- Opinion on 2003 LS 430 maintenance 66k miles
- Opinions on Price
- my buddy said hand wash only
- smart key didn't work last night
- 2001 LS 430 Mark Levinson Amplifier Problem
- Question-upgrading Fog and Daytime Running Lights
- Amsoil in the LS?
- Who has swapped their mark levison sub?
- One Hurt LS... WOW!!!!
- insurance
- datasystem asc680 speed harness connection?
- Coolant Leverl Sensor
- Tinting the front windshield
- Greetings from me and my 05
- Cylinder 2 ignition coil wiring diagram 2002 ls430
- Rear passenger door stuck
- Passenger mirror not folding in completely
- mark levinson cassette bezel
- #5 cylinder coil pack- pick of wiring
- Potential Owner Questions
- Multipoint Inspections
- LS460 seats in a LS430?
- Custom X pipe exhaust question
- Car Cover - my Covercraft experience
- Ashtray lighter power..
- One Year, 2000 miles, Oil Change Question
- air suspension conversion LS430 2006
- LS 460 Rear strut replacement tutorial
- 2002 Full Ultra 152k miles on it
- Can LED headlight bulbs be installed on an LS430?
- New rims for Lexus LS430 but what size?
- Worst that can/does go wrong on the 430?
- Locksmith cant program new key
- If I were a traveling salesman
- Crack in door wood panel 2005 LS430
- Factory RIm Refurb?
- Lexus LS 500
- data system r spec controller
- Heated Seat Blows Cold Air
- I can't tell if my pwr steering fluid is low--making noise
- 04 ultra ls430 Front parking lights not working
- Need help removing steering column nut
- signed up for unlimited car washes
- because of the LS, I'm buying cds again
- Options on Aftermarket Front bumper?
- car seems ok in snow
- Code P1354 and P1351 VVT System Fault Question
- Is Japan always one gen behind
- LS430 Inner taillight does not work
- Valve cover gasket
- do actuators click every time car is locked with fob?
- One reason why cream puff LS430s are hard to find.
- Front end sound diagnosis
- Bluetooth question
- Donuts in snow question
- Sport Shocks on my 06
- 01 LS430 driver seat won't go up or down
- Previous New Guy....just purchased LS430!
- Has anyone replaced the LOWER engine shield?
- Shift indicator plate cover.
- Slight whistling sound in cold temps?
- Build Quality 430 VS 460
- abs issue after wheel bearing replacement.
- Plan on selling in May - are these flaws worth fixing first?
- Thinking of selling my 04 ML. Any suggestions on price?
- Preventing door rust? Any ideas/Experience?
- Have an '04, spent a week in a '12
- 2003 LS430 Driver Seat Frame Broken
- 03 LS430 - Front and Rear Bumper Covers
- Installing air ride on LS430 UL
- Master Key Compatability across years
- New Guy....looking to by LS430
- check vsc
- Need a part? Check out lexuspartsnow.com - great service!
- HELP.....Red Maintenance Light wont shut off
- Rack and pinion issues
- 2004 LS430: navigation touchscreen issues (need help w/ replacement)
- found a 17mm nut near the a/c condenser
- Tried all solutions - help required on CODE p0171 - Lexus LS 430 2002
- How can I removed tree sap???
- I like this car
- It Pays To Check Your Service History In Detail
- Rear seat belt question.
- Radio/Navgiation/Climate controls not coming on
- New member, no Ls
- molding strip on the front bumper
- Picked up GS today....
- Coolant leaks
- 90k Mile Service Needed
- Scan Gauge II on the LS430
- VIP Badgeless Grille Painted
- Happily back in the LS430!
- Need help ASAP
- Transmission Flush Advantages/ Disadvantages
- 01-03 Tail Lamps replaced with LED=Tail Lamp Failure
- New owner questions
- 2014 Lexus ES350 17" wheels on LS?
- Good thread on 4th gen forum re: 430
- My precious OEM Lexus glass!
- Cleaned the MAF Sensor, Now Shifting is Smoother
- Headlight goes off and on
- Finally back in a Lexus..
- Will not shift past 3rd gear
- Oil Analysis on 169K LS-430
- Wires pulled out spark plug connector
- where are all you guys anyway?
- Key is Different
- Techstream Question
- Smart Key Broken
- Mouse-damaged O2 Sensor Wire - repairable?
- How does the LS know miles since refuel
- What is best replacement for LS 430
- Need Advise on new to me 430 purchase
- 0-35mph time (comical)
- Wrong Things To do in the Winter Season
- Am I dreamin'??? New battery solves my ML amp speaker cutout issue
- Driver seat issue.
- How many of you are interested in getting new leather seats?
- Can you start the '05 LS430 with just the hard key?
- Are winter tires/rims needed vs. GT All Season?
- Tranny Fluid question
- Smart access keyfob
- Replacing LS 430 2001 Headlight
- Snow is here - Ballast
- Question regarding car battery area
- 147k miles on a timing belt
- Missing clips on plastic engine covers
- Cayou Honk the Horn When You Press Unlock?
- Do low-profile tires improve handling?
