowering an inch be?
- Aimgain or Buddy Club Coils?
- HELP! Almost out of patience with this GS!
- Help with increasing ride height?
- BC Coilovers BANG BANG BANG
- Caster & Control Arm Bushings
- Uh-oh brake repair
- Emusa sway bars incorrect!!!!!!!!
- Need help: Megan Racing Sway Bars
- 2GS300/Aristo 98' master cylinder swap form sc430 issues
- GS control arm bushings.
- Megan Rear UCA max camber?
- '98 GS300 - ABS deploying occasionally at low speed
- JZS161 aristo rear upper control arm
- Installed Mega coils, but loud thud sound in rear. Pics
- Brake Booster Accumulator
- Complete Suspension Refresh/Overhaul
- air ride handling
- Need Help ASAP! OEM Lexus/Toyota Shim Kit
- subframe (rear) bushings failing?
- just installed Prothane GS caster, upper, lower control arms poly bushings
- Squeakty-squeak-squeakitin noises from my new to me GS300
- Has anyone looked at Prime Auto shocks?
- suspension concern on 2004 GS430 with about 120k miles
- Control arm bushings
- Thunk/Clunk coming from rear (occasional vibration) check here first
- GS300 Suspension Aftermarket thoughts!!
- Question about rotors
- Adjustable coilers for GS 350
- Bilstein HD, what springs
- rear strut replacement tips needed please!
- Camber Upper Control Arm Opinions
- Front end Maintainence
- Anyone have front end suspension torque specs? Searched high and low
- sway bar bushing or caster arm bushing
- Where to buy rubber front lower control arm and caster arm bushings?
- Reducing negative camber front and rear
- GS300 rear toe in
- Is the castor arm and the lower control arm the same thing?
- LS400 brake upgrade buying decisions
- Brake Rotor Questions?
- Not the Knock!
- Aftermarket Rotors
- Why do people pair kyb's with drop springs if the kyb struts are oem replacements?
- Things to look for and replace while changing springs and shocks?
- Suggestions for shocks to pair with Tanabe df210 drop on GS430? for max comfort
- GS300 Rear control arm help
- Most Comfortable Suspension Setup?
- Brake Master Cylinder Chronicles for my 99 GS400
- Does anyone know anything about this Bilsteins Kit
- Front Ball Joints and Rear Camber.
- Suspension
- Chanigng caster bushing=new alignment?
- Front End Suspension kit?
- Clunking noise coming from rear
- Results from installing 2002 SC430 BMC into 99 GS400
- Installing Megan coilovers. Is there a gasket/bushing on top?
- Car brakes by itself
- New Control Arm
- Strut Bar install 98-00 GS300
- Megan Racing 14mm Camber eccentrics?
- Coilovers for my GS300
- Suspension fix recommends
- Centric Premiuim Rotor rubbing issue
- Sport Design rims fitment w/rear Spacer
- Which brands (tie rod, ball joint, caster, etc)???
- Vibrations After Installing TRD Front Lower Chassis Brace
- Castor Bushing
- Crossmember brace broken.
- Crossmember brace broken. What does it do?
- Upper Control arm thoughts
- Jdm bmc -> usdm gs400?
- Front and rear strut mounts. These look correct?
- Lowering GS300
- I want to get slight drop on a budget
- Help on Front Driver's Side Brake Noise
- need new rotors
- Wheel rubbing against suspension arm
- what kinda lcas will work good for sc400
- Help adjusting height on tein cs coilovers
- Rear end wobble
- Upper Control Arms - Sewell
- Rear knuckle help
- Hipermax coilover won't budge- just spins on body threads
- Upper control arms 98' aristo
- New member needs help with suspension upgrades
- New member with suspension upgrade questions
- Upgraded 2gs suspension vs stock 3g
- Figs swaybar with oem endlinks
- Not the average Coilovers question
- Rust Proof Rotor Options?
- Camber/Toe oem bolts where to order?
- Changed parking brakes on this side and rotors, now clicking noise?
- Good/Best Coilovers For Gs300!?
- New coilovers! Attempt or Nah!
- Is300 coilovers on Gs300?
- Front GS400 Rotors on a GS430
- Help! Inner tie rods question.
- Slight steering wheel woble
- 98 GS300 ABS lights
- 98 GS300 figs lower control arm bushes, swaybar d bushes and ball joints
