- Is this headlight stable?
- Wipers
- Lexus Gx460 not reversing
- Shaking in very low speed in reverse
- P0705 came up right after gas fill-up
- Best rims and tire combo that fits still fits in the spare.
- towing light failure
- Strange FOB issues since trying out the FOB remote start feature
- 2014 GX460 DIY replacing radiator, water pump, belt, belt tensioner, idler pulley
- JAOS Mud Flap Installation
- So Many Problems!!! SOS
- OEM Alternator rebuild?
- Leaking Radiator, Timing Chain Cover, and Coolant Valley Combo
- Consumer Report - GX460
- Luxury v Premium seat comfort
- Steering wheel / driveline vibrations - yes? or no?
- Had an LC Prado for a few months
- Tire size question
- New Potential GX Owner
- Pre purchase advice
- 2022 GX460 Passanger Running Board Lights Not Working
- 2014 Gx460 Leaning with error code C1731 r/f & C1732 l/f
- Big brake upgrade
- New '23 Owner : First Things to Do/Change?
- Discount for New 2023 GX460
- Stock badge placement measurements…
- Electronic cutout button for dash
- is there way to show oil/coolant/trans temperature on dash?
- CarPlay for 2015 GX460 with CarLinkLife
- Window Sticker
- Wheel Spacer Brand
- FITCAMX Dash Cam?
- Simplest GX Available
- 2012 gx coolant dripping from hose connected to top of radiator
- GX CAN Bus attacks/thefts?
- One Month Impression
- Can't stop Rattling
- Cargo Length with Second Row Flat
- What Can I Use To Not Show the Scratches on The Black Plastic?
- 2023 Rear Brake Smell
- Tip for looking up service history (Try the app!)
- 2023 Floor Mats
- Used 2023’s coming from California
- Connect GX to a different mobile hotspot?
- GX 460 Rear Brakes Dragging
- Stuck Parking Brake Release - Small Thud During Acceleration
- Maximize 2023 Warranty Before Mods
- My 2011 GX 460 Daytime running Lights won't come on!
- climate control button not working
- Rear rattle
- California immobilizer to prevent theft?
- How to display reading for Tire Pressure
- Roof Rails Cargo Box Suggestions
- Smart Access Disabled? - Key Fob Programming Error
- New 2023 GX460 Premium plus package
- Why are my brake pads wearing out so fast?
- Buying a Used GX460 in 2024 - long term issues?
- New 2023 GX and wheelspacer
- MY2022-2023 GX460 Dashcam PT949-76221 Installation Instructions
- 2023 GX460 Brake Upgrade
- Parking for a week outdoors
- 2021 gx460 all interior lights stopped working.
- GROM VLine VL2 / VLite VT2 for CarPlay Android Auto Group Buy
- Anyone have a lift with 20” wheels?
- 2016 Remote Start
- 2019 remote start “how to”
- Repair recommendations/estimate after oil change.
- Captains Chairs x Bench Seat Swap Finally Completed
- Throttle Controllers
- Drivers memory seat keeps changing
- Rust question
- BFG KO2’s PSI???
- Steering Wheel Controls Not Working
- 2019 GX 460 Luxury Sepia Leather Durability
- 2019 GX Luxury OFF Road
- Front Door Handle Question
- Bfg ko2 275/65/18
- GX460 Eibach lift anyone?
- Correct way to trickle charge battery
- Lock / unlock work but alarm doesn't make sound, courtesy lights are out (bulbs OK)
- "S-mode" questions for 2023 GX460
- Manual says you may/may not have jack handle. I don't in MY2023. Matter?
- Centramatic wheel balancers?
- GX Oil Pressure Light, Vehicle Won’t Start
- More elegant USB wiring solution for 2023 GX
- Warranty Question + Infotainment Upgrade
- Looking at 2017 GX but wondering about LX...
- Master Wheels Dealer for your Lexus! *Authorized Dealer*
- 3” Lift Options & Airbag Delete
- Name of plastic part over back window ‘11 gx460
- Yota Tune
- Missing DRL indicator on instrument panel
- Squeaking/Rattling Noise Indentified:Radiator Cover?
- My Introduction
- plastic part number
- Prado Lower Bumper Tail Lamps
- Power 3rd row conversion
- 2023 GX won’t start after sitting for a couple days
- PCS calibration template / Techstream instructions?
- Truly 'Base' Lexus GX460 - How Common?
- 4Lo and Check Engine Lights after fuel pump replacement
- 30K service (diff and transfer case)
- WeBoost Cellular signal Booster Install
- OK, NOW I can introduce myself...
- Prado 150 Tire Door Swap to GX460
- SMS/Text messages
- 2015 GX Luxury - Rough ride
- EBC brakes - greenstuff
- replace grille 2022 gx 460
- Black Line Tail Light Part Numbers
- Help LX600 Rims onto my GX460
- Vibration through steering wheel when under load?
- Chrome to Black Door Belt Molding
- keyless Entry Sensor
- Need help diagnosing rubbing sound
- Break In Period
- Random 4Lo Issue
- Bumper bracket identification gx2017
- Long term Fuel Trim
- New grill sensor error
- My '17 GX with 1.25" wheel spacers
- One of the front USB ports in our new 2023 does not work for CarPlay or charging
- 2023 GX460 Wheel Change
- Certification Price 2020 GX 460 Buying out lease
- Tailgate Latch Problem
- Fender Trim to larger tires
- Headlights Help PLZ - 2011
- Why is the Engine Fan So Loud on the 460?
