is this a suspension problem? noise while turning
Old Nov 3, 2008 | 10:48 PM
acenase's Avatar
acenase
Default is this a suspension problem? noise while turning
Whenever I turn my wheel to the right to turn it makes this ERRRRRRRRR noise. I checked to see if the tire was rubbing, but it's not. So I w as just wondering if anyone had something like this before and knows what it might be?
Old Nov 4, 2008 | 07:18 PM
acenase's Avatar
acenase
Could it be the steering rack bushings?
Old Nov 4, 2008 | 09:25 PM
dwebb99's Avatar
dwebb99
Check your power steering fluid. Could be a wheel bearing. Check your tire.
Old Nov 5, 2008 | 12:50 AM
vinh's Avatar
vinh
record this noise and show it to us
Old Nov 9, 2008 | 10:51 PM
Myblacksc's Avatar
Myblacksc
can you be more specific? You hear the noise when making a right turn? or when turning to the right while at a stop? Left turn also?
Old Nov 14, 2008 | 04:49 PM
818sc400's Avatar
818sc400
my car is also making a clicking noise when i turn the wheel completely to the right at a stop. no vibrating or anything tho at high speeds, the sound is annoying like somethings F'ed up
Old Jan 30, 2009 | 09:55 AM
Enigma8246's Avatar
Enigma8246
Bump. Having the same problem. Anyone ever figure anything out on this? I really don't want to replace my steering rack if it's not the culprit.
Old Jan 30, 2009 | 12:49 PM
818sc400's Avatar
818sc400
nope i jus lived with it. it only makes the noise when i turn the wheel completely to the right
Old Jan 30, 2009 | 05:03 PM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
Has any of you tried lifting the front tires up and does the noise still appear or does there have to be weight on the wheels? I would lean toward a wheel bearing or a tie rod, lower ball joint, or sway bar link busted or cracked. Just something to look for while you have it jacked up.
Old Jan 31, 2009 | 06:39 AM
Enigma8246's Avatar
Enigma8246
i thought about the tie rod too. I'm really hoping thats it. A friend of mine owns a shop and imma drop it off tuesday to let him look at it. As expensive as parts are for our cars, i like to get a professionals input before i start buying parts.
and mine isn't just when i turn all the way to the right. its every time i turn right no matter how far.
Old Jul 28, 2009 | 07:36 AM
Patsfan's Avatar
Patsfan
having the same clicking problem noise when i turn hard left. i notice it the most when i am parking in my parking garage and have to keep turning hard left when i got up the levels of the garage.
Old Sep 1, 2009 | 03:13 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
has anyone figured this out? my beater is making the errrrr noise when turning 80-100% left at lower speeds. would the seals alone cause this? its like a metal on metal errrrr noise. it had play in the steering, so i put in the daizen bushings.
now steering is tight but didnt help the noise any.
**edit: fixed it by topping off power steering fluid. (half way is not enough)**
tzxlyd
Jan 22, 2017 09:41 AM
RLGS300
Aug 15, 2011 02:50 PM
knocker
RX - 1st Gen (1999-2003)
Jun 30, 2011 03:09 AM
Yg_green1
GS - 1st Gen (1993-1997)
16
Jan 1, 2008 09:40 PM
