PDA
View Full Version : RX - 4th Gen (2016-2022)
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19
  1. Passenger side storage
  2. 21" wheels on 2022 RX?
  3. Precut tail light tint for 4RX w/ triple beam option
  4. P0430 help!!
  5. Mystery Remote starting
  6. Lost Sport+ mode on 2017 RX 350 Fsport
  7. Anyone have TRD body kit or exhaust?
  8. 2018 Rx Cup Holder Question
  9. Is there a way to turn off the Green lights on the cluster ? BSM park assist etc?
  10. Was my windshield replaced?
  11. Wireless earbuds case and keyfob issue
  12. 2017 RX450h wiring connector behind cowl
  13. Sway bar bushing replacement?
  14. Worn sway bar bushings?
  15. Loose cable under drivers seat goes nowhere
  16. Locked out of RX350, keys not working
  17. Is this rear center headrest piece replaceable?
  18. 2018 RX 350 Passenger seat won't fully retract
  19. Looking for advice/comparing two RX’s
  20. Windshield camera fog?
  21. 2013 vs 2022 rx350
  22. Android Auto connects sometimes
  23. Android Auto ?
  24. Front struts replacement: torque specs and tips?
  25. A Woman in Desperate Need of Advice buying used car
  26. adapter to make wired iphone connection wireless
  27. loud rain noise on my 2021 Rx450h
  28. Loud Annoying Noise in reverse
  29. Tuned RX 350 F sport 2019
  30. weird cupholder issue with 2022 RX
  31. Ticking Sound Steering Wheel
  32. Rear door window / glass removal / replacement?
  33. New to Lexus: 2021 RX350L Maintenance Costs?
  34. Recall for Air Bag Sensor?
  35. Display shows a picture of a sd card
  36. Need help 2022 RX350 less than 20k miles multiple alerts
  37. 2016 RX350 AWD - Front Suspension feels loose
  38. Soft Dinging Sound
  39. Collision repair schematics???
  40. Looking to buy 2018 350L - carfax shows sketchy service internals - can computer help
  41. Can anyone ID this chirping noise?
  42. Leather Patch
  43. 2020 F Sport 3 Towing
  44. 2022 Rx350 - Looking to purchase used - should i be worried about exhaust drone noise
  45. AC Compressor Relay / Power - 2017 RX350
  46. Is this loud lifter or engine knocking?
  47. 2019 Lexus RX350 Moonroof/Sunroof Window Seal Number
  48. Sound of refrigerant moving
  49. CPO warranty-extended the time car is being repaired?
  50. 2019 Rx350 - Should I take it to Lexus for annual inspection?
  51. F sport transmission selector
  52. Weird Behavior - windows and door locks
  53. 22 Lexus RX 450 Rear Bumper Help
  54. ‘17 Intermittent knocking noise on passenger side
  55. Green light on air recirculation buttons and others doesn't light up
  56. How to enter destinations as geo-coordinates?
  57. Leaking Shift Shaft Seal
  58. Unlocking doors issue...possible gas cap door actuator malfunction?
  59. Key programming - 2022 RX350
  60. Revs high with cruise control on.
  61. Rear Seat Squeak
  62. Alarm goes off randomly in the night
  63. New Keyfob message on Display Screen
  64. Standard features of Safety 2.0+ package?
  65. Wind noise inside the drivers door
  66. Ignition coil looks overheated?
  67. Center Screen Making selections on its own
  68. Disable passenger seatbelt/airbag warning?
  69. Movement inside driver seat
  70. Intermediate Steering Shaft ??
  71. Ticking noise
  72. How to adjust navigation display?
  73. Frozen lock
  74. steering binding when on cruise control / lane centering
  75. What is this device installed on the dash?
  76. 350L Tow Package FWD only?
