Help: Headrest Removal
Yes, I did do a search and only found 1 thread regarding this back in 2007.
1. Any current info on how to remove the headrest?
2. Is it compatible with an after market headrest?
Any help is appreciated.
1)Make sure you slide the seat all the way back and the headrest supposed to move up too.
2)Follow the be link how to remove the headrest.
https://www.clublexus.com/forums/ls4...r-ls460-l.html
3)Just make sure the diameter and the length of the pole is the same.I think you need to take it to the machine shop and custom it. If not the same dimension, the headrest will not move up and down. But, if you don't care if the headrest moves up and down you can just disconnect the harness.
tuterz
Apr 19, 2021 08:23 AM
