Electric power tailgate retrofitted on 3IS
Old Jul 22, 2023 | 02:46 PM
ahmed24's Avatar
ahmed24
Default Electric power tailgate retrofitted on 3IS
The 3IS seems to come with some spring system for the tailgate which is not as well refined as having gas struts. A 3IS owner wanted to retrofit power electric tailgate on his 3IS. So I’ve completed the project and the results are amazing and so thought I’d share a video demo showing the finished result. All the buttons work. The trunk is operated from either the interior button, the key button or the button on the trunk. At a later stage, I will be adding the kick sensor to it like I did on my 2IS as the customer did not order the universal kick sensor. Waiting for that to arrive.
Here is the video:
Old Jul 22, 2023 | 02:51 PM
AkioToyoda4Ever's Avatar
AkioToyoda4Ever
I could never do that to my car; I'd be concerned that I'd be giving my kidnap victims a time window of escape.
Kidding aside, this looks cool.
Old Jul 22, 2023 | 07:34 PM
kj07xk's Avatar
kj07xk
Nice! Any guidance on how to add it my IS?
You’re on the other side of the pond, so if this is a service you sell, kind of hard to get to your shop.
Old Jul 23, 2023 | 01:09 PM
ahmed24's Avatar
ahmed24
LOL 😂
Comes with Chinese instructions which were as always with most Chinese products absolute piece of junk lol. It has illustration pictures that were so small you cannot make heads or tails of it. The wires are pretty much self explanatory it all has colour coded connectors that connect to the supplied electric tailgate ecu. The only parts that hooks up to the original car wires is a connection that needs to go to the trunk door actuator lock. It comes with a adaptor where you disconnect the trunk actuator connection then plug in their connector and then plug the original car one to the other end. The only thing is the switch on the tailgate you have to tap into the switch button so that the interior switch and trunk switch continues to work. Everything works just like it should. If I press the trunk button it beeps and starts to open. If I press the button inside the car same thing happens. If I long press fob trunk button it does the same open and close function. And you have the additional closing button inside the trunk. I will add the universal kick sensor for the customer at a later stage as it’s on order
Old Jul 24, 2023 | 08:31 AM
kj07xk's Avatar
kj07xk
See this one on Alibaba, is it what you used?
Old Jul 24, 2023 | 02:22 PM
ahmed24's Avatar
ahmed24
Here is the link to the one I installed. If you contact the seller mention my name “Ahmed” referred you and you seen my install and he might give you a bit of discount https://m.alibaba.com/product/160052...-Tailgate.html
Firstlexy
May 20, 2023 03:53 PM
glamglam
ES - 7th Gen (2019-2025)
Dec 12, 2022 09:01 PM
ItzFilyO
Aug 25, 2022 08:06 AM
ahmed24
Oct 14, 2021 02:46 PM
RuninRoach
Nov 6, 2018 07:34 PM
