Exhaust code and smell fix
Old May 12, 2020 | 04:09 PM
lexus0707's Avatar
lexus0707
Default Exhaust code and smell fix
Hey guys,
I currently have a 2007 lexus is350. I have been getting a horrible exhaust smell for a while now. I took it to one shop, where they located a small leak before the o2 sensor right under the drive side door therefore I had it repaired. No change In smell. I then took it to a high end exhaust shop where they told me that both mufflers and resonator are leaking at the top. As a result I've seen before that replacing the trunk vents will help with exhaust smell therefore I took them out to notice the flaps were completely gone. I then duct taped both of them, reinstalled them and the smell Is completley gone.
I'm currently getting a p0430 code cat bank 2 below threshold. No other leaks are were noted by the shop and I threw a heat gun on the cats and they seem to be working good. Any ideas on what could be causing the code?
Thanks.
Old May 13, 2020 | 08:18 AM
Gville350's Avatar
Gville350
You might still have a leak somewhere, the cat might be bad, or the O2 sensor might be bad.
Frank2029
Feb 7, 2020 09:49 AM
OilMemes
RX - 1st Gen (1999-2003)
16
Mar 17, 2019 09:28 PM
shadykev
Jun 16, 2016 09:31 PM
MattyG
Sep 6, 2013 07:34 PM
djzapp78
Sep 3, 2008 06:07 PM
