Vibration while accelerating
Old Feb 8, 2024 | 10:36 PM
supratreo's Avatar
supratreo
Default Vibration while accelerating
hi, i have a 2017 2wd and recently it started vibrating while accelerating ONLY. i replaced the PS axle and it fixed the issue a little at lower speed (up to 60) but still vibrates at 60+ and gets worse the faster you go. I'm getting ready to replace the DS axle but wanted to see if anyone here had experience with this issue. i've done a lot of searching and it seemed to be a problem with the 2 and 3RX, but couldn't find and topics for the 4RX. i checked all suspension components (bearings, joints, struts...) and everything is solid. car has 105K on it.
thank you
Old Feb 9, 2024 | 01:50 AM
jcg0324's Avatar
jcg0324
Other items you can check: Drive shaft and worn u-joints or inner cv joints. Other possibilities would be loose or broken motor or tranny mounts.
Old Feb 9, 2024 | 06:08 AM
autotech13's Avatar
autotech13
Check wheel balance.
Old Feb 9, 2024 | 03:35 PM
supratreo's Avatar
supratreo
the car is 2wd so no DS or U joints. i did check wheel balance but vibration only when accelerating wouldn't really be a balance issue anyway. all mounts are good also.
Old Feb 9, 2024 | 03:36 PM
supratreo's Avatar
supratreo
i should also mention, to rule out any tire/wheel issue i swapped wheels/tires with another vehicle and the issue did not go away.
Old Feb 15, 2024 | 09:35 AM
RCA350's Avatar
RCA350
6th Gear
thank you
I'm taking car in Monday. Starting with Differential Fluid replacement. Will look for shaviings on on magnet on drain plug to see if gears need replacing. 2016 RX350 with 80k miles.
Old Feb 15, 2024 | 05:43 PM
supratreo's Avatar
supratreo
your having the same issue?
Old Feb 16, 2024 | 06:10 AM
Quantum501's Avatar
Quantum501
CCN just released this video.
May not apply to these situations, but who knows....
Old Feb 16, 2024 | 09:14 AM
supratreo's Avatar
supratreo
great video. thank you. i order the axle today to i'll report back after i replace it.
Old Feb 19, 2024 | 07:29 PM
trunghn1988's Avatar
trunghn1988
1st Gear
I encountered identical vibration issues on the driver's side when accelerating beyond 50-60 mph. Despite having the tires balanced, the problem persisted. I suspected there might be issues with the driver axle. Seeking a resolution, I visited the Southern California dealer, where their master technician spent four hours diagnosing the problem and confirmed it was indeed an axle issue on the driver's side. I would recommend to have someone drive the car with you to see which side do you experienced vibration and then fix the axel on that side.
Old Feb 19, 2024 | 08:30 PM
supratreo's Avatar
supratreo
well i've already done the PS and the DS showed up today to i'll swap and report back.
Old Feb 19, 2024 | 08:52 PM
15RX98422's Avatar
15RX98422
Swap front 2 wheels with back 2. Check very closely for bent rims. Check all tires for bubble. Check for anything loose or broker in front of car.
Old Feb 20, 2024 | 01:49 PM
supratreo's Avatar
supratreo
ive tried that and have also swapped wheels with another vehicle.
Old Feb 21, 2024 | 12:26 PM
GS4_Fiend's Avatar
GS4_Fiend
thank you
How many miles do you have? Quite early for the axles to become defective.
Old Mar 2, 2024 | 04:06 PM
supratreo's Avatar
supratreo
Just an update. Finally got around to replacing the left axle and that solved the issue. now i just need to figure out where this vibration/hum is coming from right around 2000rpm. been doing it since new, i knew i should have taken it in then.
