- P1277 LEXUS - Port Injector Circuit Number 2
- Rim recommendation!! Help
- Oil Filter?
- K&N filter for 2005-2013 Lexus IS 250 $18.75
- Rear brake sound
- New Mods - Carbon Hydrodip interior, Blue Hybrid Start Button & LED Upgrade
- PX6 Tesla Radio Install - 2nd Gen Lexus IS
- New member. Anyone selling an axleback?
- How is it with conversion to F-Sport?
- Engine fan noise
- Drag Brand wheels
- Front Differential
- Rattling/Creaking noise
- bank 1 catalytic converter is gone, what should I do next..
- AWD 2is information discovery idk
- IS250 Oil Catch Can Install + PCV Valve Replacement
- Fuel trims
- Does downstream o2 sensor actually adjust air fuel ratio?
- A/C stops blowing once a week.
- P0304 and P0305
- Has anyone slapped on a muffler NOT made for Lexus IS?
- is possible to downgrade the navigation to a non-navigation system in a lexus is250
- Group Buy Speed Freaks USA group buy for OS Giken LSD
- Savagegeese review of the Lexus LC500, GSF and RCF
- 2010 Lexus IS250: How to Replace Center Console Light
- Trunk Rain Drain Gutter Cleaning & Fixing Trunk Panel Flap
- Aggressive lip+splitter for 06-08 models?
- My thoughts on installing an ISF Steering ECU
- Dash lights and stalling issue - 07 IS350
- 2008 is350 65k miles. Squeaky suspension?
- is350 squeaky cruise button
- Clutchmasters flywheel and FX100 clutch kit?
- anyone painted their stock wheels?
- What is the best phone holder for the 2nd Gen IS?
- 2007 Lexus IS250 RWD [MokinWinks]
- Anyone used non oem fuel pressure sensor?
- Anyone convert HID to HALOGENS ???
- IS350 AWD Driver Road Sound Diagnosis
- Used BC racing coilovers
- Straw Blowing Sound When Accelerating And Cruising
- Gear shifter is loose
- Help with disabling auto play in Bluetooth audio
- Dorman Key fob with programmer
- Water Temperature Sensor Adaptor size
- At my wits end- IS350 won’t start
- Rotten Egg Smell Fix on Lexus IS250 2008
- Steering wheel buttons not working
- 2006 Lexus IS 350 Head Unit - No power
- 2010 Is250c
- fuel level sender problems
- Not sure what to replace - TPMS
- IS300 09' spiral cable problems
- DIY Ceramic Coating on 13 Year Old Paint
- Check VSC: just C1201 code
- Lexus RX/GX key compatible with IS?
- Resonator or muffler delete?
- 07 Lexus Fitment Help!!
- Frame bent?
- A tad surprised how easily I walked a Type R Civic at 85MPH+ today
- Cabin Air Filter
- New Tire Setup, Does it work?
- 2012 Lexus IS250
- Navigation issue
- Need help after alt installation
- In search of ISF rims!!
- Blinkers conversion to LED
- 19” GS 350 Fsport rims on 2IS. Will they fit?
- Can anyone help me With my is250...
- Had both rear axles replaced now differential is leaking
- G-Spyders worth saving?
- CT200h hybrid engine into an 08 is350?
- Wheel Well Molding
- What have you done with your 2020 stimulus check??
- Automatic Transmission fluid condition
- Tune/file knob stuck
- A/C blowing warm air
- Trunk remote control program
- slightly louder exhaust than stock?
- Exhaust fitment
- XXR 527 Question
- Phoenix Auto PX6 Stereo
- Pennzoil Ultra Platinum 0W-20 wrong oil?
- 2012 Lexus IS350 F Sport Wheel fit on a 2006 Lexus IS350
- Side blinker light change (turnsignal) is 250
- Which MOD did YOU do. . .that was useless OR not worth the money.
- Need help with wheels
- X-PIPE Exhaust. Is it the same sound as resonator delete?
- Diff fluid question on IS250 AWD
- Some interior improvements
- Need help. IS300 2009 headlights.
- Possibly broken AC? Not sure
- ISO Coilovers
- New Lexus Owner
- Bad Experience with Maxlife Full Synthetic ATF
- Is the RCF/GSF LCA bushing good as RRracing/Figs?
- Are SWAY BARS and LCA (RR racing/Figs) WORTH IT FOR MY DAILY DRIVER?
- How to improve vague steering?
- Is 250 2010. no alternator output
- Best stereo for 06 is350
- Anyone have APEXI THROTTLE CONTROLLER?
- Lexus is250 2006 CHIRPING NOISE
- Anyone have experience with exhaust cutouts?
- Lexus is 250 turning off when i put in gear
- Strange transmission behavior
- Help! [steering wheel clockspring problem]
- Another purchase question
- New owner needs help with air vent removal!
- I'm Back
- P0302 at 225k
- What exhaust does this look like? (AXEL BACK)
- Can I run a SQUARE tire setup on RWD IS350?
- Asking help with some DTC 2008 IS250
- 2007 Is350 Lexus Crank Shaft Sensor
- Wrong bumper cover???
- Dealer "Prank" got me
- Does anyone know
- What's this silly sound?
- IS250 stuck in 4th gear.
- Beat Sonic - Phoenix Tablet or Grom Unit?
- It's been real guys goodbye 2IS community
- Upgrade Stereo 2007 IS250 WITHOUT ML system but w Nagivation
- Calling all Experts - alignment challenge
- 2011 to 2007 IS navigation screen
- Are these tires/wheels a good deal for $500?
