- throttle position sensor
- rx300 tuneup
- Car wont stay on
- Coolant leaking on 2002 RX300
- cel
- WTK: RX300 Compatible Transmissions?
- Auto-RX
- 5W/40 Oil ok to use?
- Happy thanksgiving!!!!!!!
- RX Awards
- my moms 2001 lexus rx300 needs a new transmission
- The Gear shift lamp Out where we change gears
- WOW!! 1st time coming in here
- Were the glass AWD trannies fixed in 2002 models
- Anti lock Brake Issue
- Pass side mirror assembly replacement
- custom rims & tires
- A/F O2 P1130 P1150 Check engine vsc etc
- sludge! ticking time bomb?
- Unknown beeping noise from rear
- Starting problem (have to step on the gas)
- buy power antenna: broken
- back hatch wont stay open when its ridiculously cold
- First Time on Board -- Transmission?
- dead transmission! Highlander trans different
- 22" Rims
- Best replacement speaker
- Lexus rx300 2001 wont start.. Please Help!
- Where do I install the rod on my lock actuator
- Transmission - timing belt problems...
- where to find clear side markers
- Unknown oil Leak from bottom of Engine
- Code P1133 and P0171 for Lexus RX 300
- How to lockcentral diff
- Front Arm Rest Removal-How?
- Exhaust Leak front of motor?
- new battery causing alarm to go off
- Timing belt should I or shouldn't I
- High RPM Ping
- Which motors can I use??
- no power to cigarette lighter and side mirror adjuster?
- Cruise Control ECU Replacement
- P0440, P0441, P0446 and P1150
- Cracked Exhaust, Manifold, brown tranny fluid and more
- tilted steering after tire rotation
- When should you replace RX300 springs
- Great.. Knock sensor
- Rear runner light fire
- False "Rear Bulb Failure" Warning
- Headlight "lense" Removal?
- Wants to change engine main seal & bushings for transfer case
- VSC/Engine light & codes P1135 & P1150
- 99 RX Side Air Bag did not deploy
- p0022 on neighbors Highlander 2003
- RX300 Speaker Installation
- Rear Spoiler Installation / DIY???
- replaced my washer fluid pump
- Lower Control Arms - help
- Transmission pan gasket
- Radio Reception
- RX300 Storage In Arizona..Help!!
- Anyone know where to buy 3rd High Mount LED Brake Light?
- sneak peek / teaser pics.
- Please HELP! Just purchased 99 RX300, ECT/SNOW Light Dead
- Toyota coolant
- RX 300 Engine Codes
- When 7440 bulbs are not my rear blinkers!
- RX 300 Trans. Filter
- Headlights
- Rear Hatch Gate Issues
- Marvel mystery oil
- Tranny question
- Tail light exchange
- my lexus rx300 starts choking when I push the gas pedal
- engine codes: P0171, P0300, P0136 and P1153
- need maintenance schedule
- ** Did your signature image stop working? Here's how to fix it! **
- Does this look like sludge?
- odd noise coming from the glove box
- '99 RX300 Squeaky Driver's Seat
- Is Rims On Rx
- air intake clip broke...
- 6,000 rpm yesterday!
- The viscous coupling
- Looking for a "Rod Millen" front bull bar for RX300
- is there a better AC cabin air filter than the original Toyota filter?
- how do I know if my RX300's brake pads are worn out?
- HELP! 3 Problems: Lock Broken, Aux Cable, Steering Wheel
- Heater doesn/t work
- spark plug wires
- Informal Timing Belt Failure Survey.....
- Original Timing Belts Mileage.......
- Cheap blank keys (no cutting) <$4USD
- timing belt change
- hatchback panel fasteners
- does the AWD RX300 have front & rear differential and transfer case?
- Manifold Gaskets
- Air filter
- led lights for interior 01 rx300
- p1150 code
- Time to sell my 99 rx300
- RX paint
- Is the 2000 RX300 stereo RDS compatible?
- test thread
- #5 Cyl Misfire!!!!!
- NAV Issue
- Brake pads and rotors turned - success! (part 2)
- Jack support points?
- Transmission drain plug ruined - how to remove?
- P0440 Engine Code
- Alt/AC comp belt
- Finally, it comes out, It's OEM Projector Housing
- Front Suspension Noise
- 2000 overhead console removal
- Location of Fog Light Bulbs?
- Heater blowing cold air
- Door lock actuator
- RX-300 versus BMW X5
- winter blend fuel
- Rebuilding the suspension - do I need these?
- Starting quirk shifter/ignition switch?
- Atf Filter Change W/o Small Black O Ring
- switching out brake rotors from front to back, what do you think?