- 2018 Gx460 alignment question
- OEM Foglights on GX460 - Are They Just 'Decorative', or Functional Add'l Visibility?
- Front turn signal lenses loose
- Production of the last 2nd gen gx...check
- Auto dimming mirror stopped working
- Attachment points for the plastic protective shield
- Auto dimming headlights
- Adaptive cruise control
- P0108 intermittent issue
- Rear door rattle
- It's deer season in PA
- GX460 Luxury Wheels
- Odd "ping" when turning steering wheel
- My Undercoating Experience
- Slip sliding away - rear carpeted cargo mat
- New GX !
- 2019 new owner Lexus app doesn't save vehicle
- GX 460 Luxury front-side and rear cameras
- Which drives better - Premium or Lux
- 4Runner Limited to 2023 GX460
- My 3rd GX Happy to be back
- Anti theft socket go bye-bye
- New 2023 GX - Normal noise on startup?
- Issues with my new gx460
- Replacement Sport Design Rear Valance Piece (Tow Hitch Cover)
- Steering wheel suggestions for GX 460 2023 Lux
- Tire and Wheel Upgrade
- Bolts Sticking Out in Wheel Well Fender Normal?
- Electrical Malfunctions -Triggered by parking brake? (VIDEO)
- Panoramic View Monitor Available on Non-Luxury Models?
- 2016 GX460 Head light issues.
- ‘23 GX 460 - tail lights
- Trailer Hitch Decision: Gen 2 Parts Availability for the future
- Possible paint defect in new ‘23?
- What general maintenance have/will you perform yourself?
- What is with the allocation of Captain's chairs vs bench seats?
- 2022 /2023 Proclip Mount?
- Remove door panel from the inside
- Bouncy ride after replacing air springs
- Accelerator pedal solution for short driver
- Will 4 tires fit inside? Pics?
- Any information on shocks
- Looking for Lift Kit installer for 2013 GX in GTA
- Rubber insert in front skid plate - what for ? Part Number ?
- Tire Pressure with Spare in the trunk
- Sway Issue at highway speeds and while accelerating
- 2011 smart remote starter and car play
- Lexus oil places to buy
- Windshield washer fluid leak
- Reading VIN through Windshield
- Anyone know the Part Number for the 7 pin trailer connector
- All Terrain, specifically Falken Wildpeak AT3W tires, noise
- Painted F sport lip kit?
- Adding park assist/parking sensors to GX? Is it possible?
- Thoughts of GX owner after owning a Model Y
- Is it Just Me ?
- Mobile 1 Advanced Fuel Economy vs Extended Performance vs Truck & SUV, anyone tried?
- Convert Captain seats to Regular Bench
- Body Side Moulding ls for 2023?
- Dome light Electrical gremlins
- Center Console Armrest Replacement
- CV Boot leaking with only 23K miles
- Should I return my Wildpeaks?
- Complimentary maint, diff oil
- Auto-darkening mirror repair
- Toyota Dealership Quote for Winters
- Coolant Level in Recovery tank
- Touch up paint
- Preparing for a Trip
- Lifting options for GX460 with air suspensions remain in place?
- Aftermarket Front grill with front camera
- Experience w/ ZZ-2TZ-GX-A Carplay vs. Beat Sonic?
- 2018 Sports Lip paint code
- Rotational Chirping Noise
- What is the wheel weight of the 18" wheel?
- 2022 Black Line matte wood steering wheel finish coming off
- Switched 12V / 30A terminal?
- 2023 GX has been at the dealer being worked on for 8+weeks
- 2013 GX problems
- 2013 GX problems
- Persistent GX 2nd Gen Brake Issue
- Trailer Extension Cable
- Magnaflow Overland Exhaust - looking for local member
- Lexus insists my 2019 GX has a transmission cooler
- Dts cd
- 3rd Gen impact to 2nd Gen
- New LASFIT, turn signal LED bulbs
- Rust Proof Planning ('23 GX)
- captain's chairs
- I'm gonna do the Timing Chain Cover Oil Leak repair myself. Got any advice?
- service on my 2016 GX
- Unconnected cable under dash id needed
- Seeking Help with Lexus GX 460 Traction Light and Shaking Issue
- Carpet Floor Mats
- Transit time question
- Wind and GX = Whoa!!
- Help adjusting OEM roof rack cross rails
- Power Stop K5874-36 Front and Rear Z36 Truck & Tow Brake Kit
- HELP. What is the part number for this piece?
- Open the rear door and/or window with a dead battery.
- Lexus app is opening when my phone is plugged in
- Hard or long start
- Viair air compressor fittings help
- Backing Assist Lines
- Best replacement radiator for 2012 GX?
- Clunk when shifting into Drive or Reverse from park. 2022 GX460
- Engine start stop door lock volume knob
- Wheel Offset
- Any Coloradans up for some 4-wheelin’ this holiday weekend?
- 2017 GX460 Tires and Wheels
- Google assistant stopped working properly
- 2014 GX460 2nd row seat
- OME MT64 shocks
- Apple Carplay over bluetooth?
- Bought a “Throttle Response Controller 9 Drive Modes” from Amazon - quick review
- 2023 GX hood movement
- Car Washes
- Any reason not to buy a '22 GX over a '21?
- Need help with back-up lens replacement
- 2011 head light assembly replacement advise
- Completely disable pre-collision system on 2023 GX460?
- Upsize Tire Options for 19 inch Sport Design Wheels
