- Heads up display.
- Plz! Need Pioneer Avic-d3 Custom Lexus Backrounds
- TV,S for my HEADREST AND VISORS
- 2nd gen gs3 stock sub removal? need help !!
- sc3/4 sub
- Stock Sub Replacement Advice
- which one of you guys run IB subs?
- Real Time Help Needed
- Sub vibrations ok with oem (in trunk) CD changer?
- Sub problem
- Gathering necessary components for stereo install:98 SC
- Help viewing DVDs with my pioneer D3
- Metra Harness or Scoshe?
- Antena stopped!
- Seattle aftermarket alarm shops?.....
- help how do I get the cig tray out 90 ls400
- will a 2000 Gs subwooofer fit 90 ls 400
- Panasonic Strada CN-NVD905U
- HELPPP car not starting after system install
- In the middle of an install...quick question
- alpine PLV-7 install help needed
- Window Help !!
- Need Help Putting Nak System back into aftermarket sc400
- subwoofer replacement help
- cig lighter issues
- Elemental Designs SQ10 install into SC300 is complete
- Viper 791XV problems
- Orion 2500?
- Any Fans of Steve Meade Designs?
- three way components
- Aftermarket 8inch sub in LS 400 (Using Factory Amp)
- Kicker with rockford fosgate?
- 1991 es300 radio code entered wrong 5 times
- homemade camera mount in LS400
- LuxLink Sense-O-Shock install on 2000 GS400
- Stock Head unit problem
- '99 RX 300 wire colors for stereo?
- Remote Start
- cracked
- Headrest TFT monitor problem - Please Help
- lights out!
- stoled my radio
- GS OEM Navi splash screen
- Please help which sub with this amp!?!
- HD Radio for '02 es300? cheap...
- VAIS Promo Code?
- HELP: GS300 Levinson CD mag jammed!
- Pioneer Avic D2
- custom dash/control panels
- i need help with my radio speakers
- please!need help with speaker
- CD error Nakamichi 12 disc changer 1996
- Update to Nav System?
- Where can i get subwoofer help?
- IB limits in a 2g gs3
- Just installed Alpine 9886 and car pops when shut off.
- Stock SC300 radio antenna hookup on back of radio?
- 10" aftermarket sub in factory location...
- How much will I be spending?
- US Spec Navigation system changed to european map
- NAV map update disk
- Just got 12 Cd Changer
- Aftermarket Picture Thread ... Head unit/Subs/Custom Trunk/Speakers/Etc..
- Opinion on CDT and other speakers in my budget.
- Anyone have some extra Polyfill I can buy?
- speaker suggestions
- installing a new dual din in sc300,help!!
- Keyless Entry Question (Sorry!!)
- Question about BT/Nav Opinions wanted...
- stock pioneer model #
- Infinite Baffle / Free Air Subwoofer - Please Post Brands and Models
- crossover question??
- Maximum watts to stock speakers.
- Need Help with Auxilliary Horn Wiring
- Owner's manual needed--Alpine 3555 amplifier
- HELP!!! And yes I have searched. :)
- Better service then pioneer
- Woot: Just put in my preorder for this...
- Installing AfterMarket Headunit in 94 LS 400
- Lexus ES 250 won't start
- sc300 radio question
- How many watts going to factory sub 2IS non-ml?
- Aftermarket setup with 94 LS400 help
- got a few questions on the gs300 audio.
- rx350 conversion of non-nav to nav system
- LS400 - Headunit Deck size?
- Eclipse AVN 5435
- Just bought 97 SC300, No Amp or Changer???
- 5.1 channel amp
- Lost Key, NEED HELP!
- Bought a 2nd Gen GS and am about to install a D3... are these the right parts?
- Best Sub Location for 2nd Gen GS!!
- Audio quality via handhelds; wma lossless
- Amp on but VERY little noise coming from sub
- 1994 LS400 -- Deck size? Double Din?
- Second failure of Sirius radio.
- Kenwood's new 2008 line of indash dvd and nav units
- Sub/Brands etc --
- 3rd GEN GS3 Amp & Sub DIY
- today my antenna went up, but kept going...?
- Installing Pioneer Avic Z2
- how to replace subwoofer
- How can you hook up video input to stock 2000 GS400 Navigation?
- Kicker Or Fosgate
- Wow talk about some bogus indash nav comparisons
- Keyless entry works partially tried search cant find anything
- Blackkenned LCD - '94 LS400 (Need part asap)
- Video: AACs new Halo Inverters put to the TEST!
- GPS -System Disconnected Message-GPS OUT
- Panasonic Strada CN-NVD905U in 98 ES
- Is a 17-foot RCA cable long enough to go from the HU to the trunk in a 2G LS400?
- Eclipse AVN5510 install in a 2000 ES300
- Illumination wire for 2000 ES300
- Subss....help?
- Front Speaker Cutting Out
- Audio turning off
- Stock alarm driving me crazy! plz help
- IN STOCK! Fiberglass subwoofer enclosures for the GS and IS, PICS
- Help....I've read /searched...no luck :( (Installing Amp)
- Cd Changer Need Help!!
