- Major pulling R or L during heavy acceleration
- ML Amp Blows its 30 amp fuse
- 2020 RX350 paint peeling on hood
- Upgrade Your Lexus RX with a 12.3-Inch Lexion Infotainment Screen
- Squeaking noise when switching dual climate control
- What is this wire in front panel driver’s side for?
- Mushy and creaky steering wheel volume buttons
- 2016 RX350 rear ended
- MPG display freezes at times
- Rear windows not working
- Exhaust like odor when accelerating
- TPMS Caution Threshold
- 2018 RX350L Rear Liftgate Strut Part Number Question
- 2020 RX 350 inform remote trouble
- HUD update?
- Cool upgrade trim/parts for 4G RX 350.
- 2017 RX350 rough idle and check engine light
- What is the purpose of the oil filter clip?
- Hi beam issues
- Any Brake Difference on RX-350 F Sport?
- Swap/extend armrest USB with dash?
- Lower control arm bushing leak? Help
- 2020 RX350 vibration while shifting
- Thump when traveling about 65-70
- To buy or not to buy 2018 RX350?
- 2020 RX F-Sport Intermittent Rattle
- '19 RX350 Electrical problems...
- Vent setting changes from the last setting...
- CD player screen "CUSTOMIZE"?
- Footwell Lighting
- What is this part in cargo area?
- How do I tighten rearview mirror 2018 RX350
- Used RX 350 different color door what are my options?
- Temperature display way off
- Yes, RX 350 F Sport Is Noisy
- RX Gear Shift Knob upgrade or modification
- Headlight short
- Chrome delete for exhaust trim on 2021 RX
- Rotating/Rubbing noise when turning left
- Takes long time to turn on headlights while in auto mode
- 2018 RX350 F-Sport Passenger Door Damage and Edge Replacement
- Considering a Cpo 2021-2022 Rx 350 or 350l
- USB Flashdrive Music Issue
- RX 350L insulation piece missing?
- Dim Dome Light
- 2016 RX350 Wiring diagrams needed
- Shift indicator lights not working, any ideas?
- How to turn off the Mobile Assistant?
- Glove box light turns off after about 15 sec?
- Actual Cash Value 2020 RX450h - Is it a total loss?
- "Door" Button on the ceiling?
- Remote Start from Lexus App Problem
- Turn signal/hazard relay location?
- RX350 2018 Firing order?
- 2019 RX350 Lube Door Hinges/Latches
- Sport Mode Question
- trunk lid too sensitive
- Won't start after oil change
- Rear cup holder removal
- Tundra throttle body on RX 350
- Mark levinson question
- 2016 RX350, 46k Miles - Am I overpaying?
- Steering wheel squeaky noise
- 2020 F-Sport passenger front wheelwell trim part number
- RX350 - RPM is fluctuating crazily UP and DOWN
- Lexus RX 350 Plastic Hanging from front
- Center console started splitting, any suggestions?
- Part number for the driver side fuse box cover
- Looking To Replace My 2007
- Used Lexus RX 2017 with CarMax extended coverage
- Seat Warmer & Park Break Removal
- 2021 RX 350 crackling noise from panoramic roof
- Is it possible to change the oil and filter without ramps?
- Can't connect my iPhone to carplay
- What size cable port to run Android Auto?
- Ignore popup message without using mouse
- Experience replacing headlight washer cover?
- 2019 RX350L noise when starting
- Used RX 350, can I please have help with the year?
- Part number for back seat release lever
- Hooks below glove compartment?
- Power Gate Issue
- 2018 F Sport or 2020 Luxury
- New F Sport emblem
- Question? Anyone seen this problem? Engine Check & ICS Malfunction
- Restart the system to protect the battery of the car message?
- Accident repairs on my 2020 lexus
- Looking at 2017-2020 RX
- Suspension alignment on a '22 non-F
- Microphone?
- Lexus RX 350 modded drive by
- Front Passenger Door Lock Knob Bezel Replacement
- Driver side airflow vents -weak 2017 Rx 350
- '16-'22 RX 350 20" Wheel Charcoal Paint Code
- Palm rest/storage
- Can't upshift from steering wheel controls?
- What does Base F mean on my 2018 RX350
- Fender damage
- 2021 RX350 Taillight - identify part
- Have you repaced your wheel locks?
- 2022 RX350L seat bolsters??
- Sun Strip Tint
- Searching for a 2021-2022 RX
- F Sport AVS System Question
- Two Separate Displays
- L/ certified but bad shape?
- 2016 RX 350 - Parasitic Battery Drain
- Front brake discs are too hot
- Hard Shifting From P To D In Morning
- Passenger side storage
- 21" wheels on 2022 RX?
- Precut tail light tint for 4RX w/ triple beam option
- P0430 help!!
- Mystery Remote starting
- Lost Sport+ mode on 2017 RX 350 Fsport
- Anyone have TRD body kit or exhaust?
- 2018 Rx Cup Holder Question
- Is there a way to turn off the Green lights on the cluster ? BSM park assist etc?
- Was my windshield replaced?
- Wireless earbuds case and keyfob issue
- 2017 RX450h wiring connector behind cowl
- Sway bar bushing replacement?
- Worn sway bar bushings?
- Loose cable under drivers seat goes nowhere
- Locked out of RX350, keys not working
- Is this rear center headrest piece replaceable?
