- Will JDM Rear Taillights/Trunk lights fit on a USDM 2006 RX330?
- Right side speakers not working 2005 RX330
- Retracting steering wheel
- air shocks
- new to RX
- Gas Door Hinge
- Thinking about a 2008 RX400h
- Console differences? Which is which?
- Installed Vaistech SL3B yesterday and tested it vs CD
- Should i buy 2005 RX 330, 14000 miles for $10K
- Disable auto re-lock function, please...I'm panicked.
- anyone know how a diff breather valve look like?
- #3 cylinder code of P0303
- Body side molding replacement
- Error 4 revisited--request help from any and all experts!!
- Changing inner door panel driverside...
- Please help - What engine oil to replace recommended
- A mysterious suv showed up in our garage:)
- '09 RX Radio Security Code?
- navigation system
- windshield wiper replacements 2009 rx30
- Transfer Case Leak 2004 RX 330
- 07 RX 350 Lights
- Replacing rear bearing
- Automatic Window Up Mod
- Unlink headlight washers from windshield washer
- VICTORY!!!! Fianlly Solved an ABS problem.
- Sounds like a diesel when started
- Transmission slipping
- Shifter skips "D"...trans won't shift to 5th
- No way to open rear trunk manually?
- Can I Obtain A Build Sheet For Our Lexus?
- 2006 RX400h Aftermarket Wheels Offset
- New to Lexus and forums
- From Toyota Tacoma to a Lexus RX350
- Heat only coming from Driver's side, but Cold A/C works on both
- 08 RX350 AWD Transfer Case and Rear Differetial fluid change
- Cruise range of miles on computer
- A question for those that have painted headlights
- 2006 RX 330 Check Engine & VSC light on
- Dash pad
- Cracked dash
- AC occasionally doesn't work on 09
- 2009 RX 350 Rear Hub Replacement
- Are There Replaceable Batteries in the 2007 RX350 Tire Pressure Monitors?
- Timing belt plus
- Brake line flush/gasket repair
- Rear Hatch Beep Be Gone Please!
- TSB for RX330/RX350 rattle
- 18 watt backup bulbs
- Tail Light Picture Request
- Pulled The Trigger Today on an 09 Pebble Beach
- 2005 rx330
- 2004 - Fender "Inner-Liners"
- 2007 RX 400h lost power, even with new IPM
- Need Help Considering buying 09 tomorrow, 8/30
- Valve clearance
- Life expectancy?
- 2nd vs 3rd generation styling/design
- Water under carpet mystery
- Side mirror looks like it is peeling?
- Should I Buy?
- 09 Rx350 Power lock issue...
- Steering Gear Replacement and Spark Plugs/waterpump and transmission cooler
- RX330 Purchase and new sound system
- 2004 Rx 330 Suspension Rattle with Air
- Strange Noise - Only when AC is on
- Installed new struts, axles, brakes (***pics***)
- Auto Shop in L.A. 2005 RX330
- Sound System Problem! Please any help!!
- 2004 rx 330 steering rack questions.
- 19 mm Rear sway/roll bar on the rear of my RX
- Anyone have remote start on their 330?
- RX330 Power Mirror Switch Erratic
- Is there any market for a stock 2004 RX330 No-ML non_Nav Radio?
- defective tire wrench?
- Installing Puddle Lights on 2nd Generation RX
- Help Identifying Sunshade / Cargo Cover
- cd-r not working in rx400h
- Rack and Pinion VSC Light Problem
- 2007 rx 350
- DVD Changer and Rear LCD Question
- Toyota Lexus keys?
- RX300 Overheating help please!!
- squeaky belt noise when wet (rain)
- Grounding (aka Earthing) the RX
- Creaking sound (coming from center console(
- Brakes Revisited
- DAQ: Different size tires on front? How bad?
- Yes, again: tires. Enjoying Ecopia
- 28 mpg!?
- Bluetooth for music?
- 2008 Rx400h Rear Wiper Arm Replacement
- Stolen Keys
- Rough Idling & Hesitation Under Load
- All Weather Mats
- Check your strut mounts before more expensive repairs
- RX330 2005 Security System not working
- How to know if 2005 RX330 AWD has air suspension
- CD Player Error 4
- Need help identifying cargo cover
- driver rear window
- Lighted Rear Door Scuff plate Out
- Weird CEL Code P2195
- Bent a rim
- ['04] Best roof rack
- I added pinstripes- RX330
- overhead USB installation
- '04 exterior door strip inquiry
- Low oil damage?
- 2006 rx400h towing issues
- 07 RX350 AWD tranny, transfer case, diff oil question
- Towing Issues - 2006 Lexus Rx 400h
- Years for 2nd generation RX
- Thinking about trading for an RX
- rx400h factory speaker specs and locations
- '04 front license plate bracket question
- Why would you .................
- iPhone connection rx400h
- Any RX330's with over 200K miles?
- Need Wiring help
- Help ID this cooling line
- 2008 rx 350 oil change issue
- Cost for a 4-wheel alignment ...?
