- 1.5JZ build, Bad knocking :(
- we all know about the LS 4pot in the front but about the 2pots in the rears
- Fuel Rail question
- car won't shift
- Auto Bahn Soarer
- If it's fried-shouldn't it throw a code????
- What kind of BLACK is nice for paint?
- LED strip on spoiler, the screw
- anyone here from florida that does intere work
- Who here has swapped a 1jz into an SC400?
- cigarette lighter won't come out
- my new sc400
- just got my first lexus 1995 sc400 193000 miles
- Need help with front plate
- Is this a worthy buy?
- Wanted: dead power mirror ECUs!
- Some Pictures of my SC
- Automatic 1j sputtering under boost
- Na-t or GTE swap ?
- Subtelty Increased...
- Timing Belt Change
- Auxiliary Switch
- Headlight Condensation
- new to the family
- Underhood insulation...
- Driver Side Window Problem *sigh* :(
- Tightening the shifter
- Black 99 SC300 For Sale In Atlanta
- My Wife says i'm obsessed...i just bought another Soarer
- Dashboard swap...tan to black
- Eau Rouge D1GP Soarer Pics & Video
- Stereo help please!! New owner!
- 1 out of 1 Lexus SC
- i need help. where can i get trim.
- picked up another sc
- mk4 exhaust
- Help me decide which dual exhaust to pick
- Topspeed Pro 1 exhaust is on!
- New Here Introducing my boy
- In the Shop..
- sc300 front lip
- Got into an accident today...
- humming/vibrating from engine bay
- Is this sc400 overpriced or what????
- Back from the Grave
- New Motor and Trans Mounts..Cures what ails you
- How do you remove the headlights? too much water building up in-side time to clean it
- 1JZ ecu pinout, help me identify this
- Adjusting DOOR?
- EGR delete sc400??????
- supra clutch pedal assembley
- New pics of my soarer and my friends sc300
- Looking at replacing body parts on my SC...questions
- Lexus Sc advertised on web site in Naples, FL
- Sunroof problem, a lil help please
- Does Anyone Know Of A Cheap And Easy Way...
- MK3 Supra Rotors and Calipers swapped to my 92 SC300
- spec of sc needles?
- sc300 is300 gs300 2jzge vvti?
- Converting my corners into fogs...but how does the parts look like????
- R154 trans question
- Going to look at an SC tomorrow, need some input
- Another.."Hey Someone Stupid hit my car" Thread..
- Manual sunroof retract?
- Are there more than 1 type of Soarer ECU's?
- Front Main Seal, are the GTE's the same as the GE's?
- 97 sc400 FS/FT.. North Jersey
- 2jzge vvti noob questions
- will these rims and tires fit?
- Fuel dampner line to fuel rail LEAK!
- info on tq ratings (when choosing a clutch)
- Keep the JDM dual exhaust or go single? Pics..
- anyone ever blown their engine??????
- 1993 SC keys screw keeps falling out! DEFECT?
- Door courtesy lights and seat memory not working
- Need help
- Fuse for climate control keeps blowing out?!
- Looking to replace tires...stock size
- is there a fuse for the dome lights?
- Potholes
- Check your trunks.... before its too late.
- What Is This For?
- Gauge needle repair?
- EBAY headlights
- Crazy screeching sound from under the hood. ABS?
- K&N or A'Pexi
- Removing "Lexus Phone" transceiver and controller from SC300 trunk
- Annoying misfire at idle
- 6262 billet, or hybrid twins for 450whp?
- ground, tps? I'm stumped
- the worst mod ever thread
- Got Hit!!
- pics
- soarer 2 step
- my attempt to duplicate fireball mega look
- Misfiring...
- Fifth Gear: Tiff drift challenge in Toyota Soarer
- My Super Duper JDM tight weighted shift knob yo
- Installed Black Emblems today
- A few exterior upkeep questions
- 2jzgte auto gear box
- Rear passenger side scratching Noise!
- Antenna Mast werid problem
- Quality aftermarket headlights. Which ones?
- Formula Drift Thailand Toyota Soarer UZZ30 with 1UZ-FE
- Clutch?stays down when I leave it in gear to long with the clutch engaged
- windows and sun roof
- Just some random questions....
- CarPCs are easier than you think!
- Power steering issue
- steering wheel woodgrain?????
- question about steering rack
- sc400 front seat upholtery
- 4URXTC plans.....
- Is this a good price for a 5spd swap for my SC400?
- Remote for 95 sc400, anyone gotten a hyqwdt -c to work?
- sc breif appearance in gone in 60 seconds?
- gold sensor on top of engine?
- 96 SC300 - Door/wood rattle..
- Mini sunset photoshot
- The Bad Photoshop Build Thread
- New wheels for my car...... again
- Have to part with my 97 manual 5 speed
- The 2 SC'S from Last Nights Meet
- Help me identify these please...
