Dropped screws for stereo into console
Old Jun 16, 2014 | 04:50 PM
Sadiekins's Avatar
Sadiekins
Default Dropped screws for stereo into console
Oops!!! I was installing the GROM Bluetooth adapter and I dropped two of the screws down the hatchet. One was already missing when I opened it up!! Is there any way to open the console thing and retrieve them? I read in another thread that the screws are 10mm. Is this a standard screw I can find at Home Depot? I don't know anything about this stuff. I'm surprised I was able to even install it myself without screwing my car up!!!
Old Jun 16, 2014 | 05:58 PM
mwengineer's Avatar
mwengineer
4th Gear
Exactly the same thing happened to me while installing the iphone adapter. I located one of 2 screws I dropped with a telescoping-swiveling mirror and then used a telescoping magnetic pickup to retrieve them both.
Old Jun 16, 2014 | 06:14 PM
Sadiekins's Avatar
Sadiekins
Ooh a magnet is a good idea if I had one!!! I don't even know where they are!
Old Jun 16, 2014 | 06:50 PM
RX330inFL's Avatar
RX330inFL
A telescoping magnet tool is relatively easy to find, even in HI, and need not be expensive.
http://www.sears.com/craftsman-magne...1&blockType=G1
Old Jun 17, 2014 | 03:38 AM
smassey321's Avatar
smassey321
+1 on this. I also used mine to re-install the screws when I was putting it back together. It is powerful enough to get the screw started in the thread.
Old Jun 17, 2014 | 10:30 AM
beefmc's Avatar
beefmc
If you have a Harbor Freight Tools, you can find telescoping magnets and mirrors on the cheap there
Old Jun 17, 2014 | 10:42 AM
RX330inFL's Avatar
RX330inFL
Before I posted I checked the HF web site and could not find any there on the islands. Why I went with the part from Sears.
Old Jun 18, 2014 | 07:48 PM
LeUsX's Avatar
LeUsX
Same thing happened to me when I was installing the Grom adaptor. I just ordered a telescopic magnet too.
Old Sep 9, 2017 | 03:22 PM
Bobomo's Avatar
Bobomo
If you're coming here from Google (probably standing in a hardware store) the answer to the question appears to be M6-1.00-16. That's what worked for my 2006 RX400h.
Old Mar 10, 2024 | 01:13 AM
SaltyWater's Avatar
SaltyWater
1st Gear
I also lost both screws. I was able to retrieve one of them with the telescopic magnet (thanks to the suggestions here). I can't find the other one though. Can I just leave it there or are there fragile stuff down there? I have a non-hybrid if it matters. Even with a mirror I can not find it.
Old Mar 10, 2024 | 06:21 AM
Leeper's Avatar
Leeper
Yes you can leave it it there. I fished around for it with a magnet, also looked with a borescope with no avail, so left it and hit up an Ace Hardware picked up a new one all has been good since.
To others attemtping this simply put a shop towel or micro fibre underneath when removing stereo bolts thi should stop them from dropping into the abyss
RocketG35
Sep 15, 2016 10:32 AM
gsean400
Oct 20, 2014 05:20 AM
Blueshark
Aug 9, 2014 03:46 PM
SC400slide
Mar 11, 2014 07:50 PM
kevin1000
RX - 1st Gen (1999-2003)
Oct 2, 2008 08:09 PM
