Please help which sub with this amp!?!
Im ordering a kicker 15" L7 for my ES.
I know im going to get this amp.
http://www.onlinecarstereo.com/CarAu...roductID=16367
Should i get the 2ohm:
http://www.onlinecarstereo.com/CarAu...roductID=18888
Or the 4 ohm:
http://www.onlinecarstereo.com/CarAu...roductID=18889
Which one should i get? I dont know **** about ohms.
Or the 4 ohm:
Ooops - Yup. Dual 2 Ohm in parallel will make for 1 Ohm @ 1200 Watts.
Good catch guys. I am still real rusty on the car audio stuff.
Here is JL Audio's Reference page.
Tortoise,
Are you going for sound quality, SPL or a combination? From everything I've read, the Kicker L7 isn't that great on either. I also looked and can only find the Qts (greater than .5) and an xmax of 14.5 mm. Where are the rest of the Theile/Small parameters or are they hiding something?
A Fi Q or BL has a better sensitivity and at least 50% more excursion. Not to mention they cost less. link.
-Robert
-Robert
You want to wire it like the first diagram - wiring diagram. That's wiring the voice coils in parallel.
-Robert
-Robert
-Robert
-Robert
Yeah i know what its saying im just wondering do i get the 2 ohm sub or the 4 ohm sub to go down to 1 ohm?
alright thanks for clarifying. The rms on the sub is 1000 and at 1ohm the amp is 1200rms but 1. the amp might be rated low and 2. 200 watts over isnt too much i dont think. I just hope the shop i got to knows how to wire to 1ohm.
If you are worried, print the diagrams on the link I gave you. Really, if they don't know how to wire a dual 2 ohm sub for a 1 ohm load, then they shouldn't be installing stereos.
Remember, that is the power the voice coil can handle but not how much power is needed to push the sub to its mechanical limits. With only 14.5mm of excursion, it should take a lot less power to reach the max. Pushing past the limits can test the suspension or crash the voice coil into the back plate. Both can destroy your sub. The Brahma Power Handling technical doc is specifically for Adire's line of drivers but the same logic applies to EVERY subwoofer. WinISD or Unibox are great pieces of software for determining not only proper enclosures but determining how much power your sub can handle before it reaches its mechanical limits.
-Robert
-Robert