- 2018 RX 350 Passenger seat won't fully retract
- Looking for advice/comparing two RX’s
- Windshield camera fog?
- 2013 vs 2022 rx350
- Android Auto connects sometimes
- Android Auto ?
- Front struts replacement: torque specs and tips?
- A Woman in Desperate Need of Advice buying used car
- adapter to make wired iphone connection wireless
- loud rain noise on my 2021 Rx450h
- Loud Annoying Noise in reverse
- Tuned RX 350 F sport 2019
- weird cupholder issue with 2022 RX
- Ticking Sound Steering Wheel
- Rear door window / glass removal / replacement?
- New to Lexus: 2021 RX350L Maintenance Costs?
- Recall for Air Bag Sensor?
- Display shows a picture of a sd card
- Need help 2022 RX350 less than 20k miles multiple alerts
- 2016 RX350 AWD - Front Suspension feels loose
- Soft Dinging Sound
- Collision repair schematics???
- Looking to buy 2018 350L - carfax shows sketchy service internals - can computer help
- Can anyone ID this chirping noise?
- Leather Patch
- 2020 F Sport 3 Towing
- 2022 Rx350 - Looking to purchase used - should i be worried about exhaust drone noise
- AC Compressor Relay / Power - 2017 RX350
- Is this loud lifter or engine knocking?
- 2019 Lexus RX350 Moonroof/Sunroof Window Seal Number
- Sound of refrigerant moving
- CPO warranty-extended the time car is being repaired?
- 2019 Rx350 - Should I take it to Lexus for annual inspection?
- F sport transmission selector
- Weird Behavior - windows and door locks
- 22 Lexus RX 450 Rear Bumper Help
- ‘17 Intermittent knocking noise on passenger side
- Green light on air recirculation buttons and others doesn't light up
- How to enter destinations as geo-coordinates?
- Leaking Shift Shaft Seal
- Unlocking doors issue...possible gas cap door actuator malfunction?
- Key programming - 2022 RX350
- Revs high with cruise control on.
- Rear Seat Squeak
- Alarm goes off randomly in the night
- New Keyfob message on Display Screen
- Standard features of Safety 2.0+ package?
- Wind noise inside the drivers door
- Ignition coil looks overheated?
- Center Screen Making selections on its own
- Disable passenger seatbelt/airbag warning?
- Movement inside driver seat
- Intermediate Steering Shaft ??
- Ticking noise
- How to adjust navigation display?
- Frozen lock
- steering binding when on cruise control / lane centering
- What is this device installed on the dash?
- 350L Tow Package FWD only?
- Blur on the bottom of HUD
- CPO Rx question
- Got the 20-21 airbag sensor recall letter today
- Has anyone custom flash software on RX450h 2017 model?
- Replacement heat warmers
- OEM mag got trashed
- 2022 RX350 Engine Vibration After Oil Leak Fix
- Permanently disable faulting BSM?
- Vibration while accelerating
- 2016 RX350 - P0037 code
- Front Strut bar
- 2021 RX350 timing cover gasket replacement
- Wireless Android Auto & CarPlay for your Lexus RX's infotainment system
- Is height of infotainment system bothersome?
- Microphone failure
- Door opening while driving?!?! 2022 RX 350 F Sport
- Seats damaged by dealer (heating element)
- A/C cooling power on 2016-2018 RX
- Leaking from rear shock
- Struts/shocks, spark plugs covered under CPO warranty?
- 2017 RX350 Easy exit / shutdown issue
- Lease mile overages
- Backup camera image options (non-panoramic) for Gen 4 RX350
- Screen and radio frozen
- Is it Carplay? iPhone? Google Maps? Normal?
- Issues with windshield
- Metal Sound When First Backing out of Driveway
- Front sensor calibration
- Dealer recommends throttle body clean at 30,000??
- Really dead battery in cold - odd symptoms
- Creaking sound from roof
- Update mileage on MyLexus dashboard
- Things to look during test drive?
- Key not detected
- Problems downloading Lexus RX service history
- Where is the blend door actuator?
- Seat belt does not retract - 2016 Rx450H
- RX 350 F Sport Brake Noise?
- PKSB Light Flashing - '17 Rx350
- DCM Error
- 2017 Rx350 Oil leak fixed in Dec now radiator problem
- rear window defroster not working
- 2022 RX Shift issue in M mode
- Brake Pad Warning System?
- CPO 2021 RX350 F sport purchased but Now Lexus says it’s not a CPO
- Rx350-2020 Strange warning messages
- Used RX Dealer Discounts
- Update to Transmission Programming
- EPS steering wheel noise on start up for RX 350
- 2019 RX & Remote Start.....
- 2018 Back UP camera repair
- How to remove rear captain seat cup holder?
- TRD wheels on 4thGen RX350
- 2022 RX350 Bottom door trim replacement
- Sport Mode Transmission Issue
- Toyota Recalls Certain 2020-2022 Toyota and Lexus Vehicles
- TSB L-SB-0032-23 - Thank you
- Preferred Fuel Cap
- Shopping for a unicorn?
- Front Window Washer Aim Adjustment
- How to stop Spotify automatically playing iPhone 11 ProMax
- 2017 Rx350 won't start
- Alignment Fnt Camber@-1.4 and -1.2
- Looking to purchase Lexus RX 350 2020-2022
- How to restore apps?
