- Removing Rear Muffler section of exhaust IS250
- Driver window rattle help.
- IS350 Code P0020 - Camshaft sensor problem
- Pre-facelift vs facelift models
- Questions about replacing rear axles.
- Time to change IS350
- Melting Dashboard -- out of warranty
- Who knew.... 2013 recall for stickies
- Anyone replace a rear CV axle on 2011+ 350awd before?
- Cabin Temperature Sensor
- Red SOS Light On All The Time?
- 12000 for a 2006 IS350 w/ 45k
- MPX Override for Fog lights when running lights are on? Help
- P0172 & P0175 on 2006 RWD IS250
- P0051 IS250 Manual RWD
- HID to Halogen headlights
- IS350 AWD Fitment
- Power Steering Blues
- Sunroof jammed on right side
- 2008 Lexus IS250 Outside Mirror Glass Replacement
- Help: bumper cost and touch screen problem
- 2008 IS220d Sensor Problem
- Rough and low idle and O2 and MAF codes
- M2/manzo exhaust any good??
- Best exhaust under 400$?
- Should I SWAP my '08 IS350 for an '08 IS250 6MT???
- 2006 is250 awd Driver side rear wheel isn't moving
- Weak battery or dying alternator?
- IS 250 2nd Gen Hood Hinge DIY Installation?
- Lexus IS250 2007 electric seat stuck in back tilted position - help!
- Lexus IS250 2007 automatic seat won’t tilt back or forward
- Throttle controller no lag extra quick???
- LEXUS IS 250 steering wheel is stiff and stuck in a locked position
- Lexus IS250 Code P2118
- Time for a new IS
- Awd engine drop into manual rwd car swap
- Need help. URGENT (should I buy an IS with engine codes)
- Cold start isn't loud?
- INCREASE gas mileage? APEXI throttle controller? DOES IT WORK?
- How to out car in neutral with a dead battery
- Replacing bank 1 sensor 2 02 sensor?
- IS 250 2008, trunk actuator
- Upgrading factory Navigation IS 350
- Diag bad wheel bearing
- Fusible link white with blue line wire
- IS250 Heater Core Replacement
- AWD front axle nut removal
- How do I know if the rims fit my babe?
- IS250 Satellite Switch & Instrument Cluster
- 2007 IS 250 - Airbag light on after navigation repair.
- AWD Splash shield
- Oil catch can?
- 2006 IS350 none navigation system to aftermarket
- Headlight Identification
- IS250 Bluetooth problems
- Hello from the Netherlands & Unique iPod mod (?)
- Is350 scan codes
- Help! 2 problems with sons 2007 IS250 w/Navigation no premium sound!
- 2009 IS350 Engine test out of car
- New owner
- head unit replacement
- PCV Breathers: YES or NO
- sewell headlight set for sale
- Door Sensor Over Triggering
- A few questions on the IS 350 engine sounds
- Bolt replacement help.
- VLAND Tail Lights & Puddle Light Activated front and rear lights
- Increased wind noise/whistle from front of the windshield
- 08 IS250 with 322k miles for sale
- Has anyone tried a lightweight flywheel with SPUNG OEM clutch combo?
- DIY: Fusible Link Block Removal for 2006 Lexus IS250
- please help!! car wont start
- Sold my 08 is350
- Where should i wire my custom tweeters into?
- Need help with intake plenum questions
- Who has Radar Cruise control?
- Pls I need your help 2006 Lexus is 250 speedometer wouldn't read and my P/s light is
- Wheel hub assembly SKU
- Swapping out the main ecu
- DIY Auto-Folding Mirrors for £6.49 (GBP)
- What kind of bulbs do our fog lights use? 07 is250
- IS-350 key fob, is it illuminated?
- Battery or alternator dead?
- Lexus Smart Card Key.
- Serious question
- Outside mirror compatibility question
- Starting vehicle after 3 years
- Possible IS 250 Purchase
- Acc wire location
- How else can I get into my trunk?
- CEL Please help
- Help with Drone in Cabin
- Car won’t start
- Noisy stock exhaust
- Pin-out diagram for instrument cluster
- Jerky in certain conditions
- Looking at buying a '12 IS350 F-Sport w/ 106k miles for $15k. Bad idea?
- Disk changer
- IS250 Noises
- IS350 E85 custom tune result!
- Sweet looking bumper on this 2IS!
- Piano black interior
- Aftermarket parking sensors on factory harness
- Fidanza flywheel with Clutchmaster FX250 clutch..Impressions
- rear view camera replacement
- EMERGENCY.. need engine help, ASAP!!!
- Gasket
- is250 AC problem
- F-Sport Intake Part Number
- Rough idle at start with codes
- 07 IS350 K&N Air Intake
- Code P0420 - Catalytic Converter
- Can/Should I go lower?
- 07 IS350 Front Lights
- Will these TPMS work
- Ac blows cold air on one side and hot air on the other
- Steering slightly resists sometimes at high speeds
- Ebay cheap headers question
- Does anyone have instructions on how to install the damper door assembly?
- Winter tires
- Is oil burn normal?
- 2nd airbag recall?
- Removing quarter panel carpet.
