- Yet another sludge thread...
- My last CEL question
- 2000 RX 300 CEL (update of previous thread)
- Transmission Filter Kit
- fuel filters?
- 75,000 is the begining mark of high mileage? please advise?
- Engine flush? please advise?
- Aux input for Non-Nakamichi systems
- Issues with Short drives
- Need advice... Should I raise my deductable?
- here a picture of my rx300
- Front end problem.
- 2000 RX300 CEL questions
- Lexus Rx300 Full Set Pedals? Look!
- 01-03 Front Headlight Fit 98-00 Model Rx?
- TPS and A/F Error Codes
- power antenna motor
- Lexus RX300 USA Brochure Archive
- Passenger's Side Only A/C Not Working
- No heat drivers side only
- mobil 1 synthetic 15,000 mile service?
- Filtermag? Good Investment?
- Kharma, then Teaser...
- 02 RX 300- where to buy back hatch sun cover
- 02 RX 300- need accessory for key
- RX 300-back passenger door wont open from the inside
- oil problem
- Sputtering Rattle Sound? Please Advise? Thanks!
- Filters Replaced-Cost effective maintenance repairs?
- 99 RX300 Engine Sludge Questions
- Gel vs Carbon?
- Aux Input for 1999 Rx300
- lexuspartsonline.com
- Questions about struts and lowering
- 90K service
- does any one know where to buy thermal exhaust?
- Are These Good To Have? Do They Work?
- what is the D.C.C short fuse in the engine compartment?
- Throttle please advise!?
- "what A Dirty Pcv Valve Looks Like! Pics!
- RX300 skid control way too sensitive
- Error code P0330 - Knock sensor replacement
- Help out the new guy!
- A/f Sensors And 02 Sensor Question? Please Advise Thanks!
- Torque Wrench Recommendation
- Quick acceleration vibration
- P0302 - Bad Coil: Thank you Forum & Lexmex
- Where To Buy Front License Plate Holder?
- Fluids for 2001 RX 300
- 2003 rx 300 door lock and shift knob
- Exhaust flex pipe issues
- will 19x8 offset ET20 fit ...Is that too big?
- Should I change my transmission fluid in a high mileage RX?
- Gen 2 Navigation Destination button greyed out
- RX300 - Remote Question
- Screw on add on tips? Anyone do this?
- 2000 RX 300 35,000 mile service
- Something Wrong With Fuse or Wiring?
- cable for mp3/ipod to cd changer connector
- Vibration at speed above 75mph (120kmh)
- Just finished Brake Job- but some problems
- Trans blew on my RX
- Brake job questions
- A big black muffler
- spark plug question oem vs. aftermarket?
- Broken Power Antenna
- Tint
- Odometer Mileage on your RX300
- RX300--Jumping, and Dying, and Stalling (Oh My!)
- Tranny!!
- 2000 Rx300
- Front license plate bracket rx 300 2003
- Using K&N HP-2009 oil filter vs HP-1002
- New owner intro.
- IACV cleanup weekend project
- engine oil and tranny oil , spark plug questions please advise. thanks
- engine oil and tranny oil question please advise. thanks
- Light are Bad
- Any way of checking
- Drive Belts for RX300
- Cel
- REAR HATCH, latches but dash lite & bell indicates “Open” ??
- Should I buy it?
- RX300, Smoking and burning oil at 75k ???
- Rotor Resurface Already?
- Vsc Vehicle Skid Control Light On?
- Tire Forum
- RX Slammed on 22s
- I'm sure you are all happy now...
- ATE Super Blue Brake Fluid DOT 4
- Belt Squeaking Real Loud
- wheels/ tires on 99' RX300 question
- 01 rx 300 hard starting
- 2000 RX300 Engine Tick
- Ah the joy of...transmission?
- What could be the problem? Check Engine, Trac Off, VSC light just turned on
- The last exhaust modification in Mexico (and it was a good one)
- Electrical Problems?
- Need Source to purchase parts
- Help please location pics front view of fuel line before going to fuel injectors?
- What years
- How many miles before a brake job?
- Transmission Issue at Higher Speed
- QUICK HELP NEEDED!! Bolt Size....????
- lexus rx 300 few questions ????? help?????
- Will these 22" Wheels fit my RX300?
- Stabilizer bar link removal
- Advice on timing belt
- whole headlight removal plus front bumper removal help? ANGELEYES INSTALL....
- trd chrome oil cap? buy or pass what you think?
- Rx300 Cooler Tempuratures At 18psi?
- Do I need Struts?
- Ignition key will not turn
- Exhaust upgrade for rx300?
- Recalibrate? please advise...
- 2001 rx300 advise with pics please... IAT sensor location pics please?
