Winter tires
Hi guys,
I have a question. For my IS 250, I have tires 225-45-17. It's very low profile...I used to have a subaru forester for 6 years, and my first winter with the lexus is still unknown. Do I have a possibility of putting a tire that is bigger so it's less low profile. Should I put a smaller rim? What are the possibilities?
And do you guys have good recommandations for tires and good prices (around Mirabel)
Thanks for your input
Smallest tire you can use is 16" if you really want more sidewall, but you'll have to buy a set of 16" rims for that. You can't really stray much from the current amount of sidewall on the 17" tire. If you don't want to buy 16's, the suggested tire size above for the 17 is more than fine with a good set of winter tires.
https://www.clublexus.com/forums/is-...-wheels-2.html
edit: for those of you with 350's, a 16 rim will not clear the front calipers.
https://pmctire.com/en/
https://www.tiresandco.ca/
https://www.4tires.ca/
https://www.quattrotires.com/
https://tiredirect.ca/
PMC Tire, good prices and free shipping in Canada.
The change in speedometer is so minuscule you would never notice any difference. We have terrible roads in town so I run slightly taller sizes: 245 40 18 in the summer and 215 50 17 in the winter. Never had problems with electronics.
For winter tires I always go one size smaller. For the IS250 I have 205/55/16 winter tires. The advantage is that a narrower tire (205 instead of 225 width) will be better in deep snow. A wider tire will tend to sit more on top and not dig into the snow as well. A higher sidewall (55 instead of 45) also allows a bit for flex in the tire and also helps with tire traction. 205/55/16 is virtually identical in circumference as the 225/45/17 so there is no impact on odometer.
I do samething as Newgsman. I'm running on 16" on my IS AWD and it's better than the low profile 17s for winter.
Also I drove a WRX for 12 years on Blizzaks and they were amazing. But the Hankook I-Pike that came with my IS are as good as the Blizzaks were for my Subaru.
The IS is a very stable car in bad snowy road (like my WRX was) I just miss the LSD for drifting...