- P0328 Check Engine Code
- Ignition Coil Lock Tabs broken
- RX330 OIL PAN was leaking at the thread area
- Towing a 2008 RX 350 FWD
- Removing rear interior quarter panel
- Anti-knock sensor replacement leads to coolant leak found
- DIY O2 Sensor Replacement
- Is this mp3 player?
- back door????????
- media/soundsystem switch
- Idle's Better With Vacuum Line Off?
- Brake light switch issue
- Where does rear wheels speed sensor connect to?
- RX330 custom sub box
- Summer tire recommendation?
- 2008 Vibrating Under Braking
- Thundercloud grill for 2005 RX 330
- clicking sound after trying to remove rear rotor with parking brake on.
- 06 RX330 Sat Radio Antenna install?
- Manual shifting of 2005 RX 330 with automatic transmission?
- RX350 rebuilt motor
- Bright LED Reverse / Backup Lights for RX350
- Grinding noise made by right rear wheel
- Changing LED ring light in cluster. Need pics of your cluster lights
- New Lexus owner (2005 RX 330)
- 2008 RX 350-No Outlet Power
- 2007 RX350- What Tire Pressure for 18 inch rims ?
- Misfire on cylinder #3...already swapped coils
- Spare tire carrier lower cover lost
- Aftermarket Radio install NON-ML NON-NAV
- 2007 RX-350 rear struts replacement
- Paperwork Lost in or behind Dash??
- How many catalytic converters?
- Passenger Airbag Sensor
- 2005 Lexus RX330 Low Gas Alerts
- Looking for OE Wheels (rims)
- Battery Keeps Dying
- Alternator replacement options
- How to solve rattle in sunroof deflector (when closed)
- Power window felt scratching Tint. Has one remove it?
- Major problem getting intake manifold off
- Considering 1-1.5 inch drop
- What a waste of time.
- Differential fluid question
- Happy 4th!
- Pin stripe / side decal on your lexus rx?
- Noisy car
- How long will a RX 330 last?
- Need information (2011 RX 450H)
- 2007 RX 350 Water Pump Replacement - Trouble removing top engine mount
- Camshaft Position Sensor
- Battery Replacement With 9v Holding Power
- Changing Leds in cluster?
- 2005 RX330 Stereo Upgrade
- AC warning message on display
- Thanks Dad
- Frequency output of stock 8 speaker amp?
- oil filler cap 5w-30
- New to Club Lexus
- Planning on buying - need your assistance
- A/C Compressor or Clutch
- help needed
- Question for those of you who repainted
- Belt Replacement / Tightening?
- Advice - Planning to buy used RX 2006-2008
- Almost a New Lexus Owner
- Who has the HIGHEST mileage? 200k? 300k?
- o2 sensor bank 1 sensor 2
- Alternative Cargo Mat Ebay Cut to fit (pics)
- Black Suede Dash Mat in a 2005 Lexus RX330
- Anyone know a good customized Dashboard Mat?
- 30 Amp Towing Circuit
- which repair shop in Sacramento, CA?
- 2007 RX -350 Alternator replacement
- Need help finding a front lip for my hybrid rx
- Dropped screws for stereo into console
- Sudden MPG drop!
- MY car will not start? Is it the Starter?
- Dash cracks
- Pairing I Phone 5
- Replace driver seat RX350 2010 instructions
- Hello, everyone. . .
- Need help with key
- I'm buying RX 300 with 115000 miles.
- What if I remove cat converters? - no emissions control here
- Has anyone used/installed the Techna Fit brake lines on their 05 RX330?
- p0037
- 05 rx330
- Factory towing wire harness with Curt Hitch
- won't crank
- Changed spark plugs, need vacuum diagram,mismatched lines in process
- Windows opened themselves!?
- ON or OFF: Tilt/Telescope Steering Wheel
- Led lighting for driving lights
- Can replacing your gas cap improve fuel economy?
- AC compressor Wine? and lights on dash
- Anyone running 235-50-19 tires on an 06?
- '09 base stereo upgrade
- Lexus RX Arm Rest Replacement Vinyl Ebay
- Chrome Handles Review from Ebay with pics
- Damage to RX350 grill
- Sound (clunk? knock?) from front of vehicle
- Warranty head lights
- Just Tinted my Front Windows 15%
- RX330 Reverse Light Tap in Cab?
- 2006 RX 400h - Floor Cigarette Lighter
- Help! Looking for radio wiring diagram!
- Used 2007 RX350
- RX 330 Antenna Mast replacement
- Lexus RX Dash Mat on ebay?
- Back seats
- Need your help to decide my Lexus's destiny
- RX350 Dash Cracked
- Wiring new Radio
- RX350 Steering Rack issues
- Transmission
- daytime driving lights/high beams
- Window Operation Noise
- Overdue response to Bamboo Paint PM's
- Adding an aftermarket touch screen but also keeping my touch controls for climate etc
- Grills
- Sell GS for RX?
- 2006 400h leak? And musty smell
- Lexus RX330 Tint Percent
