Check VGRS Check VSC warning Light HELP!
Old Feb 24, 2014 | 11:41 AM
isaaaaaacc's Avatar
isaaaaaacc
Default Check VGRS Check VSC warning Light HELP!
Just picked up an 2007 LS460L about 2 weeks ago. It is out of warranty so I am scared of what might the price might be to fix this. So the problem:
4 Lights came on the other day.
1x Check VGRS System
1x Check VSC
1x Check engine light
1x Squiggly line
Currently the car drives fine. Doesn't seem to have any problems whatsoever. I did some research and some people said it might be a battery issue, or perhaps a gas cap issue. I find it weird to see how those two can throw it off. I will be replacing the battery just to check. Just wondering if anyone else out there has had the same issue and hopefully it could be an easy fix.
Also, There was a recall on the VGRS system for the ls460 but only the 09 10 model. Why is that? Would i be able to fix mine under that recall even though my car is a 2007?
Old Feb 24, 2014 | 11:57 AM
rominl's Avatar
rominl
exclusive matchup
did you add gas recently? a loose gas cap WILL trigger CEL and possibly some of those lights. in my experience that's one of the most common situations where people suddenly see those lights.
i hope it's nothing major
recall only applies on the specific years. if yours not included then they will not apply it
Old Feb 24, 2014 | 12:14 PM
Aristo300's Avatar
Aristo300
I'm not normally one to be the "search function" Police, but there's so many topics on this problem. There's probably two other threads regarding the same issue on the 1st page here.
Old Feb 24, 2014 | 02:42 PM
1Putt's Avatar
1Putt
For me was a mis-threaded gas cap that seemed to trigger some of these lights
Old Feb 24, 2014 | 03:22 PM
isaaaaaacc's Avatar
isaaaaaacc
Thanks 1putt. definitely going to try that.
rominil. The light actually came on near the end of full tank. Probabaly pumped gas around a week ago. I dont see how a gas cap wil throw off the VGRS light tho. since it deals with steering. but i will try it out anyways.
Old Feb 24, 2014 | 05:53 PM
Tee's Avatar
Tee
Please use the search feature and add to existing thread/s already discussing this topic, here is one recent thread below.
https://www.clublexus.com/forums/ls4...m-problem.html
Also more threads..
https://www.clublexus.com/forums/sea...archid=3137419
Kazaxat
May 29, 2020 12:09 PM
kalali
RX - 1st Gen (1999-2003)
13
Oct 30, 2010 02:29 PM
penone
Oct 10, 2010 06:57 PM
Mikey2007
May 28, 2010 01:39 PM
IS350ISFUN
May 3, 2006 03:25 PM
