RX - 4th Gen Tail Light Replacement
Old Oct 29, 2023 | 09:35 AM
MMcG's Avatar
MMcG
3rd Gear
Default RX - 4th Gen Tail Light Replacement
I am trying to replace the driver-side tail light in the rear lift gate for a 2017 RX350. This requires removing the “Rear Liftgate Molding Garnish” (the piece below the window with the Lexus “L” logo). The top part which abuts the rear window comes away easily but the lower, chrome piece seems pretty locked in. I don’t want to damage it by pulling too hard. Could someone share how to remove that piece? Thank you!
Old Oct 30, 2023 | 07:12 PM
IntrinoX's Avatar
IntrinoX
It's bolted from the inside under the carpet panel. Once you remove that, you'll find 4 bolts that hold that entire trunk garnish to gain access to the tail lamps.
Old Oct 30, 2023 | 07:21 PM
MMcG's Avatar
MMcG
3rd Gear
Thank you! Just to clarify the locations of the bolts -- are they along the lower portion (chrome portion) of the garnish?
Old Nov 3, 2023 | 04:46 AM
IntrinoX's Avatar
IntrinoX
I do not recall exactly but they’re black bolts.
Hope the diagrams help!
Old Nov 6, 2023 | 11:15 AM
MMcG's Avatar
MMcG
3rd Gear
Default Thank you!!!!!!!!
This is just what I needed!
Old Nov 6, 2023 | 01:10 PM
IntrinoX's Avatar
IntrinoX
For sure! Let me know if you need anything else!
Old Dec 25, 2024 | 09:30 AM
kosanmr2's Avatar
kosanmr2
1st Gear
I'm having problems removing the carpet liner. I removed the obviously panels (upper and lower), dis-connected a couple light cover assemblies. Do I just yank out the sucker? There's video of a Lexus Master Technicaan removing it from a 2010-2015 Lexus RX350 and there's a couple covers to open where I need to remove a couple 10mm nuts. But, I don't see that in this model. Afraid to just yank it out.
Would you be able to provide some guidance? i think once I remove that, should be good to go.
rvlexus
Apr 16, 2023 09:28 AM
AndertD
Aug 4, 2021 12:24 PM
draco
RX - 3rd Gen (2010-2015)
Sep 2, 2020 05:26 AM
emjaybee
Apr 7, 2019 10:34 PM
10000rpms
RX - 4th Gen (2016-2022)
Sep 23, 2017 10:10 AM
