- Issue with AC-Code 41: air mix damper control?
- Navigation in Gen1 RX; any good?
- ECM does not see new knock sensors
- High Mileage Oil discussion
- New spark plugs eliminated CEL code P0330 but still have P0171 (290K)
- switch "blank" where Trac Off goes: anyone mod a new switch there?
- oil change intervals/high mileage oil
- should i change my brake fluid
- Tire rotation?
- 2003 RX300 Drive shaft replacement?
- Transmission TROUBLE
- Coolant Leaking
- general maintenance tips?
- Need Wheel Offset advice
- Does the A/C need to be discharged to switch out the radiator?
- refreshing my new 99
- 1999 no master key
- Loud squeal 5-10 seconds on startup
- Which spark plugs to use
- Need help in locating rear shell bearing hub
- more dumb headlight questions: sorry in advance
- Washer fluid reservoir
- bleeder screw caps
- Aftermarket parts use/review thread
- Surging hard shift
- Rx300 cooling fan problems
- Multi Display not working ...?
- Timing belt
- Lucas Products
- No heat
- Towing Help, Yes or No?
- p1150 cel code again?
- oil in intake hose
- CEL light turned on and then off
- no codes and engine won't run
- Replacing transmission cooler lines; have ?
- Noise at idle
- Mode servo (again!)
- Front Lower Control Arms DIY
- engine swap
- Mods for a long road trip
- How to cover up the RX300 tape player..
- Lower radiator hose
- fixed P0300 P1325 P1153, 1999 Rx300
- Engine Water Decarbonizing??
- Huge thanks to this forum!
- Toddlers and Lexus.
- Problem with master key
- coolant change
- Drivers mirror
- Dealer stock number and key code
- 2000 RX 300 Centre Display
- Wiper motor does not turn off
- No power under a load
- Death in the family...
- Automatic light - how to change time?
- Rear pop noise when braking or reversing
- 1999 RX 300 Lexus 337,000 miles
- Something strange
- bad VSV on canister
- seat belt retractor 2003
- Towing pkg
- Not sure when timing belt was replaced
- 2000 RX 300 Seat Bolt Torque
- 01 RX w/40K going to synthetic oil good idea ?
- 2003 lexus rx300 muffler replacement part
- Water keep dripping under the car ?
- P0305 - can I just buy an ignition coil?
- RX300 2001 Remote unlock slow to respond
- Looking at buying a 2000 RX300, have some questions.
- Am I crazy to prefer the RX 300 over a new RX 350 ?
- HELP - ** Complete electrical shutdown **
- Front end Vibration
- 1999 RX300 Stumble/Shudder off idle
- ?s re: Nakamichi sound system
- Antifreeze mysteriously disappearing?
- How Important is Heat Shield Above Catalytic Converter?
- Washer fluid pump- help please
- Hatch Lock out of sync with door locks
- oem shocks?
- happy new year
- Screeching sound after starting
- 1999 RX300: not accelerating, exhaust smells, both(?) o2 sensors out
- Toyota Genuine Parts 90915-YZZD1 Oil Filter
- Navigation updates
- Happy Holidays
- HID Headlight Lens Broken
- P0440, P0446, P1130, P1150 Codes simultaneously
- Some Generic Service Items listed in the Maintenance Guide
- poor rx
- in cabin hvac filter
- How To Fix Lexus RX300 intermittent window problem
- Cel's I don't know where to start
- Dallas: Engine Mount Replace cost and Mechanic Recommend
- Driver's fog light, impossible task.
- Center Panel Display Dim in Cooler Weather
- Car start up but engine die as soon as it start
- rx300 2002 keeps blowing remote mirorr fuse.
- Question about Center Display Screen
- Mirror Switch / Security Panel Illumination?
- Sharing my Trans Pan Removal and Filter Replacement
- 1999 RX300 Subwoofer Install
- Exhaust rumble from inside
- Rx300 new owner
- EVAP Canister 1999 RX300
- Source for RX300 fast install struts at a good price...
- RX300 2001 pvc and pcv?
- Rear wheel bearing replacement
- Happy Thanksgiving
- Changes over the years of the Gen1 RX?
- no heat
- Coolant Drain
- AC and Fans Not Working - MGCLT Relay Not Receiving Ground - PLEASE HELP!
- Remote will not lock driver's door
- Northern 2000 rx300 rust rot
- Moving over to 2nd gen
- Lower Control Arms or Bushings
- trans and diff fluid replacement
- removing air/fuel sensor
- Engine Room Junction Box SHORT Pin
- need OEM ski rack for rx300 2002
- o2? sensor ** connector ** location?
- Lexus rx300 abs problem
- Driver's seat position memory system failure
- Timing Belt Price?
