- LS460 engine air filters
- 2007 LS Trunk will not close
- DIY: Nearly FREE Loose Glove Box Fix
- wheels - is bigger better or is motion of the ocean?
- Move from 2008 to 2012?
- Paint flaking off rims
- LS460 navigation problem---urgent help needed (unread in 3 days, must not be urgent!)
- Update for iVic-i fixes some bugs but not all
- CPO 2008 LS460L. 56,000 miles. $31K. Should I take this? Or haggle more? Need help!
- What is unusual with this steering wheel ?
- puddle lights not turning on when key fob is in proximity
- Recalls by serial numbers
- Tire pressure system
- ASL microphone locations..
- Right front speed sensor
- 3rd party extended warranties
- What should I aim to pay a private party? 2008 LS460L. Expert advice needed!!
- First aid kit tip
- CPO '09 LS460 - Is it me or the car?
- 2008 ML vs 2010 non ML
- Value of Executive Package on used 460's ?
- Lexus LS 460 Odometer Reading
- Headlight question
- My New (To Me) LS
- Buy 460 with Air Suspension or not?
- Good deal on 2011 Lexus LS 460 L w/Exec package?
- Keys locked in car
- what kind of LS460 is this? and are they rare
- Upgraded ML stereo
- 9005 or 9006 fogl lamps?
- Need advice on price. Buying used LS460L
- Trunk deoesn't open all the way - Normal??
- I pulled the trigger on Saturday! Many thanks to all of you.
- Advice on ls460l deal
- Early Ls460s how are they holding up?
- Maintenance plans, Oil Change mileage??
- Test drive: what to look for or pay attention to ?
- New member
- LS430 to LS460
- ML audio in 07/08 search yea or nay?
- 2008 Brake Caliper Bolts
- Complete Detailing of my Obsidian LS with PICS
- Save those pinch welds when floor jacking
- Intro & Exhaust Question
- Would you buy this?
- 20x8.5 & 20x10
- Advice on this deal
- New member,
- New member , my 2010 Ls460 smoky granite mica
- LS460 6 month Service
- LS460 F Sport
- First squeal, now rattle.
- My 07 LS460 is ready for new wheels and tires
- brake pad sensors
- Factory clear film on the headlamps ??
- 2008 Ls460 L question
- Cheap Pennzoil Synth ($1/qt)
- Rear Window sunscreen rattle
- My Super Fly New Ride
- ls460 music screen
- Question about newly purchased 2010 ls460 swb...
- LED DRL DIY with pics
- 2010-2014 F Sport 19" OEM Wheels on 2008 LS?
- Separate power amp for sub
- LS purchase help
- Help: Headrest Removal
- Oil Drain bolt snapped!
- Costco Tire Dilemma - Help!
- AFS Fuse Location
- 19" or 20" Rims
- :D $12 worth of light fun! :D
- Feeling like a special customer, what has your dealer done for you.
- Lexus select
- lights around Nav & stereo system
- LS460 L bad starter or battery or...
- LS460L just purchased 2007 question
- Just picked up a '10 CPO LS460 AWD
- Good indy in Jacksonville, FL?
- Need help with wheels
- Loud squeal coming from brakes.
- air conditioning filters (they are two, right?)
- Plastic Underside cover - do I really need it?
- 2013/2014 ls460 fsport ultra white
- Shaking at 70-75mph!!
- Bluetooth streaming from iphone 5s
- What Causes Brake Rotors to Crack Like This?
- Dash noise
- New car 2010 ls460 sport
- Check VGRS Check VSC warning Light HELP!
- Little bit of light work tonight
- Headlight low beam issue
- Trade LS 430 Sport for LS 460 Sport
- Parking Brake Not Available, HELP!
- Key remote & Navigation question
- front bumper cover replacement.
- Philips LED/DRL
- Just got my car !
- Grill Plasticote DIY with PICS
- ls460 steering difference
- Help! LS460 climate and ML audio/nav problems-Dealer says replace
- remote touch interface Vs the old touchscreen style
- Aero Stabilizing Fins Wind Noise Fix DIY w pics
- High Mounted Stop Lamp Replacement?
- Parallel parking - how good it is?
- PS Module Install DIY with pics
- 18.3 MPG in city. Is this below normal?
- LS460 abs vsc system problem
- Protective Film
- Tire rotation
- Wheel Size
- Knocking / Diesel noise
- Nav Screen Scratches
- Best switch location for Prestigious Society Bypass?
- What is your window tint level?
- wattage for our fog lights
- Looking to buy 2007 LS460
- Ls430 vs ls460
- Ultra Racing Subframe braces
- Thoughts accepted
- Headlight timer
- oil change
- Traded my LS460 for an ISF !! Farewell to the LS crew !!
- Window question
- Add Lexus Link to 09?
- Oil Change DIY - Is a SST absolutely required?
- Tips on keeping a battery from going dead...
- ls460 lsd?