- is350 what antenna
- 2IS 2012 - A/C issue
- 2009 IS250 sunroof wind noise
- IS Dash Replacment
- awd binding at full steering lock
- Looking to purchase an IS250 AWD
- Android Headunit for 2008 IS250 ?
- Strange sound coming from wheel
- Dash removal/reinstall is350
- HELP alternator problem!!!!
- 2014 to 2006 fenders
- Just a quick question
- Driver seat repair
- New Tesla style so-called 10.4 inch screen
- Help! someone wants to trade cars with me!
- 2010 IS headlights and fog-lights
- Bumper Conversion
- Techstream erasing/clearing used key
- Bleading Brakes
- Lexus key card
- Help!!! No Power Steering, No ABS, No Traction Control
- Will a 2011 lexus is350 tranmission fit my 2006 lexus is350 ?
- Tesla style android budget system, px3 Airbag ON after installation. Bug FIXED!!
- Is250 misfire problem
- Car audio Reverberation
- Why is the is350 more reliable than the is250?
- NEED EXPERT HELP! 2006 is250 RWD 6spd won't start! Electrical Specialist Pls!
- Any additional parts to replace while doing spark plugs?
- Aftermarket Android Auto Infotainment?
- Looking at a used IS purchase - thoughts
- Carbon Fiber Rear Diffuser for 2012 IS350 2nd generation
- ***The radiator cap "challenge"***
- Dash repair ideas
- Aftermarket DRL's
- Battery Maintainer?
- Canadian Spec AWD Is250 DIfferent rotors?
- 2008 Lexus is 250 Fuel pump
- IS350 Rear Tire Wear Figs Toe Link Fix?
- WOW... Stolen ISF wheels on LEXUS dealership LOT! BEWARE BOYS
- GS 350 F sport wheels on IS250 fitment?
- Lexus IS 350 solenoid
- Could use some help [Spark plug replacement]
- New Radio Sounds Horrible!
- Fuel Door Lid Removal
- Not displayin on screen
- 2010 is250 AMP Relocation
- 3" exhaust fit our pipes? (LOUD)
- IS350 AWD Wheel Question
- No power till 3k
- Thinking about buying a 2012 is250 F sport
- F Sport exhaust or muffler delete?
- My 2007 Lexus IS350 made it to 300,000 miles!
- Exhaust TIPS?
- How to remove 2007 IS350 driveshaft
- Camry 17" wheels for winter tires??
- Ignition Coil packs. Anyone had to replace any?
- Muffler delete? Is350
- Replaced ECM-Smart Key Module-ID Box won't start
- Anyone ever order from phoenixautomotiveinc.com?
- 2012 IS250 fog light
- Anybody running a F225/40 R245/40 +40 setup?
- Diag VSC Message
- Help! Diffusers, Lips, & Skirts
- Headlights making buzzing noise and sometimes my right ones out sometimes the left
- Stereo Install HELP
- Ac/heater not blowing air
- Exhaust code and smell fix
- 10” vs 12” Sub (Options/Experiences)
- Has anyone replaced a dashboard? DIY SWAP
- Car not turning on
- 2007 is350 p0500, P0894, P2714
- Help with HKS Exhaust/Exhaust Flange Spring & Bolt
- Trans Pan and Oil Feed Tube Leak!
- Is350 On Fsport Springs wheel setups
- Check VSC, CEL, and traction light
- Coolant loss 2006 IS250
- G-spider wheels!
- IS250 Single Mass Flywheel (SMF) conversion and 2010 6spd upgrade parts and tips
- Transmission control or what is this?
- Work Emotion KIWAMIs 18x8.5 Front 18x9.5 rear fitment for IS350 2IS
- Looking into Lexus IS350 2006
- BG additives
- Aftermarket Wires Ran to the Trunk - Using Factory NAV stereo. HELP PLEASE!
- timing chain
- ISF Weather strip T clips
- I was considering buying the RR Racing ECU Upgrade Tune...
- 2011 is headlight conversion to 2013 headlight with led strip
- Performance
- 2008 IS 250 Actuator help and recommendations??
- Oil Leaks
- Custom tune for 2is
- DIY Cluster light fix
- 07 is250 cranks but won't start
- F Sport Sway Bar set question
- Tyre size
- Will I notice the difference between V & Y speed rated tires?
- Need Help My IS250 AWD Wont Start!!!
- Awd wheel spacer help
- Alternator bolt question
- What mod made YOUR is350 more fun?
- Wheel Fitment Help (18x9.5)
- Oil Catch Can mesh wall between in/outlet?
- Question
- Can anyone fix my burnt out gauge light?
- Resolved: Accidentally Ruined Wiring Harness P0345
- Overheating issue
- Weird Headlight Issue
- Valve body or solenoid????
- Need help.
- Rust
- 06 IS350 Green Brake Fluid Growth, Time For Brake Flush?
- Looked at a used manual IS today and...
- I lost my key fob.... PLEASE HELP
- intermittent RPM @ 3K on start
- AWD torn front CV boots - advice?
- Please help ! [best offset setup for a 2011 lexus IS250 rwd?]
- IS250 bad alternator or battery. Help!
- wheels !
- Which fuse is responsible for unlocking the trunk?
- Big 3 wire upgrade
- Is Obd2 scanner
- 2006 is350 new owner FAQ
- In a time bind need advice please
- Injen Cold Air Intake
- AFS lighting adjustment