  77. Blur on the bottom of HUD
  78. CPO Rx question
  79. Got the 20-21 airbag sensor recall letter today
  80. Has anyone custom flash software on RX450h 2017 model?
  81. Replacement heat warmers
  82. OEM mag got trashed
  83. 2022 RX350 Engine Vibration After Oil Leak Fix
  84. Permanently disable faulting BSM?
  85. Vibration while accelerating
  86. 2016 RX350 - P0037 code
  87. Front Strut bar
  88. 2021 RX350 timing cover gasket replacement
  89. Wireless Android Auto & CarPlay for your Lexus RX's infotainment system
  90. Is height of infotainment system bothersome?
  91. Microphone failure
  92. Door opening while driving?!?! 2022 RX 350 F Sport
  93. Seats damaged by dealer (heating element)
  94. A/C cooling power on 2016-2018 RX
  95. Leaking from rear shock
  96. Struts/shocks, spark plugs covered under CPO warranty?
  97. 2017 RX350 Easy exit / shutdown issue
  98. Lease mile overages
  99. Backup camera image options (non-panoramic) for Gen 4 RX350
  100. Screen and radio frozen
  101. Is it Carplay? iPhone? Google Maps? Normal?
  102. Issues with windshield
  103. Metal Sound When First Backing out of Driveway
  104. Front sensor calibration
  105. Dealer recommends throttle body clean at 30,000??
  106. Really dead battery in cold - odd symptoms
  107. Creaking sound from roof
  108. Update mileage on MyLexus dashboard
  109. Things to look during test drive?
  110. Key not detected
  111. Problems downloading Lexus RX service history
  112. Where is the blend door actuator?
  113. Seat belt does not retract - 2016 Rx450H
  114. RX 350 F Sport Brake Noise?
  115. PKSB Light Flashing - '17 Rx350
  116. DCM Error
  117. 2017 Rx350 Oil leak fixed in Dec now radiator problem
  118. rear window defroster not working
  119. 2022 RX Shift issue in M mode
  120. Brake Pad Warning System?
  121. CPO 2021 RX350 F sport purchased but Now Lexus says it’s not a CPO
  122. Rx350-2020 Strange warning messages
  123. Used RX Dealer Discounts
  124. Update to Transmission Programming
  125. EPS steering wheel noise on start up for RX 350
  126. 2019 RX & Remote Start.....
