Rx350-2020 Strange warning messages
Old Jan 1, 2024 | 10:01 AM
johnjkowalski's Avatar
johnjkowalski
2nd gear
Default Rx350-2020 Strange warning messages
Happy New Year everyone!
I started my 2020 RX350 (36,000 miles) this morning and the engine ran rough, the check engine light flashed, and a warning popped stating that the 4 WD system malfunctioned and was being deactivated. After about 10 seconds everything returned to normal. Has anyone had this experience?
Old Jan 1, 2024 | 10:51 AM
ravenuer's Avatar
ravenuer
Was your car in a garage or outside? If outside, heavy rain, snow, very cold? I ask that because those things could temporarily affect various sensors.
Old Jan 1, 2024 | 01:38 PM
Volley's Avatar
Volley
It may have stored a code to the on-board diagnostic system. If you don't have access to a code reader, Autozone and most of the similar auto parts chains will read them for free. Don't erase it if you do find a code as it will be useful if you need a repair. If you don't find a code it was likely a transient problem that you may not see again. Also, there is a good chance based on your vehicle year and the weather that your battery is on the way out and the act of starting the car dropped the voltage below what was needed for a particular sensor. Again, the auto chains will be able to test your battery.
Old Jan 1, 2024 | 02:51 PM
ravenuer's Avatar
ravenuer
Good point about the battery. Didn't think of that.
Old Jan 1, 2024 | 04:43 PM
johnjkowalski
2nd gear
The car was parked in an attached garage last night. The temperature in the garage was in the 40's. This morning i drove the car about 20 miles. I then parked it outside, temps in the 30's. The car started and ran just fine when I started it at about 7:00 pm. Maybe the problem is a one time issue. Next time the car is in for service I'll have the battery checked.
Thanks for everyone's input.
Old Jan 2, 2024 | 05:20 AM
ravenuer's Avatar
ravenuer
Good luck.
Gronemus
Jan 23, 2019 06:43 PM
wrogers
Apr 24, 2008 06:27 PM
LexusTime2
Jan 20, 2007 01:07 PM
JsN
Jan 24, 2005 12:49 AM
mastella
Oct 8, 2004 01:55 PM