- Radio Problems
- modifications needed to install 6.5" rear speakers?
- JL w7 in back seat, or trunk?
- "Check hard disk" navi problem
- subwoofer that go boom
- 2001 GS430 NAV, Latest Version?
- hid lights for lexus
- To activate a stock alarm.
- Few questions about my ml system
- Sizing
- Stock '98 Nav
- GEN5 (2007 and up Navi) 5.1/7.1 override
- Weird problem on es300 '97 speakers
- GPS Navigation for 1992 SC400
- Stock Sc Sub
- Any recommedations on replacing OEM Nav System
- Just ripped everything out. I couldn't take it anymore. 56k BEWARE!
- Speakers installation on GS400..??
- Which car alarm sound?
- GROM iPod Kit
- New Stereo Help.
- Should I change out from OEM Nav/ML to aftermarket??
- Need some advice on bluetooth setup for 2003 ES300
- Upgrading to Nakamichi from premium system..??
- Volume Level: XM vs. CD/Radio/Etc
- custom
- XM RADIO with a SC??
- 91 ls400 seat memory and electric side mirrors don't work...any help?
- ignition wire?
- door speaker
- sound issue! please help
- How do I remove carphone in center console - pics
- New to the forum need help
- what kit to use w/ gs430 ml system
- How to hook up amp & woofer with stock stereo?
- sc300 antenna plug?
- INstalling a good sterep with screen and nav.
- Quick Audio Question
- Humming and RPM Dependant Buzz after Alpine DVD install
- wiring harness converter
- Looking at these component speakers for my car
- '91 LS400 sub replacement
- Show your stereo skills
- Popping & Crackling from SC spreakers....
- radio sound very low
- How to remove the driver's door speaker grill?
- Okay, Here's my planned Audio setup for the SC...
- ******speaker******
- SC300 Rattling Problem
- 2GS Fiberglass doors
- What converter do I need?
- recommendations for sat on 02 GS430 ML NAV
- DEI 513T Piezo Siren
- Deck Installation Help for 1992 SC300
- Another CD changer questions.
- pioneer D3...amazing..
- Trying to fix my audio system LS 400 90
- Sub Placement? Too close to trunk?
- What's Wrong!
- anyone installed a connect2car system?
- Module in trunk footwell
- TribalVision Truck!
- What size heat shrink?
- 99 SC300 Help with aftermarket headunit
- Tubes vs solid state - a good read!
- Anyone install an A/V recording system in their car?
- Save $$$! Call First When Buying DVD Navigation Update
- 02 SC430 Navigation: Map Region is grayed out!!!
- Some input for a possible setup...
- Sound Deadning/Dynamat/Baffle Question
- 6 CD Changer trouble
- Aftermarket sub+amp on 2008 is 350 w/ ML?
- best option
- Elemental Designs products
- Pioneer AVIC D2 Screen Change?
- 2-way, 3-way, 4-way?
- NO sound from stock sc300
- speaker size..??
- 03 ES300 Radio Install
- Cops cant touch me! ("naaah nah nah nah... nah nah... nah nah... can't touch me")
- Aftermarket Radio Modifications
- Radio reception
- GS radio display problems
- factory amp ?
- 25 watts make that much difference?
- iphone and LS460
- I-pod hook up on SC300 radio....
- Please Critique My Amp Choices!!
- Surround Sound Button Advice
- Headunit install (sc300)
- Anyone with Kenwood DDX6019 + Ipod setup?
- Digital Designs - your thoughts
- What amp do I need for my old box?
- Custom Box for 2nd Gen GS
- Need your help. Is this a good deal?
- XM Radio Quality on News/Talk Programs!
- Question on amp for 2 TC-1000's and General ?'s too
- Kenwood ddx 8017 install 2000 GS300
- installing stereo in sc300
- Help needed with my reverse camera!!!!
- GS430 New School/Old Skule System
- After market Bass Tube installation question
- Navi to Non Navi Help!
- ls430 ML CD Changer
- SC400 Nakamichi Jammed Cassette Help Needed
- 1993 Lexus SC300 - Carputer Installed
- bluetooth
- Question about audio unit
- K40 CALIBRE Install w/laser DEFUSER
- Good place to buy stuff online for good price?
- OK, got a NEW Sub and amp but... its sounds muddy
- Alpine PDX series
- what's the largest tv you can fit into a headres on a SC300?
- Whos running OLD SCHOOL gear?
- 99 ls400, factory audio to navigation, anyone did it?
- Christmas came early, got a new Sub and Kicker AMP
- 97 sc300 amp bypass wiring question.
- Eclipse BYPASS LOCKOUT
- Pioneer D3 or Z2? I got the money for both
- Jl 8 inch w3v2 sub replacement questions
- audio question!?!
- Monitors in back headrests? how do I do it?????
- Problem ejecting nav dvd on Gen 3 system
- Just installed radio, now buzzing noise with rpm
- Adding a sub with out changing amp
- Power Supply interference with ipod
- What is Your Favorite?
- How Do You Take Out The Sub Woofer On A Gs Year 93'? Helpp
- NIB JL 10IB4 Subwoofers $100