  127. 2018 Back UP camera repair
  128. How to remove rear captain seat cup holder?
  129. TRD wheels on 4thGen RX350
  130. 2022 RX350 Bottom door trim replacement
  131. Sport Mode Transmission Issue
  132. Toyota Recalls Certain 2020-2022 Toyota and Lexus Vehicles
  133. TSB L-SB-0032-23 - Thank you
  134. Preferred Fuel Cap
  135. Shopping for a unicorn?
  136. Front Window Washer Aim Adjustment
  137. How to stop Spotify automatically playing iPhone 11 ProMax
  138. 2017 Rx350 won't start
  139. Alignment Fnt Camber@-1.4 and -1.2
  140. Looking to purchase Lexus RX 350 2020-2022
  141. How to restore apps?
  142. Rear bumper dent and tailgate light repair
  143. ambient strip of light in door f-sport or non f-sport option
  144. Rear hatch only opens partially
  145. Split screen setting.
  146. Intermittent starting issue
  147. odd noise from engine used 2021 RX350
  148. Key fob no longer locks/unlocks after installing new body control module
  149. Android Auto Maps, Automatic Day & Night mode not working
  150. Headlight aiming
  151. 2021 Highlander TPMS on a 2020 RX350
  152. Steering Power Low code
  153. 2022 Rx450 window seal issue
  154. 2019 Tailgate issue
  155. Trade 2020 RX for a 2024 RX or TX
  156. 2019 Climate Control Question
  157. Is it worth upgrading from 2020 RX350 base to 2021 Luxury??
  158. What are the differences in the 2016-2022 RX350?
  159. Block off plates for canbus under driver side headlamp
  160. Looking for sideview mirror wiring diagram
  161. No washer fluid to rear wiper
  162. Covers Recommendations
  163. Upgrade Base model steering wheel to F Sport w Paddles and Heating
  164. BT and CARPLAY music disconnects??
  165. replacing the qi charger on 2022 RXL
  166. Tires inflated to 37psi by dealer during scheduled maintanence
  167. Can I play videos on the screen?..
  168. Aftermarket intake for RX 350
  169. Carplay suddenly vanished
  170. Musty Smell (checked AC)
  171. Erratic Cold Shifting on 2016 RX350
  172. Excess Lease Mileage
  173. RX350 : power rear door stuck pls Help
  174. Question on cabin temperature display
  175. 2017 RX steering power low U0131
  176. RX - 4th Gen Tail Light Replacement
  177. Tongue Weight
  178. Hitch mounted Cargo Carrier
  179. Panorama roof available on 2019?
  180. Hands-Free Texting Functionality Change? 2020 RX350
  181. Adaptive Cruise Control shutting down 2017 RX
  182. Please help! Noise from front right wheel going over bumpy road and pothholes
  183. Wheels set up question
  184. Transmission Fluid Leak
  185. Trade 4 gen RX350 for Venza?
  186. Tire psi read out showing ———
  187. Is There A Way To Permanently Disconnect my iPhone as Audio Source?
  188. Brake Problems
  189. 2017 Lexus Rx350 Purchase help
  190. Dimples in interior door panel rx350
  191. Leaving my 2022 RX sit for a month
  192. Is rear windshield wiper location different on RX-L?
  193. How to remove cup holder - 2016 RX350
  194. 2019 RX 350 Power Back Door takes multiple tries to close
  195. Lexus app not working (Android). Dealer says must pay to use app.
  196. Purchase help on 2021 RX350 FSport
  197. MFI certified usb to usb c cable
  198. Which RX350 is most reliable? 2020, 2021, 2022
  199. 2021 RX350 vs 2021 ES350
  200. Can someone Tell me what the drivers side fluid well is for.
  201. Front Cam bolts
  202. RX350 WRAP Color - closest to Ultra Bright White?
  203. Humming noise after cold start
  204. Lock dimples on handles do not work
  205. Green light in middle of rearview mirror
  206. Orange/ rust colored stuff in oil cap
  207. 2021 rx350 multiple malfunctions error
  208. Proper pressure for 255/50 20's
  209. Multiple malfunction messages after Viper install
  210. Looking at 2021 RX-L and 2014 RX
  211. 2022 RX350 Driver seat Cooling not working.
  212. RX350 F Sport / red colored vents??
  213. Emergency call unable to perform maintenance inspection
  214. 2020 rx350 vs 2018 rx450h
  215. 2018 RX 350 Radar Cruise control and PCS go out at the same time
  216. Media source removal from navigation
  217. Need to replace fuel pump again with 23le03?
  218. Knee Hitting Start Button
  219. Anyone have circuit diagrams of the power window system?
  220. Outside temperature display broken
  221. 2017 RX350 Muffled Call Audio Issue
  222. 2021 Lexus RX Heads Up Display issues?
  223. 2017 RX Front HUB & Bearings/ FWD base model
  224. 2021 models have more issues?
  225. Would the 2023 21" R500 wheels fit Gen 4 RXs?
  226. I wanted to love this car, but…
  227. Front Struts
  228. Strut mount bearing!?!?!
  229. Intake manifold Seeps Oil
  230. 4th-gen RX key fob survives a washing machine experience
  231. AC Condenser replacement, oil amount?
  232. Which Year/ Rx Model would you recommend buying?
  233. Japan grille badge for RX350L
  234. Door Rattle and Wind Noise
  235. Question on AWD lock mode on 2021 RX350 F Sport
  236. gargling/bubbling noise under rear seat
  237. Noise From Trunk Area 2022
  238. 2022 rx350 cpo or a 23 350 hybrid?
  239. Am I wrong (questionable LCPO inspection)?
  240. RX350 - Aniline Leather finish locations?
  241. Starter replacement questions
  242. High Pressure Fuel Pump recall
  243. Rear Seat Back Release Lever not working
  244. Dodged a bullet with a 4th Gen RX?
  245. 2021 RX350 Anti Theft System
  246. Brake Paddle Bounces Back.
  247. Hole in hood insulator
  248. Premium/executive models missing HUD and ML?
  249. Rear view mirror won’t stay tilted up?
  250. Parking Sensor Question.......
