Question on cabin temperature display
Old Nov 2, 2023 | 02:35 PM
A440's Avatar
A440
Default Question on cabin temperature display
Is it normal for only one cabin temperature to show when only the driver is in the car? The passenger side doesn't show unless a passenger is seated in the vehicle.
Old Nov 2, 2023 | 02:41 PM
NotAFiat's Avatar
NotAFiat
Default Is It Normal?
My 2021 RX does the same thing. No temperature setting is shown on the passenger side if it isn't occupied.
Old Nov 2, 2023 | 04:11 PM
A440's Avatar
A440
I guess I should have read the manual: S-FLOW mode In S-FLOW mode, priority for the airflow is given to the front seats, reducing the airflow and air conditioning effect on the rear seats. If a passenger is not detected in the front passenger seat, priority for the airflow will be given to the driver's seat only. In this case, the temperature indicator for the front passenger side will turn off. S-FLOW mode will be activated automatically according to the set temperature, outside temperature, etc. (P. 502)
Old Feb 28, 2025 | 03:52 AM
Renoops's Avatar
Renoops
7th Gear
Thank you for your reply. Now I need to figure out a way to fix this issue.
Old Feb 28, 2025 | 06:04 AM
autotech13's Avatar
autotech13
Dude! There is no way to fix, it's part of the vehicle design!
Old Feb 28, 2025 | 06:16 AM
Renoops's Avatar
Renoops
7th Gear
"If a passenger is not detected in the front passenger seat, priority for the airflow will be given to the driver's seat only. In this case, the temperature indicator for the front passenger side will turn off"
The temperature display on the passenger side should not be lit unless someone is sitting in the passenger seat. That's not part of the design. I'm looking for a solution so that it only comes on when it is supposed to come on.
Old Feb 28, 2025 | 07:19 AM
shq's Avatar
shq
It is not a "part of the vehicle design" per se, but rather S-Flow settings (as mentioned above). Turn the S-Flow off and you won't have that issue anymore.
Old Feb 28, 2025 | 07:30 AM
Renoops's Avatar
Renoops
7th Gear
I've tried that but unfortunately it didn't resolve the issue. The passenger side temp display comes on during one trip and then 30 minutes later it'll be off during another trip, without me having to press any buttons. There's no rhyme or reason for when the light comes on.
I'm almost certain it's going to be related to another issue. The heated seat button is said for auto. It should not activate unless someone is sitting in the passenger seat. But it's not working correctly either.
Old Feb 28, 2025 | 12:55 PM
PhxBill's Avatar
PhxBill
The passenger seat sensor is wonky, it sounds like. Wasn’t that part of the airbag recall issue?
Jaewoq
Aug 27, 2023 04:34 PM
pappy97
Jul 28, 2018 12:15 AM
chivasc
Jun 15, 2010 09:57 AM
qewani1
Jan 25, 2010 06:43 AM
