- Supercharging a 96+ SC400
- NEED an ECM.
- How do I not Overfill the Tranny Fluid???
- Did an A/C test....
- one cam is off by 1 or 2 teeth
- Automatic transmission
- How to mount a blow off valve BOV
- 96' sc300 oil questions???
- new with sc's help. manual motor swap
- how much does it cost to switch auto.to manual?
- gte auto ecu into 5speed
- PSP replacement 1992 SC400
- 2JZGTE Aristo Swap in SC400 - A/C Problem
- does anyone know ?????
- vsv for evap?
- question about checking engine codes
- steering problems
- Need trans help
- 1jzgte in 96 sc obd2
- Need Advice: Noise at low RPM's
- Installing boost gauge
- gte into 5 speed
- na build
- SC300 Revving like I was tapping on accel
- I Want To Swap My Motor, Seached Forever, Need Help On Wiring A 98 Sc3
- 92-95 Sc300/sc400 Obd1 Code Retrieval
- sc300 auto to manual 1jzgte
- 2jz-ge and nitrous questions...
- Two Videos Of My Boosted SC300
- Need help. Car is dying..
- SC300 hard shift problem after valve cover gasket change
- What 1JZ manifold are you using?
- Wtf Ac?
- I'm at a total loss here...
- Head Off, anything recommended
- i think my car is possessed ...
- wiring schematics (engine harness) for 1992 sc300?
- 6speed getrag question
- no wheel power?! HELP!
- SC400 Auto to Manual Conversion?
- A/C Fuse? A/C not working
- Car not starting
- 1JZ w/ SC stock Auto Trans
- My r154 1J project
- Clutch Recommendations
- O2 Sensors
- Passing smog test after mods?
- My New 92 SC400 - Pictures & Info - WHAT YOU THINK?
- AC question for Las Vegas heads!
- stumped, and no engine codes :(
- New to the sc300 and 2jgte world.
- Poll: Should I keep waiting on the EKT headers?
- gte exhaust manifold into ge
- heard of nagano japanese.com swaps?
- Just hit 100k
- Simple Drive Belt/Maintenence Question
- Hey New to th Sc forums Need HELP please...Check engine light...
- Sc300 Transmission and amsoil
- new motor, louder than last.
- auto loc wiring question????
- New axle back mufflers from Megan
- SC300 Clutch torque specs
- Bearing
- Can anyone tell me what these wires are for?
- Car wont start...NEED HELP!
- Turbo Manifold, Intercooler, Downpipe outa paint shop!
- Pulling cams help
- will the SRT mani w/ turbonetics 60-1 hi-fi clear distrubuter?
- ABflug single vs Junction Produce dual
- Not Another SC300 GTE Transformation
- Engine Hoist
- Another Bad Idle Issue
- GMB replacement water pump --- different from stock
- TT Supra engine mounts on a '92 SC300
- Can anyone hear fuel pump whine through speakers?
- a/c problem
- considering motor swap need help/opinions
- Your Opinion on this 1JZ motor Please!
- Sensor On block
- HKS Hi Power Exhuast Question
- Parts Needed
- Small electronic problem. Please help.
- 92SC3 bought two months ago, broke down, time for a tuneup
- Any experience with Meagan Racing seats?
- Help! Head Bolt Size
- Bfi V4?
- auto to 5 speed
- Want to see pics of Apexi WS2 on SC
- Installed new exhaust, now have some hesitation. WTF!
- 1JZ flywheel and 7M clutch
- Serpentine belt slipped off after wipeout
- What wastegate mm are you 1UZ turbo guys using?
- My latest Mod...thanks to jdmjzz30
- a little scared, need help (Timing Belt 2JZ-GE)
- Sc400 Rpm ????
- Transmission clinking/bucking occasionally
- Clutch Master Cylinder
- Interesting. I don't get my fuel economy at all
- New exhaust on my 1jz SC 4" hotness (no56k)
- Would someone please let me know (Correct Socket Size for Plugs)
- Building oil pressure --on a fresh re-build GE
- Crashed 1JZ MKIII Now drop into sc300
- Increasing power with out turbo
- No Oil Pressure!! Na-t Sc300 Build
- SC300 Climate Control Issues...
- Help! GTE swap w/6spd question...
- My new exhuast...HKS Hiper
- CEL code P0420...a little perplexed
- Forced induction fan? hlp plz
- Best places to get a 1JZ Soarer Engine clip ???
- pulstar pulse spark plugs
- She is almost ready to be unleashed
- Very strange problem.... help guys!!!! did search
- radiator blew!
- NA rebuild-- Copper Spray on OEM HG?
- 98 sc400 with dead throttle
- Wierd Occurance
- Coolant splatter from Fan/Water pump Pulley *PICS*
- Super crappy idle, car shuddering?...
