PDA
View Full Version : GX - 2nd Gen (2010-2023)
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20
  1. Crack on running board
  2. Is this a valve cover gasket leak?
  3. Traction control light on after alignment check
  4. Widest tire size for stock wheels
  5. OBDII Scanner hook up during alignment?
  6. Help with service records needed
  7. #Sagging rear
  8. Fumoto Oil Valve, long or short?
  9. 2022/23 - Make screen display radio AND #Android Auto/ #Carplay
  10. 2021 backup tone - can it be muted?
  11. Easy and cool engine bay light mod... Only 15 min and $20
  12. Seat Refresher seat always on...even with new switch
  13. Small Leather Repair Suggestions
  14. Dealership or Recommended Mechanic? 2016 GX 460
  15. GX460 Maintenance Schedule After 150K?
  16. Transmission drain-n-fill
  17. 2010 GX Hitch Questions
  18. Look at your odometer. Don’t do service yourself?That’s the age of your #oil #filter.
  19. Leak
  20. PowerStop Z36 cross-drilled/slotted rotors and carbon-fiber pads?
  21. 14mm hex nut appears from nowhere when removing engine under cover
  22. Mechanical drone/whirring sound above 65mph
  23. Mystery trim piece (Driver’s side door area)
  24. Replacement for the 2010 USB/Aux
  25. Codes B15DF and B1585 on 2011 GX460
  26. Bouncing rear issue
  27. Door Panel - year to year fit difference?
  28. TRD 17in wheels for 2021 GX460
  29. Recommended Oil for 2019 GX460
  30. Captains Chairs gap filler
  31. 2012 No Nav Review (not in English)
  32. Fog light upgrade with Diode Dynamics SS1s
  33. Recs for keeping leather driver's seat intact? ...
  34. 2010 GX460: Grom VLine vs Beatsonic vs ??
  35. What apps fully support 2022+ years?
  36. anyone know what part number this would be
  37. Programming - Re-Programming
  38. Potential new 2010 GX 460 owner - Need some advice
  39. New Member Weird? Question
  40. #ATRAC without #MTS
  41. Please check Lexus Park Assist.
  42. Peachpass 2023 Windshield
  43. Mexican Gasoline GX 460
  44. Redarc tow controller in 2023 luxury
  45. Curt Folding Hitch Carrier
  46. Seat covers including second row captains
  47. Thoughts after 6 months of ownership
  48. Lug nuts with aftermarket wheels
  49. Very Slight #vibration / #shake at startup idle '13 GX
  50. GX460 cabin air circulation path
  51. Metal #Oil #Filter #Housing Conversion
  52. Front Cupholders
  53. Help from Wisconsin. (before I trade in my 23' GX for a LC 250)
  54. Finally Convinced the Wife!
  55. 2018 GX shaking
  56. Discolored Rear Window Defroster
  57. Best Rotors
  58. 2022 GX passenger front suspension noise
  59. Floormat anchor clip removal?
  60. 2010-2013 GX 460 #LED #Headlight Upgrade
  61. Rear quarter glass broken
  62. Low Profile Bolt
  63. 4lo and rear diff lock lights on
  64. Strange sounds from my 2016 GX
  65. Upgrade screen to 2022
  66. 2010 GX460 Glove Box
  67. 2022 Premium Fog Light fuse change now no dome/keyfob etc
  68. 2023 Factory Fill Oil. #Synthetic
  69. 4Runner Llimited Wheels/Tires on GX460?