- Is there an easy way to refill the transmission?
- OEM Battery CCA'S
- Car ramps
- 2010 LS460 Variable geer ratio steering recall question
- Which LED running lights
- 2011 LS460 - She's finally home!
- 2010 nike light replacement
- How long is the build time for my car ?
- 2010 ls battery different?
- ls 460 with 150k miles?
- Brembo Brakes Squeel Lexus free repair
- Question for LS460 owners
- Another Newbie to CL
- Car cover
- New Build Threads area for LS460 members
- Garage door opener distance
- So I found a really cheap vendor for the LS460/600 Data System... thoughts?
- Gas Gauge Linearity
- Wheel and 3m wrap question...
- Extending CPO Warranty
- Downshift rough when slowing
- Removal of dash under sterring wheel 2011 LS
- LS460_Downshift/Passing Gear/Kick-Down Hesitation
- New to the Club!
- Car Wash Issue with AWD
- 2007 LS460 Jerky/hard shifting problems
- VSC system issue and idle issue 2008 ls460 46k miles?
- Ls 460 Subwoofer Replacement
- DIY Spark Plug Replacment
- Any issues to look for on 2010 LS460 rwd?
- brake failure or spontaneous acceleration?
- Switch above gas pedal
- Wire from engine compartment
- anyone install Megan mid pipes? (not mufflers)
- F sport air intake sound generator DIY install (10 minutes)
- LS460 transmission downshift hesitation
- Does the compass in the rear view mirror a standard option?
- How Many Miles Per Tank On Your LS 460L?
- Service Mode for 2013 and Newer
- Buying Decision, 07 or 08
- 10 days later: My impressions
- Auto Couture Kit
- LS purchase / 2009 or 2010 or 2011
- Malfunction or normal?
- 2008 LS need new starter
- Extended warranty needed for 2007 LS 460 L?
- Over 100,000 on your LS460?
- Trunk Opening Problems
- Avest/SpecD LS460 LED Tail Lights
- Painted Calipers - Flame Suit On.
- How many cars in each color each year?
- Remote Start LS460 for $221 installed
- Brembo Brakes how to stop the squeal
- Greeting
- The LS460 is extremely dangerous. Here's why...
- Coilovers recommendation needed
- 2010 LS460 CPO Price
- New to CL
- New Member
- Help!! 2010 LS460 Bumper Cover not fitting correctly
- LS 460/600h F SPORT Factory PKG Air Intake Sound Generator
- Has anyone test fitted or used the 2GS Sport Design fender pieces?
- iVici AND Prestigioussociety
- I fixed the ticking in my LS460L
- ls460 2007 wont start
- Kumho tires cracking on the inner sidewall
- Any issues on a '10 LS460 sport?
- Air Shock/Struts problem on 2010 LS460L AWD
- Performance Mod List? (ie: not wheels and bodykits, lol)
- 2010+LS460 or E350??
- Wheel Offsets - What do I need to know?
- First Oil Change at Dealer
- Brake Actuator Help
- 07 LS 460 Trunk issue
- 07 LS Headlamp washer assembly ripped out at car wash!?!?!?
- Spotty seat heaters
- Anyone use Autolite Iridium plugs?
- LS460L to be delivered tomorrow. Couple of questions for you.
- Which Color Combination
- How much would a new parted out LS460 be worth?
- 07 LS460 Upper & Lower control arm bushings replacement
- ls460 awd without air suspension
- LKA at night
- 07 Ls and 13 Ls suspension
- New Tires/Wheels for 14 F-Sport
- New Primacy MXM4's and battery tray
- LS suspension changable.
- iPod Classic losing contact
- Best Car Ever
- Best phone mount for the LS (merged threads)
- Before and after pics of my new ride. Wheels/tires
- Looking for 19" OEM sport wheels
- 2009 or 2010(and above) Model??
- ethanol in the gas
- Did I Get A Good Deal And What To Look For Going Forward
- Loud 08 LS460L Sport!!!
- Programming a new Smart Card fails
- Matte finish wod grain trim
- For my LS Family running 22" wheels
- Back Mirror cover HELP!
- General braking question - possibly brake shim related?
- New K-Break Bodykit for 07-09 LS460
- New member - kind of.
- 2014 Lexus LS Brochue
- Hardwired Radar Detector - DIY mirror Mount
- LS V8 efficency opinion
- unique wood trim
- DVD Formats
- Should I buy a warranty?
- 2010 LS 460 Seat Care
- Oil Pan plug threads stripped by dealer
- New to me LS460 review/comparison
- 2008 LS460L starting problems
- About to be a new owner. Question.
- New Member - Happy New Year
- LS 460 2007 Radio problem
- looking to buy
- 2010 LS 460 Care & Handling
- New Member - Looking forward to less drama than my BMW
- Long Term Electronics Reliability
- high pitch sound with heat on
- Blue tooth phone questions
- LS460L Exec Extended Warranty