- Cost to replace ls430 pan gasket/dip stick o ring?
- 2 Push Buttons and a Twist Knob
- Tilt/Telescopic Function and Cold Weather
- Picky owner or too many gremlins?
- how do you program your smart key
- ls430 vs gs350
- 2005 Remote Key Programming (Non Smart) Help Needed
- A Series of Unfortunate Glitches
- I'm not meant to have a tight suspension
- VSC, check engine light and red arrow on
- Buyer beware. White 2005 for sale at Tri County Lexus
- New LS430 Owner -Question about Rear Sunshade
- 2003 LS430, Bought Recently, a few problems.
- 3rd owner 1 week
- Need Help: 2004-2006 with smart key remote start?
- Rear main seal leak
- it's time to steer again!
- Keep Your Eyes Out on the Salvage Front
- Need help! Keep blowing INJ fuse
- Where is the Ocv filter?
- Sheared valves after timing belt replacement?
- Drivers side mirror just swings
- Absorber control switch - don't change hardness?
- I thought my Mark Levinson was gone
- Coin Tray - Broken Latch
- Welcome to Lexusville
- Sport Suspension Emblems
- Bose Suspension System
- Spark plug replacement and gas mileage
- 2001 Lexus LS430 Non-Nav APP Radio 4 Install
- 04 vs 05-06
- Current LS and Dream LS
- 04-06 transmission swap to 01-03 LS 430
- Odd Window Wind Noise Issue
- Went the safe route but I'll get there.
- New to CL. Need help with window problem.
- Replace valve cover gaskets, cam seals etc
- Subpar work at indy shop
- Cup holder and interior color question?
- Parking Brake Release part number?
- Spark plug blowby or leaking seals?
- Cat removal?
- 2001 Lexus LS430 C1739 error
- Parking/Proximity Sensors acting up
- Early Christmas Gift Got the LS a Friend
- New owner intro
- Hi, what do you think is the best way to sell my 01 LS430?
- Side mirror glass replacement cost
- Good deal on 2001 LS 430 base
- LS430 Door Plug
- What did y'all get during Black Friday/Cyber Monday for your LS430?
- Part Identification help please.
- does your choice in cars help to reach milestones
- Cruise / Display on Steering Wheel not working. Airbag light on. Need Help!
- Airbag SRS light on 2002 LS430 after Rack and Pinion replacement Need help!
- C1223 c1201
- Great deal for someone in the south Florida area. 02 LS430
- Happy Thanksgiving
- Odb2 scanned or techstream
- New ls430 owners with old cars
- Giddy but unsure which to buy
- Another new owner checking in
- Never mind - Found it. Console lid replacement thread-Where?
- My First Lexus - 2001 LS430 UL
- climate control behavior--normal?
- Ultra rare combo right, blue onyx/saddle?
- haven't seen an '06 for sale with this many miles
- Power Steering Pump/Rack and Pinion replacement where do the orings go?
- Fresh detail with jetseal
- Front end dropped on wheels. Suspension?
- Good Deal or Naw?
- Trunk Latch Relay on '05 LS430 Keeps Clicking
- Air Strut Failing
- Water trickling sound during light rain....windshield drain run off?
- racing chip
- 01-06 SPark Plug DIY help
- Just completed the Levinson $20 Subwoofer repair! Sounds great now!!!!!
- Transmission mount replaced
- Picked up some quilited floormats
- My Love - The 2006 LS430 UL
- Do you enjoy unexpected trips / errands in your car
- How many keys can be programmed for an '03 LS?
- pry points for center console
- Is this '01 UL priced right?
- does your car have dings?
- Connecting to stereo with external audio source
- can anyone explain this feature?
- Lowering LS430 UL
- Tail Light Warning -- No Code!
- Exhaust Suggestions Please! (new member)
- Taillight melted?
- Potential great deal on this 88K '05 Sport in Orlando?
- Transmission Pan Gasket Part number
- Headlight issues and leaking
- How many miles have you driven your LS430 purchased fall 2016?
- LS430 hood is impervious to beer
- 4 wheel or 2 wheel alignment?
- Bumper cover repaint- millenium silver
- AFS Light Flashing: Bad shocks to blame?
- Engine warms up quicker after spark plug and TB change
- Aybody have experience with Rim Edge Protectors??
- changed plugs, now engine shaking!
- Used car shopping: '03 vs '05 comparison
- LS 430 2006 Ultra Model, Cassette stuck in the player!
- 2005 LS 430 Ultra
- Rear swaybar links: oem or aftermarket
- Rear sunshade stuck in the up position
- Unicorn Alert 2005 white on saddle for sale
- Button Backlights Not Working
- California emission?
- grommet when doing oil change
- New LS430 Owner
- got my build sheet
- Our new 2001 LS430 UL
- Is this normal for the driver's side wiper arm
- Mark Levinson Amp - Speaker Wire Plug Map
- Rear Sport Suspension OEM Upgrade Parts Ordered
- Dumb Question of the Day - Reinstall Battery Cover?
- Blower whine
- New oem rotors & pads ...what a difference!