- Is220d 2008 power loss
- Blinking front defroster light
- IS250 Drainage problem
- Aftermarket fiberglass sideskirt question.
- driver side door lock
- Non ML amp bypass
- 06 IS250 RWD exhaust leak
- Upgrading to 2012-2013 headlights, question on what is needed
- Who serviced your car
- Looking to replace my headlights, what do you guys recommend?
- Replacement fog light electrical connector and pigtail
- My rear diff has the worst rust you've seen. Prove me wrong.
- Help cars leaking fuel
- Electronic Conversion Kit for 2007 lexus is350?
- 2IS 5W30 vs 5W40?
- Airbag recall service
- Check engine and traction button lighning
- 2ad-fhv Ac compressor
- a/c outside and inside circulation buttons
- Burning Smell Car Wont Start Anymore
- Quick Question 2IS Grill Fitment
- Need help on deciding which exhaust to buy.
- Switching instrument cluster
- IS250 AWD Weird Trans/Electrical Issue
- 06 IS250 Rear Bumper Question
- Is350 rear seats removed, slower 1/4 time???
- Rear diffuser
- Traction control and Engine light on
- need help with code. P0174
- Is250 AWD with rims & springs upgrade
- Boosted 2007 IS350 Turns Heads
- P/S problems help please?
- Anyone got a European or Australian IS?
- Driver side window doesn’t work
- Steering wheel stitch-on perforated leather & F emblem
- Lexus IS250 All windows and door locks
- Thinking about getting the E85 tune
- Should I trust "Pre Wired" 2011+ Headlights from Ebay to install on My 2010
- Please help! Battling CEL '06 IS250
- Lexus IS 350C part ID
- Considering a performance exhaust, muffler/resonator delete? Read this
- 2007 IS250 Radio Sound is Weird
- part number
- Wheel Bearing kit lexus is 250 2007
- Slap Chopped
- OEM Replica Nav Unit
- Rear sway
- Car acting up with no codes
- 2 maintenance items I performed on my IS 350 that made a noticeable difference
- Build ideas? Lexus is250 2006 rwd
- 2008 Is250 Not shifting under load
- 2008 IS 250 Headlight replacement
- P0031 and P0051 IS250
- LED on speedo needles doesnt work
- Underbody cover DIY
- Pleased with walnut shells results
- Adding OEM backup camera - need help with wiring
- Tire pressure sensor question
- Does anyone know if broken cabin air filter door effects all controle of fhe front ve
- Twins again!
- Steering wheel stopped tilting in and out after shop worked on my car....
- 2006 IS350 - How to turn on heating??
- CV axle help
- My 06 awd
- PPE Headers / High Flow Cat
- Light bulb E=MC2
- What do you guys recommend using for the interior & leather on your IS?
- INGS Front Lip Replicas?
- Clutch pedal feels notchy/bumpy when releasing
- Is it possible to replace just one of the bottons on the rear view mirror?
- Interior leather wrap
- Michelin Pilot SPT AS 3+ tires
- Where to get genuine parts?
- Just introducing myself- 2010 IS 350 Sport
- IS250 Not Cranking
- Alternative fix for sticky/melting dash- Coverlay Manufacturing
- 2IS with PPE + HFC + Megan Racing Midpipe & Tanabe Axle Back
- Turn Signal Out??
- Horn Is Dying
- Stock Exhaust Drone?
- Quick Question about suspension
- 2006 IS250 Engine Temp goes down then back to normal when accelerating
- Led strips on fog lights what do you think?
- 08 IS250 hood replacement
- Check headlight system warning on...
- Voltage Signal when you lock the car
- LSD question
- Using an amplifier from GS350
- AP2 S2000 Exhaust Tips
- 2006 is250 awd cel
- GM8157ZT wire diagram and schematic
- oversized oil filter & housing for 2007 is250 RWD
- Dieting Gone Right or Wrong: IS350 Under Pressure
- Cold Air Help?????
- Part Replacement Name
- Is this the rarest Lexus IS?
- help, headlight out
- F Sport Intake Question
- Super sick Lexus IS!
- A/C condensation drain outlet
- 08 is250 awd not working
- Rear clunking noise under acceleration
- Stock HID Ballast brand and model
- HELP PLEASE! Cabin filter door linkage missing
- Aluminium sports pedal
- Anyone help identify this leak? pics
- Picked up an 08 IS350
- Navigation,Climate control,Radio and buttons not working
- 2IS Volt Gauge
- 2006 IS250 Radio Replacement
- Desperate,need advice on what can be wrong with a 2006 Lexus is350
- Lease is up in December - Looking to buy a 2nd Gen IS350
- P0500 IS220d
- Bad universal joint question
- Permanent +12v in Front Door
- Transmission fluid and gear oil fluid
- IS250 intake duct on IS350
- Vossen CVT
- How do you know when alternator is going bad ?
- Another ashtray phone holder mount DIY in a 2IS
- Clunking noise when putting car in drive
- 07 is250 rear sway bar Location
- Best parts stores anyone?!
- Exhaust info needed
- Bumper and bumper supports (HELP PLEASE!!!)
- SRS airbag light of death (B1000) - Help!
- 2009 is250 transmission
