Antenna Mast Installation
Old May 1, 2005 | 06:30 AM
Salil022's Avatar
Salil022
Default Antenna Mast Installation
my old mast was broken, so i bought a new one from dealer, but here is the problem, i took the old broken mast out right from outside and tried feeding the mast from inside, it goes in but that white wire with the teeth on the mast doesn't feed in all the way i even tried turning the radio off, seems like 1/4 of the mast doesn't want to feed in, do i have to take motor assembly out? any help would be appreciated
thanks
Old May 1, 2005 | 10:02 AM
nysupraman's Avatar
nysupraman
you probably still have some of the old broken mast in the assembly, so yes you have to take out the assembly. when i did mine a year back i used this site:
http://www.carstereohelp.com/repairD...mryPwrAntR.htm
this is for a toyota camry, but its all the same thing, it doesn't take long at all, gluck.
Old May 1, 2005 | 10:48 AM
Salil022's Avatar
Salil022
Thanks bro, hopefully this will help, i 'll try this as soon as i get home tonight and let you guys know!
Old May 1, 2005 | 07:43 PM
Salil022's Avatar
Salil022
Just got the mast installed, it was very straight forward process, i had to take the motor assembly out to get my old mast out, everything is working proper but only problem now is sometimes antenna doesn't retract all the way down, it sticks out like 5-6 inches, i don't know why is that, anyone with suggestions?
Old May 3, 2005 | 04:18 AM
byhisgrace's Avatar
byhisgrace
If you are sure that you got all of the old mast out then I would say maybe it is that the new mast didn't go in perfectly straight and is binding. That seemed to be the most difficult part of getting mine to work. It would work a few times then it would bind so bad that it would blow a fuse. Good news is, after I got it in straight I have not had any problems since.
Brad
DavidEW
RX - 1st Gen (1999-2003)
May 9, 2015 09:57 AM
rclab1
May 3, 2013 12:30 PM
GWS
GS - 1st Gen (1993-1997)
Feb 28, 2011 03:59 PM
horent135
Feb 13, 2011 09:31 PM
1995LS400
Dec 4, 2007 06:43 AM
