throttle body
Old Nov 8, 2008 | 04:51 PM
matrixgts's Avatar
matrixgts
Default throttle body
just a couple of questions fellas.when cleaning out the throttle body should you just spray cleaner on a rag or just spray cleaner directly in to clean it.also if you are spraying directly in should the car be running.also should i spray cleaner into pc valve to clean it or should i remove it and spray in.i read some diys where they did both i just want to know which way is the correct way.if their is a correct way.THANKS FELLAS.oh 97 sc 300 automatic
Old Nov 8, 2008 | 05:54 PM
LEX_MAN's Avatar
LEX_MAN
I dont think you should clean the TB while the car is running.Just do it right and take it off to clean it.
When you clean the TB with the engine running you are not using the air filter, and anything from the rag,like lint and stuff can get in your engine .
Just my 0.0002 cents
Old Nov 8, 2008 | 08:32 PM
ralsty's Avatar
ralsty
Take the TB off and spray right into it!
Old Nov 9, 2008 | 05:20 AM
matrixgts's Avatar
matrixgts
thanks for responding fellas,i already cleaned MAF sensor i need to clean the throttle body now, but it looked pretty clean but i'll clean anyway just so i know it was done
excaliber
May 7, 2015 07:23 PM
lexus-is2
Dec 15, 2013 09:32 AM
LexGs300D
Aug 2, 2012 04:53 PM
bigblack06
Feb 25, 2012 12:53 AM
Stage3
Maintenance
Jan 8, 2008 07:05 PM
