Quick Audio Question
From: NY 2 da heart but got luv 4 all...Now at Sin City
will the stock amp and sub be compatible with an aftermarket headunit? i have an i bought an ls400 with an eclipse headunit but i dont hear the subs working. any information would help. thanks
the sub has seperate amp installed behind rear wall panel in trunk. it probably was not connected by aftwermarket installer. it would be a 6 pin white plastic plug probably found behind the aftermarket unit. if you connect it up to power and sub output wiring it should work.
shaned1320
May 13, 2008 02:30 AM
lexusnoob
May 29, 2007 09:02 AM
TedxGS
May 13, 2007 02:22 PM
