Time for upgrades....
Old Aug 17, 2019 | 10:04 PM
azisslider's Avatar
azisslider
Default Time for upgrades....
going to start fixing up my car wondering if there are anything threads about isf body parts on a is250. plans are going to be swapping out hood, fenders, side skirts and upgrade brakes on all 4 corners to lexus brembos. my goals is pretty much convert my is250 into a isf minus the engine and transmission. all suspension is getting aftermarket arms, down the road the engine will get swapped out when it goes out.
Old Aug 17, 2019 | 10:35 PM
primavera's Avatar
primavera
Just FYI, for the amount of money and time you spend on those upgrades, you can buy the real ISF that drives like ISF and holds the ISF resale value.
Old Aug 18, 2019 | 08:23 AM
Petet's Avatar
Petet
^^ couldn’t agree more. Project cars are fun but expensive.
Old Aug 18, 2019 | 09:29 AM
2013FSport's Avatar
2013FSport
And because its Lexus and IS-F, you will pay a premium compared to most any other car out there.
JM2C but when the audience sees it's a 250, there may be some shaming involved. Maybe keep the 250 badge??? Ha!
Old Aug 18, 2019 | 01:16 PM
azisslider's Avatar
azisslider
buying isf would probably be cheaper if i planning on keeping it stock but its been a daily decent daily but its getting stripped and gutted and turned into a track car eventually. i rather do it to is250 then a isf, spending 20k on a $5000 car versus spending 20k on a $30k used isf.
Old Aug 18, 2019 | 01:33 PM
azisslider's Avatar
azisslider
i dont plan on badging it as a ISF at all badges are getting removed.... catching slack is going to happen from any1 every1 has there different opinions on cars just cause i want to use parts off a ISF doesn't make it 1. beside its is250 so the swaps going impractical like either a Jdm Beams or a 1j. depending the route i take it after the all suspension and brakes are done i might pull my ls3 out of my 240sx.
Old Aug 18, 2019 | 02:34 PM
Aspect's Avatar
Aspect
the isf is wider than the 250 so I don't think the hood will fit. ISF brakes require ISF hubs I've read. Idk about fender or side skirt fitment
Old Aug 18, 2019 | 03:28 PM
Petet's Avatar
Petet
I always assumed the ISF was built on the same chassis as the 250/350. Never looked at one in person really close.
Old Aug 18, 2019 | 04:40 PM
2013FSport's Avatar
2013FSport
For parts swaps I use
T o y o d i y . c o m then hit other lexus sites to check actual compatibility and where used.
OP if you know a good body man think about a weld on wide body. It will turn heads regardless of what else is done.
Good luck and have fun!
Old Aug 20, 2019 | 11:04 PM
azisslider's Avatar
azisslider
from what i have gathered from online research the chassis's are identical same wheelbase length, the widths are different front and rear cause the isf runs wide wheels and different offsets for upgraded performance. the width between them isf front fenders are 1.5 inch wider for tire clearance and the isf bumper has larger grill opening for more air volume to radiator and the isf hood is just has raised crawl for more aggressive look and clearance for the v8.... saturday going over to a friends bodyshop to compare chassis dimension between the 08 is250 and 08 isf. we have no down time at our shops right which suck for our project builds.
Old Aug 22, 2019 | 02:39 AM
MikeyK02's Avatar
MikeyK02
What color is your car? Going to be selling my isf front clip soon depending on how far away you are it maybe an option
Old Aug 27, 2019 | 11:22 PM
azisslider's Avatar
azisslider
i am in phx its dark grey with a metallic flick....
thequickad
IS F (2008-2014)
Sep 3, 2018 10:06 PM
08lexury
IS F (2008-2014)
32
Jul 26, 2012 09:29 PM
003Is300
May 27, 2011 07:54 AM
003Is300
IS F (2008-2014)
May 26, 2011 05:23 AM
mex lex
Apr 25, 2010 05:05 PM
