Radio turns off
Old Sep 13, 2019 | 12:35 PM
rlafata's Avatar
rlafata
Angry Radio turns off
I have a 2013 IS250. About every day I will be driving with my radio on and the radio turns off. I hit the power and it comes back on. It can happen like two or three times in a 20 minute drive. Sometimes it happens when I hurt a bump. I checked the radio fuses and they look fine. I replaced the fuse on the passenger side just for grins and still happens. Any ideas?
Old Sep 17, 2019 | 07:43 PM
MikeFig82's Avatar
MikeFig82
Mine used to turn off by itself. It weird it hasn't happened in quite some time.
The amp is the trunk under the plastic tray. Right side facing the engine. There could be water in the cabin from the vent on the rear bumper that's in the same area. That would be my first to check.
Old Sep 19, 2019 | 04:26 PM
2013FSport's Avatar
2013FSport
If nothing is found with the AMP in the trunk, put the stereo into diagnostic mode and test the hard drive. A failing drive does crazy stuff to and you don't need NAV to have a drive as I know it.
That said there was no mention of Rebooting or locking up. Just turning off. Go for amp. If it's been damp it will have rust on the screws and a high water mark.
If either of those are true, you need to pull the bumper and replace the missing air flap.
Old Sep 26, 2019 | 02:07 PM
rlafata's Avatar
rlafata
The disc load button was stuck on the CD player. I pressed the button several times to loosen up and appears to have fix issue. Thanks for the responses!
Old Sep 27, 2019 | 07:52 AM
Gville350's Avatar
Gville350
Weird, but glad you found the culprit!
nzasian88
Apr 4, 2020 12:56 PM
osomegaSC
Mar 23, 2017 08:30 AM
F1nALMSfan
RC F (2015-present)
Jan 13, 2016 10:09 AM
Gsnuggs
Sep 16, 2012 12:07 PM
