Front Suspension, LBJ, Caster Arm, LCA, UCA Torque Spec
Hello CL!
I've been searching high and low for all of the torque specs since I'm currently tackling the following on my '02 GS430.
Struts (front and rear)
Outer Tie Rod (Front)
Lower Ball Joint (Front)
Stablizer Sway Bar Link (Front)
Caster Arm (No 2 Lower Suspension Arm)
Brake Caliper
Brake Caliper Torque Plate
Rotors
Attached PDF that includes all torque specifications for everything you would need to handle a job like this. The next person no longer needs to read through dozens of threads to get the torque specs.
Ken
Brake Caliper
Rotors
Ken
hillwilliam (10-04-23)
shwalker07
03-16-18 11:10 PM
