Alternator Replacement SC430
Old Dec 16, 2011 | 08:34 PM
jasone36's Avatar
jasone36
Exclamation Alternator Replacement SC430
If anyone is in the market for an alternator, Advance Auto Parts sells a "Worldwide 12026" rebuilt alternator for $233.99 ($24 core) which they claim is compatible with the SC430.
Advance Auto Parts also performs a free check of the battery, alternator, and starter using this big piece of equipment they drag out to your car.
The strange part is when they checked mine, it read 14.10 volts under no load and 13.90 volts under load... which they told me is strange because the numbers are supposed to be reversed (higher under load), but in the end the test machine read "alternator status good" which is confusing. If anyone has any thoughts, please share.
Thank you
Old Dec 17, 2011 | 11:48 AM
scdroptop's Avatar
scdroptop
13.7V is by-the-book a "perfectly running" Lexus ASE Certified standard. I know because I just went through this with mine two weeks ago. The guy working on my car was a master technician at a prominent lexus dealer.
If you don't have any charging, starting or other issues-don't mess with it.
I'd put little stock into Advance Auto Parts diagnosis. They are good for filters, batteries, belts, plugs and misc bulbs...but I wouldn't trust my Lexus with diagnosing a charging/starting problem if you have one.
If it's good, leave it alone.
Old Dec 17, 2011 | 07:13 PM
texsexlex's Avatar
texsexlex
...so were you having a charging issue or what made you have it tested ???
Old Dec 17, 2011 | 08:47 PM
jasone36's Avatar
jasone36
I am not having any charging or starting issues that I know of, the only reason I had the diagnosis done was because the previous owner mentioned 'you might want to look into the alternator if you start having issues' after I bought the car (I am not having any issues 3 months later).
Old Oct 17, 2013 | 12:26 PM
Runnertoy's Avatar
Runnertoy
anyone out there can help - how to remove an alternator on a 2002 sc430 ? Appreciate any suggestion thx.
Old Oct 17, 2013 | 02:36 PM
SC43052's Avatar
SC43052
I have not done the alternator on mine yet, so I can't give you a step by step.
First use the search function on this site to see if you can find a DIY write up.
Then try the web as the same 4.3L engine is used on other Toyota products.
Finally, if you come up dry PM me with your email address and I will send you a procedure out of the factory manual. (As it is copyrighted I will not send it in the open).
KingReyes
Sep 17, 2018 04:21 PM
Domino1066
Feb 12, 2018 08:19 AM
jasone36
Jul 3, 2012 11:55 AM
Herm
Nov 29, 2007 11:48 PM