- Rear Toe-in Bolt Frozen
- Your MPG/MPH #'s on display
- Re;A/F sensor
- Driver Side Visor not staying up
- RX300 SUN SHADERS? WHERE TO BUY A HUGE BIG ONE? also chrome pedals? folks ideas?
- Does oil age when not used???
- Impact Hammering stuck rotors?
- Wood Steering Wheel has dulled...can it be salvaged?
- Not Good!
- Tempeture changes
- Newbie just bought an RX
- Aftermarket Skidplate Winbo?
- Brake Bleeding Valve Cap
- 2001 Rx 300 Visors & Dash Covers Please Advise?
- RX400 factory wheel......?????
- PO171 code
- Strange noise in passenger footwell
- Need ideas - Rear end noise
- 00 Codes PO171, 172
- '02 RX 300 Check Engine Codes
- MPX Body control question
- Can only 1 tire be replaced for a road hazard failure?
- rx300 01-03 visors?
- All 2001 rx300 please advise!!! Check engine?
- Parking lights
- losing coolant; HID hedlights
- Low gas mileage
- Does the '01-'03 headlights fit on the '00 RX?
- Off Road use of RX 300
- Transmission Filter Prices
- 2001 RX 300 Front Grill Emblem
- Airbag Warranty Coverage
- Another P0171 mystery
- Nakamichi Amp Problem
- pb rx300
- Coasting at idle
- how much can I expect to pay to replace all 4 shocks at Lexus or Toyota dealer?
- Harrier-like sides, deletion of side markers
- `99 RX300 leaking water
- New AMP for RX300 to increase bass?
- Possibly another trans failure
- Replace side runing light RX300
- Toyota dealership
- I'm SOOOOOO MAD!!
- grill size on rx 300 silver sport -
- Torque Plate & Rotors
- Engine Removal!
- 99 awd RX300 oil change and tranny change
- Radio Doesnt work?
- 2001 rx 300 owners please advise! thanks
- Strut mount replacement
- K&N air filter
- seafoam
- CCFL blinkers?
- does custom exist?
- Ignition problems...
- How to tell if you missed your RX
- keyless entry not working
- interior (photoshopped)
- Oil product that gets my recommendation
- P0171 and Possible Exhaust Leak
- CarPC Anyone?
- Time for Brakes
- 99 RX300 Control Arm Bushings
- What year did the Transmission Change
- Add factory heated seats to RX?
- Just bought a 2001 RX300
- retrofit pics continued
- Valvetrain Pics, input on sight...
- Question about Tein S-techs
- My spark plugs, is this a bad sign?
- Ok, Thermostat and Coolant temp sensor
- what do you think?
- Tire Suggestion
- Squeaky Steering Wheel Problem (Pics and video)
- finally ready for my interior mods
- aftermarket cluster?
- slow start
- finally a sway bar for rx?
- 2001 Stereo HELP!
- Clunks, creaks, groans, etc.
- How to upgrade from non Nav to Nav???
- German Castrol
- I Love It!!!
- painting body cladding
- Interesting photoshop
- Finally an air filter in my RX
- warning lights
- Security light stays on
- Should I Trade in '00 RX for a '98 GS300?
- Front License Plate Mounting?
- Driving Pattern Selector Switch
- 99-00 and 01-03 difference
- holding back power
- touch up paint for bottom gray
- p1150 A/F Sensor Circuit Range/Performance Malfunction (Bank 2 Sensor 1)
- shift linkage
- Seat heater replacement
- Re; timing belt
- Exhaust modification, y-pipe before the cat
- Which years are the best for rx300? please advise
- P1130 and P1150
- Any write-up on changing the struts on a AWD?
- Bye Bye PT CRUISER...Hello 2002 RX300!
- Fog Lights???
- Power door lock fix
- When is a good time to sell
- RX300 Spark OEM Spark Plug
- Replacing O2 sensor
- HELP!! Nused...lexus 00 rx owner
- Few cosmetic questions...
- Dealer Service Codes?
- 99 RX300'D 90k Service Questions
- When do you change timing belt and what along with it? water pump,
- small leak of some sort
- a/c system only blows HOT air
- Tires-mud,snow,street
- 2000 RX300 in dash CD no workie (disc number just blinks)
- my car audio system
- modding rx300(engine,wheels,tint,Offroad,etc)?
- torn front brake caliper boot
- 99 RX300, sludge, problems. Just bought!
- front and rear door speaker install please?
- Removing the glove compartment to get to blower motor
- Keyless entry problems
- AC Belt DIY?
- How to connect a switch
- premium octane fuel? 87 vs 91?
- cel
- headlight leveling system
- 2000 rx300 cold start up stalling
- Leaking Tranny
- In Dash Headunit/DVD player?!
- open door indicator problem