- 2jzge from a Gs300 to a Sc300
- Car won't start.
- Tranny tunnel cutout r154 swap
- question about a 1jz im thinking about getting help please
- Low Coolant Light
- Need to replace my clutch
- 1998 - 2000 SC400 Differential Ratio
- what part is this ?(2jzgte)
- Who has the best price for SC300 motor mounts?
- intake manifold for a 96 sc300
- need help sc 300 (muffler ???)
- sc400 stalling
- water pump
- Need some input on this please.
- 2JZGTE oil pan question
- Coil Pack Inspection and Turbo Blanket FAQ
- Weird thing happened today (infamous electrical ghosts)
- best exhaust for sc300
- SC300 Na --> TT Swap, INSTALL ANYONE!!!!!!
- Map ECU2 vs AEM FIC?
- greddy BCC adjustment on a 1jz
- BG 44k Complete Fuel System cleaner
- 2JZGE crankshaft journals
- extending the 1jzgte knock sensor?
- Good or bad?
- Those with low or erratic idle READ!
- Trans flush questions
- What is this & can I remove it?
- 5spd question
- How Would the SC look with these exhausts tips?
- Transmission Problem
- If my 1uz is blown...
- Swaping Motor
- 2 quick questions aristo gte swap
- aristo WIRING help
- Aight, I'm gonna do it: Single.
- something is wrong with my car please help.
- Another stumper?
- Tearing down 2JZGTE and questions with pics
- Transmission Advice
- DO I have a soarer 1jz?
- 94 SC300 A/C & HEATER blow same air temp
- I may have killed my car. Help please!
- Synthetic Oil Benefits?
- Ugly radiator support trim replaced
- PLEASE HELP....2JZGTE harness question
- Secondary cat neccessary?
- GS300 Catback on an SC300???
- Leak...maybe water pump?
- A/C electrical problem doesnt work. NEED HELP!
- Blown HG on a 92 5-spd -- fixing it right
- AC Clutch
- driveshaft U-joint replacement
- will these motor mounts fit our car?
- Check out the new exhaust! with Pic's!
- tranny question
- NEW AND IMPROVED Exhaust poll thread
- Help with idle problem
- I was on dyno today.... and.....
- Exhaust Set up Poll!!!!
- sc400 overheating pls help.
- any problems with this idea?
- heating system doesnt work
- $250 Exhaust Pics
- SC400 o2 sensors same as LS400?
- MAP ECU Users
- 2jzgte manual instead of auto
- Some pics of my starter replacement.
- sc300 basic info needed for 2jzgte swap
- Negative effects of exhaust leak?
- where is the fuel filter?
- vaf sensor circuit code 31 on a lexus help
- SC300 MT -engine removal --with trans or not?
- short shifter
- Automatic Transmission Swap
- EGR woes.
- Turbo Rebuilt By Turbonetics
- intake and ecu
- See What Came In The Mail Today!
- major problems, please help
- 95 sc 300 8000 miles tranny problem
- Woo Hoo! Failed my inspection!
- Machine Shop work
- Smoke
- Strange operation question
- Overheated, coolant leaked a whole lot, and now wont start
- Options for rebuild of stock 1JZ twins
- Starter location?
- any idea on howto take this plug off?
- 1993 SC300 - When to replace timing belt
- nakamichi 12 disc CD changer question.
- Weird problem... Trac and idle
- Dumb Dumb me..Can u help me with timing?
- Boost and Transmissions?
- quick question on lsd
- sc400 overheating problems, please help
- Newbie just inherited my first SC and I need help
- Valve cover gasket job
- Compatible engines for swap?- SC300
- biggest fuel injectors for stock fuel rail
- Year of my 2jzgte??
- Little help? My SC300 is dying...
- maybe a dumb question, but...
- Severe Idle Problem...Please Help
- HELP: Check engine light just came on! what could it be? how 2 reset?
- na-t piping question
- sc400 odd running problem
- Special Service Tool - where can I get one?
- Can I use 87 gas with a 1.3mm head gasket?
- Has this happened to anyone? PS pump
- What to do
- Ran her at the track today....
- first time at track 95sc400
- How to remove auto-transmission cooler hard lines
- sc300 chips
- Time lapse build
- Cap and Rotor
- 2jz questions...
- Quick Question
- NA supra tranny in my sc300 1jzgte missing a OD sensor??
- timing belt mantainence
- Blow off valve BOV mounted pic request
- What intercooler for a 1jz?
- Just ordered my R154 1J!!
- SC400 engine vibrates when accelerating?
- Pre 95 and 95+/Supra W58
- Manual tilt override??
- sc300 aristo 2jzgte swap wiring?
- What is this on my 2jz?
- What parts are missing from my 1jz bell housing?