  70. GX460 (2016) Rear window unlocks when locking car
  71. Wireless #Carplay #Android Auto interface upgrade module
  72. 2023 GX460 lurches forward when stopped
  73. 16 GX460 Lux suspension code issues
  74. 2023 GX sport design front grill piece removal
  75. Fairfield County, CT Installer
  76. grinding sound when almost stopped while brakes are in good shape
  77. Towing: Luxury Air Suspension & WDH Combo
  78. 2023 GX CarPlay issue
  79. Lexus gx no reverse gear
  80. Bow/Stern lines for hauling kayaks 2019 GX
  81. CEL / Trac Off / 4LO blinking -- P0761 P2714
  82. 2021 Gx 460 Transmission Fill
  83. New Belt, Tensioner, WP and not LOUD Screach at Startup
  84. GX SUV Cover for weekend outdoor protection?
  85. "Computer Reprogrammed" on CarFax
  86. Lightly modified city GX learnings
  87. Auto Start, engine stops when door opens
  88. New Pro Clip for 22/23 GX460
  89. 2015 GX 460 Squeak from back
  90. normal RPM when driving on highway
  91. #CarPlay #Wireless Adapter bakeoff ( #Ottocast U2-AIR Pro vs. #Carlinkit 5.0 (2air)
  92. lower front plate bracket
  93. 2021 GX 460 Gotchas
  94. Your One Stop Lexus Parts Dealer!
  95. Popping or clicking when using car play
  96. Toyota 50/50 vs #Zerex and other #PHOAT #coolants
  97. Idle bouncing around at stops. No codes being thrown. Anyone else?
  98. new #coolant hose with dent/scratch on it
  99. Rear #Parking #Sensor Phantom Beeps
  100. Rear cargo space measurement (length)
  101. 2018 - 2020 GX ML Sound
  102. Is this headlight stable?
  103. Wipers
  104. Lexus Gx460 not reversing
  105. Shaking in very low speed in reverse
  106. P0705 came up right after gas fill-up
  107. Best rims and tire combo that fits still fits in the spare.
  108. towing light failure
  109. Strange FOB issues since trying out the FOB remote start feature
  110. 2014 GX460 DIY replacing radiator, water pump, belt, belt tensioner, idler pulley
  111. JAOS Mud Flap Installation
  112. So Many Problems!!! SOS
  113. OEM Alternator rebuild?
  114. #Leaking #Radiator, #Timing #Chain Cover, and #Coolant Valley Combo
  115. Consumer Report - GX460
  116. Luxury v Premium seat #comfort
  117. Steering wheel / driveline #vibrations - yes? or no?
  118. Had an LC Prado for a few months
  119. Tire size question
  120. New Potential GX Owner
  121. Pre purchase advice
  122. 2022 GX460 Passanger Running Board Lights Not Working
  123. 2014 Gx460 Leaning with error code C1731 r/f & C1732 l/f
  124. Big brake upgrade
  125. New '23 Owner : First Things to Do/Change?
  126. Discount for New 2023 GX460
  127. Stock badge placement measurements…
  128. Electronic cutout button for dash
  129. is there way to show oil/ #coolant /trans temperature on dash?
  130. #CarPlay for 2015 GX460 with #CarLinkLife
  131. Window Sticker
  132. Wheel Spacer Brand
  133. FITCAMX Dash Cam?
  134. Simplest GX Available
  135. 2012 gx #coolant dripping from hose connected to top of radiator
  136. GX CAN Bus attacks/thefts?
  137. One Month Impression
  138. Can't stop Rattling
  139. Cargo Length with Second Row Flat
  140. What Can I Use To Not Show the Scratches on The Black Plastic?
  141. 2023 Rear Brake Smell
  142. Tip for looking up service history (Try the app!)
  143. 2023 Floor Mats
  144. Used 2023’s coming from California
  145. Connect GX to a different mobile hotspot? #Wifi
  146. GX 460 Rear Brakes Dragging
  147. Stuck Parking Brake Release - Small Thud During Acceleration
  148. Maximize 2023 #Warranty Before Mods
  149. My 2011 GX 460 Daytime running Lights won't come on!
  150. climate control button not working
  151. Rear rattle
  152. California #immobilizer to prevent theft?
  153. How to display reading for Tire Pressure
  154. Roof Rails Cargo Box Suggestions
  155. Smart Access Disabled? - Key Fob Programming Error
  156. New 2023 GX460 Premium plus package
  157. Why are my brake pads wearing out so fast?
  158. Buying a Used GX460 in 2024 - long term issues?
  159. New 2023 GX and wheelspacer
  160. MY2022-2023 GX460 Dashcam PT949-76221 Installation Instructions
  161. 2023 GX460 Brake Upgrade
  162. Parking for a week outdoors
  163. 2021 gx460 all interior lights stopped working.