- Driver side passenger door's power window and locks not working
- Recommendations for device to add XM to my '01
- miss fire new parts
- New Radio? for 2000 rx 300
- HID/Xenon projector headlight retrofit
- Antenna cable twisted
- Newbie - 90k maintenance questions
- failed transmissions
- MPG display is jumping around
- NV011-98 AUG 98 Exhaust - Idle Booming/Vibration Field Fix
- AARGG!!! Front Passenger Door Lock Manual Mechanism/Actuator Part 17
- Timing Belt
- Rear fog lamps + central lock + DLR problem - HELP!
- lower ball joint for 2000 lexus rx300
- Brakes on RX300 no longer work
- weird gurgling noise from driver dash area only on Decelleration
- front suspension
- New battery but car acts like it is dead
- Rear View Camera/Sensors
- 2002 RX 300 difficulty in starting - Weak battery or something else?
- Is this an A/C Servo Problem?
- Rx300 p0440 Code
- Replacing Front Seat Belts (as a unit)
- Possible water pump leak - thoughts, please.
- Factory Auto tran filter replacement ( paper or metal )
- right front bumper
- 01 RX w 38K miles steering wheel noise
- Interior Cleaning
- Pls Suggest Preventive/Maintenance Services for 02 RX300 w/ 36K miles...ROP
- The piece of foam below the cluster but above the steering column
- RX2002 36K miles - maintenance schedule service
- 2002 RX300 Erratic Shifting
- OEM or aftermarket Knock Sensor
- Key/remote/transponder
- po441,po442,po446
- loose wire in engine compartment
- coolant leak at upper radiator hose fitting
- Change in mpg after air/fuel ratio sensor change
- tool for 14mm hidden plenum bolt
- Transmission slipping - need replacement?
- Hidden Hitch
- how to determine brake master cylinder w or w/o traction control
- Rough estimate to get front and rear brakes done in Northern CA?
- Air Conditioning is growling
- Disconnect TPS
- 01 rx300 fwd engine lurching problem
- Frequency in changing ATF filter , differential oil and transfer case
- P0171, P1153 pending codes
- New Member
- Collision repair estimate reasonable?
- 2001 RX300 air servo
- P0304 Code - Please help!
- timing belt sst
- Need some info - inherited a 2000 RX300 - engine won't start
- Replaced Headlight Leveling Sensor - Warning Light Still On
- can't remove glovebox screws??
- A/C malfunction
- Rear Differential Bushing "fluid" ?
- 1999 RX300, Drivers side heat blowing cold
- New member here. owner of a 2001 rx300
- P1305 code
- What brake pads are you currently using?
- 2000 RX300 no power at low RPM when cold.
- Shifter Cable Binding
- Just rAn over a curb on my rear tires.
- Rear suspension issues
- Flashing Check Engine Lights, What next?
- Remote external transmission spin-on filter install ?'s
- Front passenger door will not open! Tried everything!
- Stereo harness wiring to aftermarket stereo
- Dreaded Transmission Fail - Sell or Repair?
- front lower control arms
- high milage oil stops seepage
- Moonroof won't open / Need access to clean clogged drain
- Purchased March 2008 with 83k miles on odometer BUT...
- How to detach this cigarette lighter?
- Help with 1999 RX300 courtesy light issues
- P0125,P1135 & P1155 codes
- Best option for a dvd/navi player for RX3000
- P1135 code
- Battery dying
- Engine and brake problems
- Serpentine Belt Disaster!
- Need help - Codes p0171, p0136, p01133, p0300, p0301, p0303, p0305
- Right blinker suddenly blinking fast
- Question on replacing valve cover gasket and torque strut
- 03' RX300 Radio cuts out for 15 Seconds
- Windshield Washer Jets
- 03 W 38K for $11K
- P1780 and P1780* error codes
- If I had ATF changed, do I still need to do front differential fluid change?
- Out with the old and in with the new
- rx300 2000 overdrive issues, and knock sensors
- Oil consumption resolved without new rear valve cover
- Noisy front wheels
- Goodbye & Thank you
- rear cv axles
- 2000 RX 300 Major Engine Oil Leak ?????
- Rattling noise from front tires 2001 RX300
- $2,000 For A Complete New Suspension?
- Autodoor lock
- RX300 Overheating
- RX 300 squeaks when in reverse
- Knock Sensor Parts Question
- 02 rx300 premium sound system will not power on.
- Newbee here 1999 model
- New member with 2000 RX300 question
- rear knuckle bushing
- Hi everybody! unfortunately I need help..
- Introduction and Thank You
- Master key vs cloning a master key
- manifold an expensive repair??
- Pulling my hair out with the CEL 1999 RX300
- New member/owner of a 2001 with 137k miles
- New member saying hi
- Thinking of buying RX300, 147k miles
- Halo Headlights for my Lexus Rx 300
- key programming issues
- P0440, p0446 & p0765
- What are these other diagnostic ports?
- RX300 ignition switch r&r - guidance?
- Ignition Switch - need Toyota p/n
- A/C low pressure port
- Help with timing belt change
- AC blows cold air only in driver side vents