- Need help! Clicking sound when acceleration
- Noise under my feet when I Accelerate
- Wipers work No Fluid
- vacuum problem
- Gas pedal sticking
- 2001 rx300 won't stay running
- which would win; RX300 or IS300?
- Door Lock
- LS460 Projector Retrofit into my 03 RX300; Pictures!!
- Brake light on...
- Parking brake light on
- Bosch Platinum Ir Fusion +4 plugs Part # 4501 issues??
- New Mod Possible...
- List of RX300 DIYs
- Power steering fluid removal and refill
- driver side front side marker always out
- Tail light and Windshield fluid spray
- RX surprise
- 2001 Rx 300...did I Get Ripped Off???
- XM Satellite Radio Installation
- 1999 RX300 Center Console - Compatible Years
- How do I remove lower body cladding?
- P1150
- How often should I change the serpentine belt?
- vsc,engine light
- Problem starting engine
- DRL daytime running light problems with CDN spec 2000 RX300
- Tranny locked?! Help please!
- no door pin switches or electric door locks without ignition
- Spark plug replacement
- Solution to the VSC and TracOff issue
- Strange problem after replacing battery
- Trailer hitch
- Radio problem - whats on RAD1 circuit
- Fuel Gauge misreading - disconnected battery
- Leaking rear strut
- RX Radio
- 25hp D-boost Performance Chip Lexus Rx 300 330 350 400
- New member, Few ?s
- Smoked Tinted Tails on RX300
- Wheel wobble
- Gear Selector Console Illumination
- Replacement keys from toy-lex: experience
- rx-300 2001 Water in cabin
- DIY Removing Transmission
- P1155 Help - Pictures needed for "The Hose"
- Which ATF to use?
- Help!!!! with VSC and Trac Off light, please..
- Will ES 350 wheels fit the RX?
- Season of the Love Bugs..I need a bra for our unit
- Headers
- Blower/Fan not working
- Rx300 Engine Oil Light On After 1000 Km continious travel (Speeds over 120 KMPH)
- RX300 transmission service
- New to the forums
- Replacement Master Key
- slotted/drilled rotors minor braking pulsations
- Thoughts on an alternator ?
- Stripped Oil Drain Pan
- 99 RX300 with Nakamichi questions
- CRC M.A.F cleaner
- Front Transfer Case Leaks
- Where to purchase rear hatch cover
- Another transmission failure?................
- magnaflow exhaust
- Nav. "No Disk Detected"
- 2001 RX 300 Spoiler
- Front Differential Leaks Fluid
- Rear Driving Lights Issue- Install of part
- I Need Charcoal Canister RX300 parted out or good deal on new.
- 45k Service
- RX300 instrument cluster lights don't dim
- Passenger tire or SUV tire
- CD Player
- Navi stop working... No Disc deteced!!!
- antenna stopped working
- best tire pressure?
- 90k Service - Ripped off or decent
- 2001 RX300 question
- How long have you been using Amsoil for ATF?
- Low Speed Brake Squeal, I need advice
- Top-of-the-roof Satellite Radio Installation
- Battery Replaced now VSC,TRAC OFF and Check Engine Light is on
- Thanks for all your inputs
- What is Best Method to Repair Leather Seat Tear
- 2001 RX300 Brake Pad Orientation What is Right?
- fuel additives do you use one?
- Jerking/Hesitating and Misfire
- Odd Problem
- stupid starting problem
- Tired of MIL.. with P0446 code..I want to bypass
- Glove box rattle TSBs
- Royal Purple ATF...Comparable to Amsoil?
- RX300 Cross bars
- footrest
- 1999 RX300 power steering question
- is a 1999 rx300 a good buy?
- Oil Filter Change
- Starting problems, IACV again maybe?
- Security Light on Solid Red All the Time
- Need help - rear brake disks don't want to come off
- oxygen sensor help please
- Need advice - rear brake caliper frozen with sliding pin
- Malfunction indicator lamp, VSC, and Track Off lights are on
- Error 2 code on CD changer.
- A/C only works on driver's side
- OMG 3300 big ones
- Petrol 18x8 offset 20 w/ 235x55x18
- 1 Year or 25,000 mile oil change..Amsoil?
- Need Info...
- Window Problems
- A/c And Fan Help! Enthusiast Please Advise ! Thanks!
- RX300 what to look for?
- trans axle 1st to 2nd
- Strange clicking noise inside dash/behind radio/CD unit
- Car Alarms what do you use?
- Lexus Short Key vs. Long Key
- Coolant Flush
- Some intake modifications
- Lexus Service department not in my area?
- How Do I check Vacuum Switching Valve for the charcoal canister
- Is my battery about to go?
- Amplifier Assembly Harness
- Brake Reservoir Has Any Sensor ?
- O.D off
- Power Out???
