Wheels set up question
Old Oct 18, 2023 | 02:13 PM
digitalrx350's Avatar
digitalrx350
Default Wheels set up question
Hi guys,
I recently picked up a used set of wheels/tires
265/30/22 Front
315/30/22 Rear
anyone know if this set up is too thin for our car? Tires are brand new so I hope not to buy new ones
Thanks in advance
Old Oct 19, 2023 | 08:16 PM
IntrinoX's Avatar
IntrinoX
Awfully too wide.
Old Oct 20, 2023 | 12:41 AM
jcg0324's Avatar
jcg0324
I suspect those tires (10.5 inches wide) may rub something in the front when turned all the way left or right. You won't know for sure until you mount them and try it. If they rub on something then it won't matter how thin they are.
Old Oct 20, 2023 | 04:37 AM
JSracer's Avatar
JSracer
too thin??
is your rx awd or 2wd ?? was the set on a rx or similar ??
(not sure how sensitive toy/lexus is to front to rear difference for abs/trac and other speed related systems)
front to rear
vs stock
https://www.tacomaworld.com/tirecalc...0r22-265-30r22
https://www.tacomaworld.com/tirecalc...5r20-315-30r22
Old Oct 23, 2023 | 06:38 AM
digitalrx350
Hey guys, thank for responding
I found the wheels/tires thread in here so I figured it out
I will need 265/40/22 front and 295/35/22 rear
Old Oct 24, 2023 | 08:25 AM
FirstWorldProblems's Avatar
FirstWorldProblems
5th Gear
Wheel specs are very important for fitment. Width and Offset will ultimately determine if they will fit.
BrentD86
RX - 5th Gen (2023-present)
77
Oct 29, 2023 06:58 PM
WaitUpGuys
Dec 30, 2022 07:21 PM
arf1410
NX - 1st Gen (2015-2021)
Jan 7, 2022 08:28 AM
Supraman16
IS F (2008-2014)
Nov 20, 2021 10:47 AM
Twisties88
Apr 18, 2013 10:27 PM