  164. #GROM #VLine VL2 / #VLite VT2 for #CarPlay #Android Auto Group Buy
  165. Anyone have a lift with 20” wheels?
  166. 2016 Remote Start
  167. 2019 remote start “how to”
  168. Repair recommendations/estimate after oil change.
  169. Captains Chairs x Bench Seat Swap Finally Completed
  170. Throttle Controllers
  171. Drivers memory seat keeps changing
  172. Rust question
  173. BFG KO2’s PSI???
  174. Steering Wheel Controls Not Working
  175. 2019 GX 460 Luxury Sepia Leather Durability
  176. 2019 GX Luxury OFF Road
  177. Front Door Handle Question
  178. Bfg ko2 275/65/18
  179. GX460 Eibach lift anyone?
  180. Correct way to trickle charge battery
  181. Lock / unlock work but alarm doesn't make sound, courtesy lights are out (bulbs OK)
  182. "S-mode" questions for 2023 GX460
  183. Manual says you may/may not have jack handle. I don't in MY2023. Matter?
  184. Centramatic wheel balancers?
  185. GX Oil Pressure Light, Vehicle Won’t Start
  186. More elegant USB wiring solution for 2023 GX
  187. #Warranty Question + Infotainment Upgrade
  188. Looking at 2017 GX but wondering about LX...
  189. Master Wheels Dealer for your Lexus! *Authorized Dealer*
  190. 3” Lift Options & Airbag Delete
  191. Name of plastic part over back window ‘11 gx460
  192. Yota Tune
  193. Missing DRL indicator on instrument panel
  194. Squeaking/Rattling Noise Indentified:Radiator Cover?
  195. My Introduction
  196. plastic part number
  197. Prado Lower Bumper Tail Lamps
  198. Power 3rd row conversion
  199. 2023 GX won’t start after sitting for a couple days
  200. PCS calibration template / Techstream instructions?
  201. Truly 'Base' Lexus GX460 - How Common?
  202. 4Lo and Check Engine Lights after fuel pump replacement
  203. 30K service (diff and transfer case)
  204. WeBoost Cellular signal Booster Install
  205. OK, NOW I can introduce myself...
  206. Prado 150 Tire Door Swap to GX460
  207. SMS/Text messages
  208. 2015 GX Luxury - Rough ride
  209. EBC brakes - greenstuff
  210. replace grille 2022 gx 460
  211. Black Line Tail Light Part Numbers
  212. Help LX600 Rims onto my GX460
  213. #Vibration through steering wheel when under load?
  214. Chrome to Black Door Belt Molding
  215. keyless Entry Sensor
  216. Need help diagnosing rubbing sound
  217. Break In Period
  218. Random 4Lo Issue
  219. Bumper bracket identification gx2017
  220. Long term Fuel Trim
  221. New grill sensor error
  222. My '17 GX with 1.25" wheel spacers
  223. One of the front #USB ports in our new 2023 does not work for #CarPlay or #charging
  224. 2023 GX460 Wheel Change
  225. Certification Price 2020 GX 460 Buying out lease
  226. Tailgate Latch Problem
  227. Fender Trim to larger tires
  228. Headlights Help PLZ - 2011
  229. Why is the Engine Fan So Loud on the 460?
  230. 2018 Gx460 alignment question
  231. OEM Foglights on GX460 - Are They Just 'Decorative', or Functional Add'l Visibility?
  232. Front turn signal lenses loose
  233. Production of the last 2nd gen gx...check
  234. Auto dimming mirror stopped working
  235. Attachment points for the plastic protective shield
  236. Auto dimming headlights
  237. Adaptive cruise control
  238. P0108 intermittent issue
  239. Rear door rattle
  240. It's deer season in PA
  241. GX460 Luxury Wheels
  242. Odd "ping" when turning steering wheel
  243. My Undercoating Experience
  244. Slip sliding away - rear carpeted cargo mat
  245. New GX !
  246. 2019 new owner Lexus app doesn't save vehicle
  247. GX 460 Luxury front-side and rear cameras
  248. Which drives better - Premium or Lux
  249. 4Runner Limited to 2023 GX460
  250. My 3rd GX Happy to be back
