auto tranny problem..
Old Nov 7, 2008 | 12:38 PM
DKNY0331's Avatar
DKNY0331
Default auto tranny problem..
hey i got a problem.. when you put the sc300 in drive and no matter how hard you hit it 1st gear feels weak or maybe feels like a slip. but either way it feels abnormal.. when you hit the gas under any throttle 1st gear whines out to redline then shifts to 2nd. 2nd engages but the rom increases but does not move car or accelrates.. 2nd gear does engine brake so its weird.. 3rd gear and o/d is working fine. its mostly 2nd gear im worried about.. i did a stall test specs say 2200rpm give or take 150rpm.. at idle with the pressure test hooked up it reads 55psi in specs.. at stall speed it reads 130.. which is under specs (189+ specs).... in reverse in idle it read 75psi which is under specs and stall speed in reverse is 215 under specs (should read close to 250+) i herd about some kind of vts or somehtign about pressure control valve but idk im new to the auto tranny but learning. any one can help me? history..... i gotten a code 63 2nd selenoid was malifunction.. so i replaced it. with a napa brand not oem.. but it worked fine. what happen was it would strat off in 1st gear but skip to 3rd.. but you could manualy down shift to 2nd gear and it would fine... any way the selenoid got replaced and it ran good for 2weeks until 2nd gear acted up..
Old Nov 7, 2008 | 02:57 PM
DKNY0331's Avatar
DKNY0331
also i got a auto tranny from the 2jzgte will it drop right in with out any mods?
Old Nov 8, 2008 | 11:25 AM
DKNY0331's Avatar
DKNY0331
bumpppp............. still got the problem anyone certified in auto trannys.
Old Nov 9, 2008 | 05:51 AM
aliga's Avatar
aliga
Former Sponsor
gte trans will not work, i have trannies for sale with lo miles, 400 shipped if you need one.
Cjet
Aug 17, 2014 06:36 AM
619Rider
Jul 18, 2011 01:22 AM
drock02
IS - 1st Gen (2001-2005)
Sep 7, 2007 05:22 AM
born
12
Oct 22, 2006 06:50 PM
mike714
Feb 22, 2006 02:52 PM