- motor swap help
- car won't turn on...
- My First SC400 with Pictures
- SC300 oem headlight, polish before and after.
- Decision time
- just sold my 1jzgte sc
- 92-94 sc corner light to foglight idea
- Turn signals, high beams, radio not working
- rear differential swap cost
- My first and final photoshoot
- sc400 cornering lights.
- Where to buy Clutch kit?
- Please Help Me. Big Speaker Problem.
- Grab yourself a cheap sc400
- A minor rant.
- LSD question
- cant take no more!!!!!
- sc400 1jz Help!
- Temp Gauge Problems
- Finally got me some wheels! =)
- car has like a bounce feel to it
- Wiring harness relocate from wheel well.
- What Kind Of Shift Knob Do You Have?
- thermostat
- Tranny cooler question
- Sc400 shuts off and drops rpm only at 2000 rpm???
- Radio self turn-on
- VIN Info
- 10w30 or 5w30???
- Build Color Options
- Foglight Question, is this normal?
- high pitch squeeking
- fair price for '98 sc300?
- Pulling codes on a 1997 SC300??
- Icecapades - SC Style
- Cool Japanese Comparison Video - 4.0L, 2.5GT, 850i, Legend
- Can I beef up the new window regulator to keep it from breaking?
- Shift solenoid from sc3 auto fit in Sc4 tranny?
- My Pursuit of Perfection PART 2. 2nd Photoshoot Pictures Inside
- Does Anyone Know The Difference Between A IS300 Airbag And A LS430 Airbag?
- 1998 sc300 auto-manual swap! HELP!!
- 1998 sc300 intake??
- ?? about saw blades
- My "Mini-Me" HPI R/C Car Build Thread
- valve cover gasket, rack bushings, steering line help!!!!!
- behrman lip or tt wheels?
- Sheilded wires-extending knock sensor wires?
- Any answer? Key Question?
- Been laying low for a while, now i'm back..new paint,new wheels...etc
- destroyed the rear of my car
- Newb Question
- Really need help. Hopefully last issue!!!!
- Hello newbie
- All dash warning lights on
- staggered or unstaggered?
- Krazematik Sold his SC400
- Help!!!:How much would you pay for this SC400.
- Any body knows a way to adapt hids or bright yellow lights on the 92 turning lights
- SEM tan paint??
- Drag DR-19's and Lug Nuts
- HID Lights and Bulbs
- Suspension qustions
- Alternator issue SC400.
- Will this downpipe fit
- Another SC300 with 315/35R17 Tires Picture Thread
- Color Matched Vinyl?
- jdm 2jzgte swap question regarding wiring
- Tail Light Issue
- Poly bushings distributor info
- *Fitment*Ebay 1jz Y pipe
- All aluminum radiator
- Need help with 1JZ body plugs
- 1jz vs 2jz
- RIMS questoin 18X10 +25 all around?
- Quick Photos--Supra TT springs/ Saleen Wheels
- 1992 Sc300 With Smoke Problem
- JDM suspension
- 2jzgte swap question regarding time
- Not sure what's up...
- Need some advice
- High beam replacement
- parts needed for auto -> r154 manual conversion
- Is this a good body kit to get
- CD Player
- drivetrain ??? driveshafts and pedals
- 92 SC300 Hypersilver XXR 521 18 x 10 +25 all the way around
- SC400-supra TT diff ?
- Stock sub enclosure
- 3 Way Components Speakers?
- Its been awhile CL
- looking a foglight mod
- ISF pedals on SC300???
- Ignition or something else?
- looking for a sticker.
- Will 92-95 taillights fit a 97?
- First steps towards sc400 R154 conversion
- Where are all the knock off vertex ridge kits gone?
- What every SC owner should do!
- MAF Question
- antenna issue
- Changed my Dash LED's....opinions
- bulbs
- OEM Power Steering Hose for $660 or Braided Stainless Steel for $65
- bellhousing question
- What should I buy????? Strut suggestions
- dropping tranny
- Donate a dead Fuel Pump ECU / what were your symptoms?
- I bypassed my fuel pump ECU. What now
- What hose is this?
- SC300 1995 Emblems
- "Premium" Sound system?
- 2jz GE vs GTE
- wth??? aem ems only for m/t?????
- part number?
- Off Throttle Jerk, On Throttle Jerk
- Potentially Stupid Question
- federal tires?
- SC400 Fuel Pump ECU Check
- my car is ready for turbo and i want opinions.
- why are my mirrors auto dimming
- *new* trunk lifts a little bit to long to snapon!!
- opinion on 1j fuel rail
- Radio help!
- Guys looking to go NA-T
- Stereo Wiring - 0gauge wire?
